  4. Is it possible to use a single reaction for multiple entities as variables?
30 Posts 4 Posters 10.0k Views 4 Watching
    Go to your Entities list, and find the window_sensors group entity, look at its attributes while you open and close a listed sensor. If it's not changing, then you either have an error in your DGC configuration, or the device(s) aren't responding as expected.
    Remember also your basic troubleshooting steps: any time something doesn't work the way you expect it to, go look in the log files for messages. DGC configures groups at startup, so look at the messages logged for DynamicGroupController during startup.
      I was just going around the hosue and testing different windows.
      Some of the windows seem to work. When I use sys_group.empty (primary), the value when all the windows are closed is True: The windows that are working, the boolean changes to false and the Local Expression value (window_names) changes to that window. I'm going to have to pinpoint which windows aren't working correctly. It could be an issue in the HA configuration.yaml for the DSC/Envisalink entries. That's for me to figure out.
      The only other issue is the message. It's not sending the value of the string. I'm receiving $ Opened!
      message: ${{ window_names }} Opened!
      Edit: The one I had been testing with, right next to my office desk, does change in the entities tab.
      Office Windows
      hass>binary_sensor_office_windows
      true
      1:38:38 PM
      Edit 2: I copied and pasted from the Entities tab the Office Windows Canoncial ID into the reactor.yaml config. Even though they looked identical, once I restarted reactor, that window is now responding properly. I suspect I may have hidden characters in the ones that aren't functioning.
      • T tamorgen
        @toggledbits said in Is it possible to use a single reaction for multiple entities as variables?:
        Seems OK
        It's still not tripping in MSR when I open a window.
        This is what is being shown when all the windows are closed. I'm not really paying atention to the comparssion value, jsut the current value it's displaying. That value isn't changing.
        I tried it with sys_group.members as well.
        None of the comparisons seem to make any difference. Current value: array:0) "" remains the same in any state of the windows.
        @tamorgen said in Is it possible to use a single reaction for multiple entities as variables?:
        Seems OK
        I went back to all the windows in the reactor.yaml file and copied the values directly from the Entities tab. They are all now working.
        The only thing not working is the notification. Any ideas what the cause could be?
        • T tamorgen
          Seems OK
          You have:
          That stands out because it's not valid YAML. Missing quotes.
            You have:
            @toggledbits, how should the quotes work for a MSR variable in yaml? I copied your example in the second post, but you aren’t calling a HA function. I’ve been playing around with it, but I’m not getting the variable in the system call.
            I’m looking at this documentation for HA.
            Script syntax
            Script syntax
            How to write Home Assistant scripts in YAML: the available actions, their structure, and how to use them inside automations.
            They show an example
            data:
                message: "{{ blind_state_message }}"
            So, in theory,
                message: "{{ window_names }}" opened.
            should be valid. The difference here is that window_names is coming from the local expression.
            However, MSR throws an error, telling me that I have invalid service data.
              #21
              @tamorgen You need MSR to evaluate the whole data being sent
              ${{ { “message”: window_names + “ opened!” } }}
                #22
                @Crille said in Is it possible to use a single reaction for multiple entities as variables?:
                That's not working either. It actually disables the Play button at he end of Entity Action.
                This is a system call on home assistant (call_service) to send a notification via the HA companion app. The message: text isn't part of the message to be sent, it's yaml code that is part of the data field.
                For example, I have another reaction that sends a message to my phone when my washing machine has completed a cycle.
                The word message doesn't appear on my phone, just the data after it.
                Here is my current rule:
                In the Local Expressions, you can see Last value: (string) "Office Windows", so that value should be returned for window_names in the system call.
                  wrote on last edited by Pabla
                  #23
                  Try without the spaces so it looks like this message: ${{window_names}} Open. MSR supports both JSON and Yaml, but you just gotta make sure theres no errors. Usually online validators help with this
                  T 2 Replies Last reply
                    Try my example by hitting the general play button for Reaction.
                      @Pabla said in Is it possible to use a single reaction for multiple entities as variables?:
                      Doesn't work. MSR throws this error.
                        I don't think you have it written correctly here's an example of how I have it used in one of my own notifications
                          That triggers the notification, but the value isn't returned.
                            Don't use the play button next to the action, use the play button right under set reaction
                              Well that makes a difference! This has been driving me nuts all afternoon. Thanks for cluing me in!
                                It should look like this:
                                message: "${{window_names}} Open"
                                  160.4k
