  3. Vera/openLuup plugins
  4. OpenSprinkler
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
B
B
Broadlink setup
Virtual Sensor Polling
B
Z
OpenSprinkler
43 Posts 3 Posters 17.9k Views 3 Watching
    looking at previous reply, it seems to differ from my responses, where station names are included. so strange...
      So, I finally, properly resolved the reload part. Version 1.4 is on GitHub, with a couple of other fixes (as the ability to have the children in the same room as the master, via the standard ChildrenSameRoom variable.
      @DesT, can you please test it? Your controller is giving different responses, so I'm interested in getting it supported. Thanks.
      • DesTD Offline
        DesTD Offline
        DesT
        yeah will try to update later today
        • DesTD Offline
          DesTD Offline
          DesT
          I upgraded this morning and I got this in the log
          2020-06-03 09:04:16.311   openLuup.scheduler:: [813] OpenSprinkler device startup
          2020-06-03 09:04:16.311   luup_log:813: VeraOpenSprinkler Controller Plug-In starting...
          2020-06-03 09:04:16.313   luup_log:813: VeraOpenSprinkler[1.4.0]: Plugin starting: "VeraOpenSprinkler" - "1.4.0"
          2020-06-03 09:04:16.313   luup_log:813: VeraOpenSprinkler[1.4.0](nil@707): Running on OpenLuup: true
          2020-06-03 09:04:16.314   luup_log:813: VeraOpenSprinkler[1.4.0](updateFromController@558): updateFromController started: true
          2020-06-03 09:04:16.314   luup_log:813: VeraOpenSprinkler[1.4.0](sendDeviceCommand@245): sendDeviceCommand("ja",nil,813)
          2020-06-03 09:04:16.314   luup_log:813: VeraOpenSprinkler[1.4.0](sendDeviceCommand@268): sendDeviceCommand - url: "http://10.99.99.16/ja?&pw=63df27a19d8f8c6669cc50ca042920cc"
          2020-06-03 09:04:16.317   luup_log:813: VeraOpenSprinkler[1.4.0](nil@191): HttpGet: "http://10.99.99.16/ja?&pw=63df27a19d8f8c6669cc50ca042920cc" - 1 - "200" - "{\"settings\":{\"devt\":1591175056,\"nbrd\":2,\"en\":1,\"sn1\":0,\"sn2\":0,\"rd\":0,\"rdst\":0,\"sunrise\":310,\"sunset\":1240,\"eip\":1167972197,\"lwc\":1591162809,\"lswc\":1591162809,\"lupt\":0,\"lrbtc\":99,\"lrun\":[3,4,600,1591155601],\"loc\":\"45.55855,-73.89608\",\"jsp\":\"https://ui.opensprinkler.com/js\",\"wsp\":\"weather.opensprinkler.com\",\"wto\":{\"key\":\"\"},\"ifkey\":\"\",\"wtdata\":{\"wp\":\"Manual\"},\"wterr\":0,\"sbits\":[128,0,0],\"ps\":[[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[1,24945,1591167601],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0],[0,0,0]]},\"programs\":{\"nprogs\":5,\"nboards\":2,\"mnp\":40,\"mnst\":4,\"pnsize\":32,\"pd\":[[65,127,0,[420,-1,-1,-1],[0,0,0,0,0,0,0,32400,0,0,0,0,0,0,0,0],\"Daily Cedars\"],[65,2,0,[180,-1,-1,-1],[0,1200,7200,900,0,0,0,0,0,0,0,0,0,0,0,0],\"St-Eustache Rules AM\"],[64,127,0,[1170,-1,-1,-1],[0,0,0,0,0,0,0,0,600,0,0,0,0,0,0,0],\"Daily Garden\"],[1,125,0,[180,0,0,0],[0,600,1200,600,0,0,0,0,0,0,0,0,0,0,0,0],\"Quick daily\"],[65,2,0,[1200,-1,-1,-1],[10800,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\"St-Eustache Rules PM\"]]},\"options\":{\"fwv\":219,\"tz\":32,\"hp0\":80,\"hp1\":0,\"hwv\":64,\"ext\":1,\"sdt\":0,\"mas\":0,\"mton\":0,\"mtof\":0,\"wl\":100,\"den\":1,\"ipas\":0,\"devid\":0,\"uwt\":0,\"ntp1\":50,\"ntp2\":97,\"ntp3\":210,\"ntp4\":169,\"lg\":1,\"mas2\":0,\"mton2\":0,\"mtof2\":0,\"fwm\":3,\"fpr0\":100,\"fpr1\":0,\"re\":0,\"sar\":1,\"ife\":0,\"sn1t\":1,\"sn1o\":0,\"sn1on\":0,\"sn1of\":0,\"wimod\":169,\"reset\":0,\"dexp\":-1,\"mexp\":24,\"hwt\":255},\"status\":{\"sn\":[0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0],\"nstations\":16}"
          2020-06-03 09:04:16.318   luup_log:813: VeraOpenSprinkler[1.4.0](updateStatus@443): Update status in progress...
          2020-06-03 09:04:16.318   luup_log:813: VeraOpenSprinkler[1.4.0](updateStatus@448): Controller status: 1, "1"
          2020-06-03 09:04:16.318   luup_log:813: VeraOpenSprinkler[1.4.0](setVar@120): setVar("urn:upnp-org:serviceId:SwitchPower1","Status","1",813) old value "1"
          2020-06-03 09:04:16.318   openLuup.context_switch::  ERROR: [dev #813] ./L_VeraOpenSprinkler1.lua:452: attempt to index local 'jsonResponse' (a nil value)
            your responses are different. I'm not sure that's because you have more than 8 stations. I will add a special support for this. It's strange that it's happening.
            All that said, v 1.4.1 is on GitHub. Just upoad L_VeraOpenSprinkler1.lua. This should prevent this kind of situation, I had the update before the device creation.
              @akbooer I found that, on some system, both Vera and openluup, the HTTP call gets a truncated response. but not every time. I'll switch to CURL to prevent this, but do you have an idea why it's happening? Thanks!
                anyway, @DesT , I published a new version using CURL instead of socket.http/ssl.https, if you want to try it and see if the json truncation is over (it should be). Thanks!
                  New version with a lot of fixes, sensors and disabled stations support. @DesT maybe give it a try 😉
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    Is there a place I can set the zone I would like to have exactly? I'm not using all the 16 zones and I would like to specify somewhere to only took 1,2,3,4,8,16 for example!
                      Not at the moment, but I think we can add this feature.
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        @therealdb When updating my code using your latest version, it make openLuup to crash with
                        Service XML root element name is not 'scpd'
                        • DesTD DesT
                          @dest very strange. I’m out at the moment, but I’ll take a look tomorrow.
                            This is a syntax check from the XML reader. Are you sure that you have specified the correct service/device files for the device?
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              I got this issue just after I upgraded my files from his repo....
                              • DesTD DesT
                                #42
                                @dest I've just tried to install it via AppStore on openLuup and it's working for me. AppStore is fetching files from GitHub, so I don't how to help you more, besides suggesting to try to update it again.
                                EDIT: SPC is coming from a Service file, but I'm just emulating lights here, so it's definitely coming from somewhere else. Can you please look at the complete logs (maybe startup logs)?
                                • DesTD Offline
                                  DesTD Offline
                                  DesT
                                  Yeah but I think I will delete my devices and recreate them from the AppStore... I was fetching manually your file from github since the beginning..
                                    152.5k
