  4. MSR with InfluxDB, filter unit from beeing send
3 Posts 2 Posters 898 Views 2 Watching
    mrFarmer
      mrFarmer
      I found that this works.
      value:
      include: true
      type: "number"
      skip_null: true
        Rene,
        You don't need all that, this should be sufficient:
              select_capabilities:
        or the equivalent, using an array of attribute names (my favorite):
                  attributes: [ 'value' ]
        or using the other YAML array syntax:
                    - value
        You can also use a negative to suppress an attribute:
                  attributes: [ '-units' ]
        Also, can I ask that you go back and fix the formatting of the code sections of your posts, for the benefit of future readers looking at your question and example solution?
          156.5k
