  4. [SOLVED] Sprinkler control: one or both of two conditions to prevent watering
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
HA 2025.9.4 Supported Yet?
Rule Set UI bug - RESOLVED
[Reactor] Copy&Paste of Rules
[Reactor] Help with scene controller cycling logic
solved
10 Posts 2 Posters 998 Views 2 Watching
    I think I'm just staring at this too hard so I'm opening up to the collective.
    Scenario: water the gardens at XX time unless one or both of the following are TRUE:
    • More than .25" of rain has fallen yesterday (I have an entity for this)
    • It is currently raining (I have an entity for this)
    I had it set to OR and that (obviously) doesn't work because, whilst first bullet was TRUE second bullet was FALSE and so the water flowed.
    I'm thinking, atm, of something using Reaction>Group and building out something that isolates the conditions vs making them an OR.
    Am I on the right path here?
    *Hubitat C-7 2.4.3.149
    *HASS 2025.11.1
    w/ ZST10-700 fw 7.18.3
    MSR: latest-25310-dc2bb580
      In staring even harder I came up with this:
      Since image functionality is STILL BROKEN on this forum (but, oh, it LOOKS pretty)...
      Triggers not or
      Comment: This is a NOT rule. If either of these conditions are NOT true then this rule is FALSE. (If the rainfall total either yesterday or today is more than 1/4" then FALSE).
      Entity Attribute: Weatherflow Precipitation Yesterday (hass>sensor_weatherflow_precipitation_yesterday) value_sensor.value <= 0.25
      OR Entity Attribute: Weatherflow Precipitation Today (hass>sensor_weatherflow_precipitation_today) value_sensor.value <= 0.25
      Currently, there was 1.61" of rain yesterday so the outcome is false and there has been no rain today so that outcome is true - as such the ruleset is rendered false.
      Is my thinking sound here?
      *HASS 2025.11.1
        So basically the way you have your rule structured right now is that the group will go true either when it rains more than 0.25" or its currently raining. Which is the opposite of what you'd want. As you mentioned in your recent post switching this to a not or operator should fix it. Meaning the group will be true if it hasn't rained more than 0.25" yesterday or is currently raining.
          @Pabla Thanks!
          I altered the premise very slightly to be rain amounts on both days because, hey, it might be actually raining right then but it might be a very slight passing shower which doesn't end up providing the needed water amount.
          The updated version looks at amounts on both days, instead.
          *HASS 2025.11.1
          PablaP 1 Reply Last reply
            @Pabla Thanks!
            @gwp1 Excellent! Regardless of condition the not operator should do the trick
              @Pabla Hmmm. We've had a sudden storm that has dropped 2" of rain today. As such both Conditions are now false and then ruleset has gone SET.
              SO... testing, when I flip the criteria of the Conditions to >= .25 both go true and the ruleset goes false.
              I did a quick test and, yes, it appears by bumping one of the two Conditions to be silly high like 5" (so today's actual is less than that) it makes one Condition true and one false and the ruleset remains as unset. Bumping both to be silly high (so both actuals are less than that) makes the ruleset toggle to SET which is the desired outcome. Any or both of the Conditions being TRUE toggles the ruleset unset. Both conditions being false toggles the ruleset TRUE.
              The expectation is that tomorrow morning there will be no flow of water as at least today's Condition is true so no matter what tomorrow's is (between midnight and 0600 ET) this ruleset will not SET.
              *HASS 2025.11.1
                @gwp1 I am not sure I am quite following. Are you saying that when both conditions: Rain amount yesterday and Rain amount today are true (meaning a certain amount of rain has fallen either yesterday or today) that the ruleset still goes true and waters the garden?
                  @Pabla
                  @gwp1 said in [SOLVED] Sprinkler control: one or both of two conditions to prevent watering:
                  So the settings are as such now:
                  Triggers [not or]
                  Entity Attribute: Weatherflow Precipitation Yesterday (hass>sensor_weatherflow_precipitation_yesterday) value_sensor.value >= 0.25
                  OR Entity Attribute: Weatherflow Precipitation Today (hass>sensor_weatherflow_precipitation_today) value_sensor.value >= 0.25
                  Right now the first one is true and the second is false. As such, the rule is RESET. Unless we get rain between now and tomorrow morning, the "yesterday" will roll off and "today" will become "yesterday" and both Conditions will be be false and the rule will change to SET and the water will flow.
                  *HASS 2025.11.1
                    Ah I see but isn't that what you'd expect? Say yesterday you got over 0.25 (inches?) of rain and today you got 0.23. This would mean your garden will not be watered.
                    Lets say no rain falls between today and tomorrow. That means when tomorrow rolls over yesterdays rain total now becomes 0.23 and todays is 0. Based on that info you'd want your garden to be watered.
                    To me the ruleset is working as intended, if you still wouldn't want it to water I would set your "todays" threshold a little lower.
                      @Pabla The original Conditions were <= .25 whereas the working version had to be flipped to >= .25. That's what ultimately made it work.
                      *HASS 2025.11.1
                        73.0k
                        323
                      • Shelly Wall Display XL
                      • [Solved] alarm() in global expression throws error in log.
                        561
                      • [Solved] Define function issue in latest-25304
                      • No Upgrade Notification for Build 25308?
