  4. What does [Error] terminated [-] mean?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
Reset a delay
Reactor Loading Screen Safari
9 Posts 2 Posters 1.2k Views 2 Watching
  • SnowmanS Offline
    SnowmanS Offline
    Snowman
    wrote on last edited by Snowman
    Post has been updated.
    Need some guidance in determining what this error means.
    Running Reactor latest-23078-d592d400; ZWaveJSController; Docker on Synology; Home Assistant 2023.3.6; Z-Wave JS UI 8.11.1
    • I have searched the site and could not find anything related to my question.
    • I know what the rule does. Yet, I cannot find the relationship with this error.
    If someone could point me in the right direction, it would be appreciated.
    Rule is as follow:
    If the garage side door opens when the alarm is not armed and that both my spouse and I are at home:
    • Set Reaction: turn on the Siren_8 (basically a two seconds beep that was configured with the Aeotec Siren to warn us that the door is open)
    • Reset Reaction: turn off the Siren_8 in case it wants to keep beeping
    Here's the updated error.
    [latest-23078]2023-03-26T22:31:36.772Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:36.772Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:36.773Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:36.773Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:36.782Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:36.783Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:36.790Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:36.791Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:36.799Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:36.799Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:36.800Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:36.800Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluation complete
    [latest-23078]2023-03-26T22:31:36.800Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:36.801Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:36.802Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluated; trigger state changed (false), but rule state remains RESET
    [latest-23078]2023-03-26T22:31:36.804Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:36.804Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:36.812Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:36.812Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:36.814Z <Engine:INFO> Enqueueing "Door Sensors State<RESET>" (rule-lerjv6if:R)
    [latest-23078]2023-03-26T22:31:36.815Z <Engine:INFO> Enqueueing "Notification: Home Security - Garage side door just opened (Disarmed Only)<RESET>" (rule-lbmoup28:R)
    [latest-23078]2023-03-26T22:31:36.817Z <Engine:INFO> Enqueueing "Toggle Vestibule scene 003 LED color state between green/blue<RESET>" (rule-lfn441bq:R)
    [latest-23078]2023-03-26T22:31:36.819Z <Engine:NOTICE> Starting reaction Door Sensors State<RESET> (rule-lerjv6if:R)
    [latest-23078]2023-03-26T22:31:36.820Z <Engine:NOTICE> Starting reaction Notification: Home Security - Garage side door just opened (Disarmed Only)<RESET> (rule-lbmoup28:R)
    [latest-23078]2023-03-26T22:31:36.822Z <Engine:NOTICE> Starting reaction Toggle Vestibule scene 003 LED color state between green/blue<RESET> (rule-lfn441bq:R)
    [latest-23078]2023-03-26T22:31:36.823Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing zwave_device.set_config on Switch#zwavejs>128-0 with [Object]{ "parameter": "9", "size": 1, "value": 2, "bitmask": 0 }
    [latest-23078]2023-03-26T22:31:36.830Z <HassController:INFO> HassController#hass action x_hass_input_text.set_value([Object]{ "value": "Closed" }) on Entity#hass>input_text_h_door_sensors_state succeeded
    [latest-23078]2023-03-26T22:31:36.831Z <Engine:INFO> Resuming reaction Door Sensors State<RESET> (rule-lerjv6if:R) from step 1
    [latest-23078]2023-03-26T22:31:36.832Z <Engine:INFO> Door Sensors State<RESET> all actions completed.
