  2. Hardware
  3. Water level sensor
Hardware
Shelly Wall Display XL
Hardware
Hardware
DIY HomeKey locks via Reactor
Hardware
A recent thread on supporting the ZRC-90 Z-Wave scene controller got me to wonder, what does everybody use and like? I'll start... oh, and no dashboards. I want to hear from you all about dedicated scene controller devices. Dashboards and apps are great to a point, but my experience is that higher WAF is achieved with (a) a dedicated device (b) in a known location (c) with predictable functions and (d) no extra steps to operate (just walk up to it and push a button -- same effort as a light switch/dimmer). She's not wrong. It's a pain to unlock the phone, find the app, open the app, find the device, tap the device, when you can just walk across the room and push a button. Bonus points for something that can be labeled readably (low WAF for stuck-on tape/thermal labels). I have a ZRC-90 and it's great, but it was temperamental to get working on Vera, and wasn't smooth sailing when it made the move to Z-Wave JS either. A couple of include/exclude cycles were needed to get it fully working on both. Since then, I've done a battery change, and while the buttons work as reliably as ever, the device continues to report the old battery level despite having a measurably fresh battery for over a year now. But I would still recommend it. I have a Hank 4-button that is probably the best and most reliable battery-operated scene controller I have ever used. It's small and unobtrusive, so it lives on a lamp base in our living room and controls the room's mood lighting. I'm not sure they're still available. RIP. I just ran across the Minoston MR40Z on Amazon, and I may try one of those. It looks like an installed (in-wall) Decora switch, but the buttons are actually a removable remote that you can pull off the wall and take to the couch. No line power required. Kinda cool. Maybe a good Hank replacement. But, I've never heard of this manufacturer before, and the concern is always "will I be able to buy more/replacements in one/two/five years?" Among the wired controllers, the Zooz ZEN32 seems to be the most popular modern unit. I like it, but the LEDs are too small for my aging eyes to discern their color in daylight -- they are pin-head sized. Four of the five buttons are too small to label, so low WAF. When I started my Z-Wave network, I used the Leviton four-button scene/zone controllers (VRCS4 and VRCZ4), and these are still all over my house. They're glitchy first-gen Z-Wave stuff (Vizia RF+ actually, so compatible but with proprietary features that aren't usable). They're now discontinued for Z-Wave. Leviton's newer units are WiFi, so if I go that route, it's HomeKit via Home Assistant for those. During the pandemic lock-downs, I built a touch-screen scene controller using an Adafruit PyPortal. It had screens with 1 to 8 labeled, colorable soft buttons that could either perform a device function (i.e. publish to MQTT) or take you to another screen, so it was the love-child of scene controller and dashboard. Wife found it agreeable. But it was just a prototype. Memory limitation of the device was an issue because the PyPortal is really an inexpensive teaching device with a big load of Circuit Python overhead, and the graphic display needs a lot of RAM, so it was severely limited. I'm sure it could work out with the right micro and programming closer to the bare metal. Packaging and powering would also need to be addressed. And, at the end of the day, while "cute," it doesn't seem like something I would want to sell with the house if we ended up moving some day. So, I'm interested in what others are doing and using, or more specifically, what your significant others are comfortable with and willing to use.
Hardware
O
Hardware
Z
Hardware
Hardware
LEDVANCE
O
Hardware
Water Flow Meter & Shutoff
B
Hardware
Hardware
Remote light switch
Hardware
ESP32 / ESP8266
Hardware
Hardware
Hardware
PerHP
After a long wait for an updated version of the rather crude and unfinished Z-Way integration to HASS, i'm now looking (reluctantly) in to replacing Z-Way with Z-wave JS.. Mind you this is a big existing network, not a new controller stick.. I threw up a docker for z-wave JS UI, and tried to connect it to the UZB stick.. It loads the whole network from the stick, but the driver keeps restarting? Looking at the logs, I see a lot of Dropping message because the driver is not ready to handle it yet. It seems like the stick just keeps talking like z-way was still listening? This ends up in the driver crashing repeatedly.. Any ideas to how I can get them talking? In the code snippet below, you see the driver restarting with the graphic letters, seemingly while the stick is mid-sentence, or because of ACK timeout... 2022-10-02T19:19:59.664Z CNTRLR received additional controller information: Z-Wave API version: 6 (legacy) Z-Wave chip type: ZW050x node type Controller controller role: primary controller is the SIS: true controller supports timers: false nodes in the network: 1, 5, 6, 10, 11, 12, 13, 14, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 32, 33, 34, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 4 7, 48, 52, 55, 69, 70, 71, 73, 74, 75, 77, 78, 79, 81, 82, 83 2022-10-02T19:19:59.765Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated 2022-10-02T19:19:59.766Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated 2022-10-02T19:19:59.767Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated 2022-10-02T19:19:59.768Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 277 2022-10-02T19:19:59.769Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 1 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated 2022-10-02T19:19:59.771Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.39 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [+] [Version] sdkVersion: "6.9.0" 2022-10-02T19:19:59.772Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms 2022-10-02T19:19:59.792Z SERIAL » 0x01050006640f97 (7 bytes) 2022-10-02T19:19:59.792Z DRIVER » [REQ] [SetSerialApiTimeouts] payload: 0x640f 2022-10-02T19:19:59.815Z SERIAL « [ACK] (0x06) 2022-10-02T19:19:59.816Z SERIAL « 0x01050106640f96 (7 bytes) 2022-10-02T19:19:59.817Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.177Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:03.178Z DRIVER version 10.2.0 2022-10-02T19:21:03.179Z DRIVER 2022-10-02T19:21:03.179Z DRIVER starting driver... 