  3. Smart bed sensor
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Smart bed sensor
15 Posts 8 Posters 3.0k Views 8 Watching
  • C Offline
    C Offline
    Christer
    • wmarcolinW Offline
      It would be great to have such a sensor. Today I do this work with pressure strips on the mattress, but it gives a huge maintenance because the movement of the body breaks the strip or the connection cables. The doubt I have is how would be controlled the personnel on the sensor? I mean, would the very weight of the bed induce someone to be on top of it? Besides, there are beds that have several feet, I imagine that the sensor does not have to be placed on all of them, there should be some that are just supports at the same height as the main sensor. In summary I do not think the idea is bad, but we still have to think a lot about how to make it a reality and test it. Good luck.
      • B Offline
        B Offline
        basai
        I think this would be an interesting sensor to have. I’m guessing you are sensing pressure / weight and returning a numeric value based on that vs a simple open / close. The reason being you is that you would need a base (empty bed) value in order to make decisions whether someone / thing is in bed or not or how many are in bed for that matter. The second reason is that beds have different numbers of legs depending on the type of bed and therefore weight distribution comes into the picture, so sensing pressure or weight vs open / close seems like it would give you more options and even interest from other markets.
        Meaning, if this is a pressure / weight type sensor it could have other applications as well expanding your market. For example, I have a salt tank that holds a few hundred pounds of salt for my water treatment system. I could record the initial numeric values at different levels and use that information to know when it is low and needs more salt. I would be interested in doing that.
        Just my $.02
        Take care and good luck.
        -bh
        • C Offline
          C Offline
          Christer
          Thanks for your comments! The idea is to use at least 2 of them @wmarcolin so that the bed is stable. I guess the other type is where you don´t have any legs and that should still be fine to use two of them on one end of the bed.
          The sensors will detect the difference in pressure when you are in the bed compared to when you are not, so it will adapt quickly to the bed you are using. Large dogs might trigger false positives but we believe we can make it reliable enough for most situations.
          Great alternative use case @basai. In that case sounds like you would need the raw values. The first version will not be as accurate as a scale but might be accurate enough for your application. Let me think about it..
          If you are interested to try it out please send us an email and we will come back to you when it is ready - smartfurniturepads@gmail.com
            theabraham90
            wrote on last edited by theabraham90
            This smart device could have some useful benefits like enegry savings, convenience and safety (e.g for elderly care); that said, this technology can be developed more in order to track sleeps to determine sleeping patterns which can be useful in many ways.
            On the other hand, it's got its own drawbacks, e.g relying on the bed sensor to control multiple smart home devices could lead to inconveniences if the sensor malfunctions or experiences connectivity issues. Also it might cost a lot and be expensive
              Interesting. If you have a bed like mine without legs, I don't think you'd get away with only two sensors. The bed would be on a slant so perhaps a set of 1 active sensor and 3 dummies to keep things level.
              Two other thoughts:
              Battery change? Bit of a pain to pick the bed up, or indeed plug it in. So I think long battery life would be a big ticket item
              Also you've got (likely) 4 possible states:
              Empty
              Occupant 1
              Occupant 2
              Occupant 1 + Occupant 2
              Just random thoughts
                Two other thoughts:
                Empty
                Occupant 1
                Occupant 2
                @CatmanV2 said in Smart bed sensor:
                HA! Vera abuser or abused by Vera? I know I felt abused when I switched to Home Assistant just about a year ago.
                • C Christer
                  @Christer said in Smart bed sensor:
                  I agree with @wmarcolin's assessment that there would need to be dummy sensors of the same height, so that the bed wouldn't be off balance.
                  I already have a "smart base" for my bed. In the application for my smart base, it monitors my sleep time, but there doesn't seem to be any sort of output for telling me when I'm actually in my bed. Someone developed a MQTT plugin for Home Assistant, so I can do somethings from HA, like change the incline, turn on/off the LED lighting, but nothing to tell me if someone is actually in the bed, which is disappointing. I would enjoy having that feature, so I can turn off lights, open blinds, etc, based upon the bed occupancy.
                  On a side note, I'd be curious how such a sensor would handle nocturnal activities! 🙂
                    I have an aquara fp2 sensor that I’m testing on my desk and I’ll soon deploy in the master bedroom. It’s mmWave and can detect up to five people in a room, with zones and status (standing, laying, walking). It should be more than enough to detect people sleeping.
                    Edit: fully and locally available in HA via HomeKit local.
                    PablaP CatmanV2C 2 Replies Last reply
                      @therealdb The zones sound interesting. So you have a zone set around your bed and if it detects someone there it considers that person laying down?
                        @Pabla yep, that’s the idea. I’ll have two zones to detect if it’s me or my wife.
                        If not in bed for 5 minutes after 7 am, consider us ready for the day and so on.
                        PablaP 1 Reply Last reply
                          @therealdb that's interesting and very useful, I have read about the FP2 and was impressed, didn't know it had the ability to create precise zones.. nice!
                          • T tamorgen
                            @tamorgen Abused by Ezlo!
                            I think HA rocks, personally 🙂
                              @therealdb How are you finding the FP2? Is it fast?
                                Yep. Still on my desk, tracking me when working from home. I’ll move it to the master bedroom in the next weeks. Too busy with work atm.
                                  89
                                  3.5k
                                  3.1k
                                  419
                                • Self test