    [latest-23078]2023-03-26T22:31:37.043Z <Rule:INFO> Batteries State (rule-leucn9pp in Control Room) starting evaluation; because entity-changed ValueSensor#hass>sensor_garage_side_door_openclose_battery_level
    [latest-23078]2023-03-26T22:31:37.044Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_garage_side_door_openclose_battery_level
    [latest-23078]2023-03-26T22:31:37.045Z <Rule:INFO> Batteries State (rule-leucn9pp in Control Room) trigger evaluation result is true (previously true)
    [latest-23078]2023-03-26T22:31:37.046Z <Rule:INFO> Batteries State (rule-leucn9pp in Control Room) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-23078]2023-03-26T22:31:37.060Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) trigger evaluation result is true (previously true)
    [latest-23078]2023-03-26T22:31:37.060Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-23078]2023-03-26T22:31:37.062Z <Rule:INFO> Batteries State (rule-leucn9pp in Control Room) evaluation complete
    [latest-23078]2023-03-26T22:31:37.062Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:37.146Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) starting evaluation; because entity-changed Group#groups>low_battery
    [latest-23078]2023-03-26T22:31:37.156Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) trigger evaluation result is true (previously true)
    [latest-23078]2023-03-26T22:31:37.157Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-23078]2023-03-26T22:31:37.157Z <Rule:INFO> Notification: Battery - Low level warning (rule-lbh1vt4k in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:37.161Z <Engine:INFO> Resuming reaction Toggle Vestibule scene 003 LED color state between green/blue<RESET> (rule-lfn441bq:R) from step 2
    [latest-23078]2023-03-26T22:31:37.162Z <Engine:INFO> Toggle Vestibule scene 003 LED color state between green/blue<RESET> all actions completed.
    [latest-23078]2023-03-26T22:31:37.316Z <HassController:INFO> HassController#hass action x_hass_siren.turn_off([Object]{  }) on Entity#hass>siren_siren_8 succeeded
    [latest-23078]2023-03-26T22:31:37.317Z <Engine:INFO> Resuming reaction Notification: Home Security - Garage side door just opened (Disarmed Only)<RESET> (rule-lbmoup28:R) from step 2
    [latest-23078]2023-03-26T22:31:37.317Z <Engine:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only)<RESET> all actions completed.
    [latest-23078]2023-03-26T22:31:38.892Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:38.892Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:38.893Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:38.894Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:38.894Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:38.907Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:38.907Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:38.916Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:38.917Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:38.925Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:38.925Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:38.926Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:38.926Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluation complete
    [latest-23078]2023-03-26T22:31:38.926Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:38.927Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:38.930Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) constraints not met!
    [latest-23078]2023-03-26T22:31:38.930Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluated; trigger state changed (true), but rule state remains RESET
    [latest-23078]2023-03-26T22:31:38.931Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:38.932Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:38.939Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:38.939Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:38.941Z <Engine:INFO> Enqueueing "Door Sensors State<SET>" (rule-lerjv6if:S)
    [latest-23078]2023-03-26T22:31:38.942Z <Engine:INFO> Enqueueing "Notification: Home Security - Garage side door just opened (Disarmed Only)<SET>" (rule-lbmoup28:S)
    [latest-23078]2023-03-26T22:31:38.943Z <Engine:INFO> Enqueueing "Toggle Vestibule scene 003 LED color state between green/blue<SET>" (rule-lfn441bq:S)
    [latest-23078]2023-03-26T22:31:38.945Z <Engine:NOTICE> Starting reaction Door Sensors State<SET> (rule-lerjv6if:S)
    [latest-23078]2023-03-26T22:31:38.946Z <Engine:NOTICE> Starting reaction Notification: Home Security - Garage side door just opened (Disarmed Only)<SET> (rule-lbmoup28:S)
    [latest-23078]2023-03-26T22:31:38.948Z <Engine:NOTICE> Starting reaction Toggle Vestibule scene 003 LED color state between green/blue<SET> (rule-lfn441bq:S)
    [latest-23078]2023-03-26T22:31:38.949Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing zwave_device.set_config on Switch#zwavejs>128-0 with [Object]{ "parameter": "9", "size": 1, "value": 1, "bitmask": 0 }
    [latest-23078]2023-03-26T22:31:38.956Z <HassController:INFO> HassController#hass action x_hass_input_text.set_value([Object]{ "value": "Open" }) on Entity#hass>input_text_h_door_sensors_state succeeded
    [latest-23078]2023-03-26T22:31:38.957Z <Engine:INFO> Resuming reaction Door Sensors State<SET> (rule-lerjv6if:S) from step 1
    [latest-23078]2023-03-26T22:31:38.958Z <Engine:INFO> Door Sensors State<SET> all actions completed.
    [latest-23078]2023-03-26T22:31:39.284Z <Engine:INFO> Resuming reaction Toggle Vestibule scene 003 LED color state between green/blue<SET> (rule-lfn441bq:S) from step 2
    [latest-23078]2023-03-26T22:31:39.284Z <Engine:INFO> Toggle Vestibule scene 003 LED color state between green/blue<SET> all actions completed.
