  3. MIOS down
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
MIOS down
17 Posts 4 Posters 1.8k Views 4 Watching
    Oh dear oh dear oh dear.
    Cloud dead. No one noticed 😄
      They're doing maintenance, as they wrote on their forum.
        @therealdb said in MIOS down:
        Where?
          sender
          There used to be a service uptime status page but that seems silently vanished.
            Oh no it's still there. Claiming everything is hunky dory.
            Just got an email saying it was due to maintenance:
            Early this morning we pushed an update to our cloud server, but unfortunately, this update took longer than expected to deploy and has resulted in you being unable to access your systems or control your homes.
            Which no one knew about (it seems apart from @therealdb ) including the guy that runs support. 😉
              sender
              Dear Vera Customers,
              We understand the responsibility that comes with putting our systems in your homes and apologize for the inconvenience this has caused many of you. The system should be up and running shortly, though due to the number of users trying to reconnect, access may be delayed a bit further.
              Please note: during the update, the system was returning an incorrect username or password error, but you do not need to update either of these. Once the system is back online your usual username and password will work as normal.
              Again, we apologize for the inconvenience and appreciate you being a loyal Vera customer.
              Regards,
              Mark Samuel
              CEO, Ezlo Innovation
                Yep. Same email here.
                Personally not buying for a second.
                  Cloudless FTW! People need to go back to what was the real purpose and benefit from the cloud and stop moving applications there because they can. I see this in the corporate world as well... The cloud's benefit is sharing and offloading things you can't do at home due to lack of processing power. This in no way applies to home automation which needs and certainly wants no sharing and even less requires the processing power to justify the power needed, the reliability/performance loss and the security liability to send your data into the wild.
                  On related note, their cloud is of the same quality as their products!! I just got an ezlo Atom 2 beta in the mail a couple of days ago in spite of having sent them an email not to send this to me as it would just add to my pile of garbage. Well it is here and completely scratched up looking like it got pulled from the ocean. It went straight to the trash can. The atom concept itself is self defeating and I fail to understand any sort of application for it besides adding RF interference and latency to any home setup. It is a product designed from gross ignorance about RF, zwave and home automation...
                    @rafale77 said in MIOS down:
                    No argument from me.
                    Terrible operational awareness as well. Private conversations blame C19 because the teams are working from home.
                    I guess it sounds like I'm kicking them for the hell of it, but blimey, it's what, 2 years since the take over? This is basic basic stuff.
                    What I see being reported as issues with Ezlo testing seems they have a very very long way to go before that's ready for prime time as well.
                    When will we get voice control for OpenLuup? 😉
                      Alright having to run to a meeting but... Right now my openLuup voice control is through alexa which is cloud dependent for the voice processing but my failover is... siri on my phone and laptop which is local...
                        Without UI7? Your ideas (continue) to interest me....
                          yeah you know I dumped UI7 for a few months now. I dumped the mios cloud for well over a year. I have been using local bridges to Homekit and Alexa for about 5 years!
                            Well, when you get a chance 😉
                              https://smarthome.community/topic/41/voice-control-and-tts-projects
                              All running on the same machine as z-way and openLuup. (a VM running on a single thread of my quad core 8 thread NAS)
                              Note that these provide much better control over what gets discovered and how they behave vs the cloud hosted solution. I can do a lot of things the cloud solution could not... in terms of action and device controlled.
                                Well I always got as far as Hue and stopped! Idiot.
                                Right I need to start some kind of migration.
                                Reckon it'll all work on a Pi4? Or an oldish NUC?
                                  Yes it would work on a rPi3 even or in my case I ran it for a long time on a celeron. It does't really exercise anything on the CPU:
                                  z-way server occupies ~5%, openLuup (which is massive... over 300 devices and 200 scenes now) only takes 3% ALTUI spikes another 3% at the most with my latest discovery of rapidjson, and these bridges all take less than 0.5% together. RAM required: 500MB. Honestly I could almost run it on the vera plus if I could compile all these for ramips. This supports my point about not needing a very powerful CPU for processing but we need to pay attention to the I/O bandwidth and network capacity/cpu storage reliability. Complete opposite of the ezlo plus which upgrades what doesn't matter and downgrades what is important vs the vera.
                                  If you do want to expand later into the video realm though at this point I would recommend the nVidia Jetson Nano...
                                  which is equivalent to rPi4 with a GPU.
                                    Hmmmm
                                    So I think I'll start a thread of my migration to hopefully document / encourage! Thanks!
                                    • Oh the joy of pairing
                                    • HDMI oddness
                                      668
                                      sethlampman
                                    • Date/time condition