2022-10-02T19:21:03.199Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:03.212Z DRIVER serial port opened 2022-10-02T19:21:03.213Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:03.229Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.232Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.233Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.234Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.261Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.273Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.274Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.274Z DRIVER loading configuration... 2022-10-02T19:21:03.298Z CONFIG Using external configuration dir /usr/src/app/store/.config-db 2022-10-02T19:21:03.298Z CONFIG version 10.2.0 2022-10-02T19:21:04.284Z DRIVER beginning interview... 2022-10-02T19:21:04.286Z DRIVER added request handler for AddNodeToNetwork (0x4a)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for ReplaceFailedNode (0x63)... 1 registered 2022-10-02T19:21:04.287Z CNTRLR querying controller IDs... 2022-10-02T19:21:04.484Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:04.485Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:04.487Z SERIAL « 0x0123000400511a9f039900b834787d066515a4b79c45bb3af55ea7f6203006010 (37 bytes) 80120c84d 2022-10-02T19:21:04.489Z SERIAL « [DISCARDED] invalid data 0x9ef4 (2 bytes) 2022-10-02T19:21:04.490Z DRIVER Dropping message because it contains invalid data 2022-10-02T19:21:04.490Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:05.488Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i n 100 ms. 2022-10-02T19:21:05.591Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:05.592Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:06.596Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i n 1100 ms. 2022-10-02T19:21:07.698Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:07.699Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:08.717Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D river.ts:3980:23) at ZWaveController.identify (/usr/src/app/node_modules/zwave-js/src/lib/co ntroller/Controller.ts:713:33) at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js /src/lib/driver/Driver.ts:1207:26) at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive r/Driver.ts:1014:16) 2022-10-02T19:21:08.723Z DRIVER destroying driver instance... 2022-10-02T19:21:08.728Z DRIVER driver instance destroyed 2022-10-02T19:21:08.739Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:08.740Z DRIVER version 10.2.0 2022-10-02T19:21:08.740Z DRIVER 2022-10-02T19:21:08.740Z DRIVER starting driver... 2022-10-02T19:21:08.745Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:08.751Z DRIVER serial port opened 2022-10-02T19:21:08.752Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:08.754Z DRIVER loading configuration... 2022-10-02T19:21:08.755Z SERIAL « 0x01080120c84d9ef40138 (10 bytes) 2022-10-02T19:21:08.757Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:08.758Z DRIVER « [RES] [GetControllerId]
Hardware
Hardware
Hardware
Hardware
Hardware
Water level sensor
26 Posts 9 Posters 12.5k Views 8 Watching
    A pressure sensor in the bottom would be a good solution.
    What is used in car fuel tanks?
    @akbooer said in Water level sensor:
    Usually it's a float with a rod, actuating a potentiometer. (variable resistor)
    Not sure about the pressure sensor as it depends on the shape of the tank (how deep the tank is) and it will be exposed to atmospheric pressure variations. The advantage of the ultrasonic one is that it is non contact and won't grow stuff in the water.
      @rafale77 said in Water level sensor:
      This
      • propheadP Offline
        propheadP Offline
        prophead
        Two (high and low)of these(bare wire):
        274 CAD
        The Parrot ATO System
        The Parrot ATO system Intelligent, observant, long lived, colorful and always repetitive, the Parrot will be the companion you won't know how you lived without. Along with the fun new name comes the pedigree of a proven winner. How do you make improvements to the ATO with an unrivaled reputation...
        And two of these:
        Ecolink Intelligent Technology Z-Wave Easy Install, Battery Operated, Door/Window Sensor, White & Brown (DWZWAVE2-ECO) https://www.amazon.com/dp/B00HPIYJWU/ref=cm_sw_r_cp_api_i_3Je6Eb7ECMY2V
        And bob’s your uncle
          I like to keep thing simple so i would go with a float switch.
          One other thing in the UK we do not store drinking water, the only water storage in the uk is for filling baths and toilets. Do you intend to attach this tank to your drinking water pipes/tapes?
          • A ArcherS
            One option would be to use MySensors. This is a cheap way of adding various Arduino sensors to OpenLuup. You set up an Ethernet gateway and then each sensor is connected to the gateway wirelessly. There is a MySensors plugin that works in OpenLuup.
            This looks like an interesting project, that you perhaps can get inspiration from: Round water tank level sensor
            Good luck!
            @ArcherS thanks for the input. I have various WiFi devices around the house, so I’ll probably add another one. I’ll go with MQTT, since I have a bridge to Vera I use to bridge other devices (tasmota, Sonoff, my own).