    [latest-23078]2023-03-26T22:31:39.530Z <HassController:INFO> HassController#hass action x_hass_siren.turn_on([Object]{ "tone": "30" }) on Entity#hass>siren_siren_8 succeeded
    [latest-23078]2023-03-26T22:31:39.531Z <Engine:INFO> Resuming reaction Notification: Home Security - Garage side door just opened (Disarmed Only)<SET> (rule-lbmoup28:S) from step 2
    [latest-23078]2023-03-26T22:31:39.531Z <Engine:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only)<SET> all actions completed.
    [latest-23078]2023-03-26T22:31:40.341Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_siren_siren_active_8
    [latest-23078]2023-03-26T22:31:40.351Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:40.352Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:40.353Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:40.645Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) starting evaluation; because entity-changed Group#groups>water_leak_detected
    [latest-23078]2023-03-26T22:31:40.654Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:40.654Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:40.655Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:41.311Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:41.312Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:41.313Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:41.315Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:41.315Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:41.327Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:41.327Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:41.335Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:41.336Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:41.343Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:41.343Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:41.344Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:41.344Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluation complete
    [latest-23078]2023-03-26T22:31:41.344Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:41.345Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:41.346Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluated; trigger state changed (false), but rule state remains RESET
    [latest-23078]2023-03-26T22:31:41.347Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) trigger evaluation result is false (previously true)
    [latest-23078]2023-03-26T22:31:41.348Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluated; rule state transition from SET to RESET!
    [latest-23078]2023-03-26T22:31:41.354Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:41.355Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:41.356Z <Engine:INFO> Enqueueing "Door Sensors State<RESET>" (rule-lerjv6if:R)
    [latest-23078]2023-03-26T22:31:41.357Z <Engine:INFO> Enqueueing "Notification: Home Security - Garage side door just opened (Disarmed Only)<RESET>" (rule-lbmoup28:R)
    [latest-23078]2023-03-26T22:31:41.360Z <Engine:INFO> Enqueueing "Toggle Vestibule scene 003 LED color state between green/blue<RESET>" (rule-lfn441bq:R)
    [latest-23078]2023-03-26T22:31:41.361Z <Engine:NOTICE> Starting reaction Door Sensors State<RESET> (rule-lerjv6if:R)
    [latest-23078]2023-03-26T22:31:41.363Z <Engine:NOTICE> Starting reaction Notification: Home Security - Garage side door just opened (Disarmed Only)<RESET> (rule-lbmoup28:R)
    [latest-23078]2023-03-26T22:31:41.365Z <Engine:NOTICE> Starting reaction Toggle Vestibule scene 003 LED color state between green/blue<RESET> (rule-lfn441bq:R)
    [latest-23078]2023-03-26T22:31:41.366Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing zwave_device.set_config on Switch#zwavejs>128-0 with [Object]{ "parameter": "9", "size": 1, "value": 2, "bitmask": 0 }
    [latest-23078]2023-03-26T22:31:41.374Z <HassController:INFO> HassController#hass action x_hass_input_text.set_value([Object]{ "value": "Closed" }) on Entity#hass>input_text_h_door_sensors_state succeeded
    [latest-23078]2023-03-26T22:31:41.375Z <Engine:INFO> Resuming reaction Door Sensors State<RESET> (rule-lerjv6if:R) from step 1
    [latest-23078]2023-03-26T22:31:41.375Z <Engine:INFO> Door Sensors State<RESET> all actions completed.
    [latest-23078]2023-03-26T22:31:41.497Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_docker_hub
    [latest-23078]2023-03-26T22:31:41.498Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:41.498Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:41.499Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:41.501Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_docker_hub_update_available
    [latest-23078]2023-03-26T22:31:41.502Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:41.502Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:41.503Z <Rule:INFO> Notification: Update Available - Home Assistant (rule-lbmnmfds in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:41.709Z <Engine:INFO> Resuming reaction Toggle Vestibule scene 003 LED color state between green/blue<RESET> (rule-lfn441bq:R) from step 2
    [latest-23078]2023-03-26T22:31:41.709Z <Engine:INFO> Toggle Vestibule scene 003 LED color state between green/blue<RESET> all actions completed.
    [latest-23078]2023-03-26T22:31:49.669Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) starting evaluation; because entity-changed System#reactor_system>system
    [latest-23078]2023-03-26T22:31:49.670Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:49.670Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:49.670Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:49.675Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) starting evaluation; because entity-changed System#reactor_system>system
    [latest-23078]2023-03-26T22:31:49.675Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:49.676Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:49.676Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:49.678Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) starting evaluation; because entity-changed System#reactor_system>system
    [latest-23078]2023-03-26T22:31:49.679Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:49.679Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:49.680Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:49.682Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) starting evaluation; because entity-changed System#reactor_system>system
    [latest-23078]2023-03-26T22:31:49.683Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:49.683Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:49.683Z <Rule:INFO> Notification: Update Available - Reactor (rule-laeg075n in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:52.484Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_siren_siren_active_8
    [latest-23078]2023-03-26T22:31:52.485Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:52.485Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:52.486Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) starting evaluation; because entity-changed BinarySensor#hass>binary_sensor_garage_side_door_openclose_window_door_is_open
    [latest-23078]2023-03-26T22:31:52.502Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) trigger evaluation result is false (previously false)
    [latest-23078]2023-03-26T22:31:52.502Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-23078]2023-03-26T22:31:52.505Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:52.505Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:52.515Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:52.515Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:52.524Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:52.525Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:52.537Z <Rule:INFO> Notification: Home Security - Open/close water main shut-off valve (rule-kvo8us5v in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:52.538Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:52.538Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) starting evaluation; because data-changed Data#states:cs-rule-lfn41thm
    [latest-23078]2023-03-26T22:31:52.538Z <Rule:INFO> Any door open? (rule-lfn41thm in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:52.538Z <Rule:INFO> Door Sensors State (rule-lerjv6if in Control Room) evaluation complete
    [latest-23078]2023-03-26T22:31:52.539Z <Rule:INFO> Notification: Home Security - Garage side door just opened (Disarmed Only) (rule-lbmoup28 in Notifications) evaluation complete
    [latest-23078]2023-03-26T22:31:52.540Z <HassController:INFO> HassController#hass action x_hass_siren.turn_off([Object]{  }) on Entity#hass>siren_siren_8 succeeded
    [latest-23078]2023-03-26T22:31:52.541Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:52.542Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) constraints not met!
    [latest-23078]2023-03-26T22:31:52.542Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluated; trigger state changed (true), but rule state remains RESET
    [latest-23078]2023-03-26T22:31:52.544Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) trigger evaluation result is true (previously false)
    [latest-23078]2023-03-26T22:31:52.544Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluated; rule state transition from RESET to SET!
    [latest-23078]2023-03-26T22:31:52.551Z <Rule:INFO> Alarm triggered (rule-lbqu752y in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:52.552Z <Rule:INFO> Toggle Vestibule scene 003 LED color state between green/blue (rule-lfn441bq in Home Security) evaluation complete
    [latest-23078]2023-03-26T22:31:52.565Z <Engine:NOTICE> [Engine]Engine#1 entry 171 reaction rule-lbmoup28:R: [Error] terminated [-]
    [latest-23078]2023-03-26T22:31:52.565Z <Engine:CRIT> Error: terminated [-]
    Error: terminated
        at Engine._process_reaction_queue (/opt/reactor/server/lib/Engine.js:1555:47)
        at runMicrotasks (<anonymous>)
      Please re-read the posting guidelines and fix your post. When posting log snippets, you are asked to post several dozen lines of context before any error message you are inquiring about.
        OK, I see you edited the post. Is your question about the error message, or something else. You said you had a question, but you didn't state what the question is (i.e. described your expected behavior vs your observed behavior). Also, it would be helpful to know the name of the rule you have posted.
        • SnowmanS Offline
          SnowmanS Offline
          Snowman
          My question is about the error message. The name of the rule is : Notification: Home Security - Garage side door just opened (Disarmed Only).
          My expectation is that there should not be an error.
          The error seems to happen on the RESET of the rule and based on previous entries in the log, it should probably have read something like this, but that is just a guess.
            Reactor for Vera and Multi-hub Reactor both do this thing I call preemption of counter-activities, where (using MSR as the example) if the SET reaction needs to run, any running RESET reaction for the same rule is first stopped, and vice-versa. This prevents the two opposing reactions from fighting with one another for control of a device if one happens to still be running when the other needs to run.