            Thanks anyone for the suggestion. Now to find some pre built device template to borrow.
            • ElcidE Elcid
              @Elcid yep, it’s allowed to drink, via chemicals to be added every now and then. I successfully intercepted the alert the public water company is dispatching, so maybe I can empty/fill on demand.
              I was exploring a UV based solution too, but I want to start easy. I will probably add this and automate everything in the future.
                wrote on last edited by Elcid
                Ok just thought i would bring up the health risks, advice i read is its best to limit the tank size for drinking so the water does not sit for long and is replaced regularly. You sound like you know what you are doing. good luck
                  that's correct. the water needs to be refreshed often and never stay in the tank (if you're not correcting it with chemicals - that's a small capsule intended for drinking water consumption).
                  since it's hot here during the summer and the water pipes are public, there's a lot of leaks and the water is never enough (to be honest, I'm living in a zone with lots of water, but we're exporting to neighbor regions as well). so, this kind of implant is very common, from houses to restaurants, etc.
                  these thanks are UV resistant, can handle -40/+60° C and is algae/mold proof. they're specifically intended for drinking water.
                  my house implants were already done when I bought it, so I had to use the current configuration, but it's becoming common to separate toilets pipe/garden pipes and use rain or a pump to get non-drink water. I guess you can make it more complex if you want, as with everything 🙂
                    Best to shade tank from sun and keep it as cool as possible to, even if the tank is uv proof, the cooler the water the better.
                    • ElcidE Elcid
                      @Elcid it’s inside the house. I think it’s mandatory for drink water.
                      • propheadP Offline
                        propheadP Offline
                        prophead
                        Float valves fail. Regularly. Pressure switch has no moving parts and has been significantly more reliable for me.
                          So, after consulting with a friend into NodeMCU, I'm going for
                          • NodeMCU esp8266 (flashed with Tasmota, so MQTT)
                          • JSN-SR04T Waterproof Ultranosic Distance sensor
                          HC-SR04 ultrasonic ranging sensor - Tasmota
                          I will probably write a MQTT to openluup bridge, if time allows. I'm getting a couple from Amazon, and tons from AliExpress for further projects. I will probably consolidate my weather station and place a couple of addition temperature sensors across the house.
                          I'll probably order other sensors, just to experiment.
                          • propheadP Offline
                            propheadP Offline
                            prophead
                            Keep us posted. I’m very interested in this.
                            • propheadP prophead
                              @prophead since I'm not that good into soldering, I always choose plug&play projects 😄
                              I already have a couple of Tasmota devices: one to monitor temperature in my pool and one for humidity in my open space, to trigger a dehumidifier (large windows, helpful during the winter) and they're quite plug&play, after you've flashed Tasmota.
                              You can poll data easily, thanks to their API (I developed my virtual devices plug-in for this) or integrate real-time change notification with MQTT, or use both. I have MQTT with a custom C# app bridging to virtual devices.
                              The only problem is they are Wi-Fi based, so I don't want to have too many, because I really prefer Z-Wave and its mesh topology. But they're cheap and can be integrated with every sensor on the planet, quite easily.
                              I'll probably build a prototype next week and I'll report back.
                                Matteburk
                                I am building a infinityppool to a customer and I use a Pressure-type level sensor #12086 https://www.youtube.com/watch?v=DCe_wYQ_BC0
                                admin
                                ASIN AQUA Home en - Aseko Pool Technology
                                DOSING Systems CONTROL Systems Aseko PROBES DOSING Pumps ASIN AQUA Home POOL WATER TREATMENT & POOL TECHNOLOGY MANAGEMENT ASIN AQUA Home The luxury unit with most advanced water treatment features and intelligent system control functions. Exclusive stainless-steel case with peristaltic pumps....
                                  sender
                                  Might you already know. But D1 mini flashed with tasmotizer and running mqtt runs like hell! Very reliable! Only thing is now it is running over WiFi...
                                  • propheadP Offline
                                    propheadP Offline
                                    prophead
                                    How do you intend to mount your sensor?
                                      @prophead said in Water level sensor:
                                      The sensor has a long cable, so I plan to just drill on the tank cover and run the cable into an outdoor-like box, where the board will be placed.
                                      Same for the pool, but I'll place it inside the skimmer. I will build a prototype and see if it fits, then build the final ones.
                                        So, I'm ready with the first prototype. The device was flashed with Tasmota, then I connected the sensor. I had to try a couple of different things, but if you have a device like mine, 5V output is on VU/VV. Anyway, I bridged to my Vera using a virtual device (generic sensor) and pushing its value from my MQTT broker to Vera (and then openluup via the VeraBridge). I still have to write a virtual device to get the amount of water, but the tank is not ready yet, so raw values are OK for now. I'll probably hook a temp/humidity sensor and then mount in a definitive box. Happy to help if anyone wants more instructions.
                                          Just curious, why not go straight to openLuup instead of going through the vera?
                                            156.0k