            The "terminated" message logged here is for RESET reaction of rule rule-lbmoup28, which is "Home Security - Garage side door just opened (Disarmed Only)" in the Notifications rule set. That reaction was started at 22:31:41.357Z in the log. The first action executes immediately. Just 11 seconds later at 22:31:52.486Z, the rule was re-evaluated because the door sensor changed state again, this time going to SET state, which would then start the counter-activity (SET reaction). The "terminated" message for the RESET reaction was logged because the reaction was still enqueued/running at that time.
            The RESET reaction is pretty simple, so it may be that Home Assistant is having difficulty communicating reliably with the device. The 10-11 second gap between the start of the RESET reaction and its preemption by the SET reaction that followed is well within the timeout period (15 seconds) for HA to respond to HassController request to execute the action. The completion of the action occurred at 22:31:52.540Z, which is quite a long time for a simple action. The RESET reaction wasn't marked complete in that instant because the wait for completion is asynchronous, and there wasn't sufficient time for the executive to regain control and the reaction to be selected from the task queue (at which time it would have been marked complete and removed from the queue) -- the evaluation of the rule and change to SET had completed before HA responded to say it was finished.
            On the plus side, the turn off action was completed, so the termination was benign, coming after the last action in the reaction.
            On the minus side, it looks like you need to dig in and figure out why it took 11 seconds for HA to turn around one simple message with that siren. Assuming that's a ZWave device, you might look at the mesh performance and diagnostics in ZWaveJS UI.
            • SnowmanS Offline
              SnowmanS Offline
              Snowman
              Thanks Patrick. I clearly understand your explanation and I thank you for that. It makes sense and it explains what I was observing with my alarm system yesterday during my testings. I could see a lag when opening a door but never made the connection with what was in the log.
              Today, I have started to exclude and re-include those door sensors w/o security to see if the response is better because I am thinking S2 security might be the reason of the lag.
                S2 is a wrinkle and sore point for many manufacturers. But, the log isn't really pointing to the door sensors as the problem, it seems more likely from the log data that it's the siren. From personal experience with two popular brands, they are very battery-sensitive, and they need to have any firmware updates available installed. The battery issue with one brand is very interesting... if the batteries are around 60%, the operation of the siren at full volume appears to cause a significant enough battery drain that the device drops off the mesh briefly. It will keep wailing away uninterrupted, you just can't talk to it. As it is, the batteries last less than 60 days in my use, which basically amounts to a simple chime that repeats once every 5 minutes while either garage door is open (so maybe just 4-5 chimes on an average day for us). That's ridiculous. So far, I haven't found a Z-Wave siren I like, and most of my notifications are by Pushover and through Sonos.
                SnowmanS 1 Reply Last reply
                  SnowmanS Offline
                  SnowmanS Offline
                  Snowman
                  Thanks @toggledbits
                  Quick update. I have excluded and re-included about 12 S2 devices to no security. I do not have a tool to measure the response time for my alarm system (door sensors, motion, scene controller, and siren), for example, but from I have seen today (tomorrow is another day), response is almost immediate. S2 the issue?
                  My only problem right now is pairing two Zooz ZSE41 sensors. One of them being the garage side door sensor. On the latter, at your suggestion, I noticed this in Z-Wave JS UI which may explained to lag.
                  Those sensors simply won't pair anymore even after factory reset. I am in discussion with Zooz support.
                  BTW my Aeotec Siren 6 works on AC (plus a battery as back-up).
                  • SnowmanS Offline
                    SnowmanS Offline
                    Snowman
                    I finally found the problem after a lot of troubleshooting. Patrick guided me to possibly an issue with the Siren but couldn't figure out, until, I realized that the 2-second tone duration I configured for siren 8 was likely the reason I saw those errors.
                    If you look at my original screenshot, I was turning off the siren under the Reset Reaction but the siren had already stopped beeping under the Set Reaction. At least I like to believe it did since it only lasted 2 seconds.
                    All I did is remove the Reset Reaction. See below. That did the trick for me. No more "Terminated" errors.
                    • Self test
                    • Possible feature request 2?
                      83.9k
