  4. Dark Mode not Working - 24293
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
13 Posts 3 Posters 2.4k Views 3 Watching
    wrote on last edited by Pabla
    Seems like switching the UI to the newly added dark mode (thank you for this) does nothing. The UI stays in light mode and only a few buttons turn into dark mode (see screenshot)
    Things I have tried:
    Hard refresh
    Different browser
    Different computer
    Restarting Reactor
    Failed troubleshooting attempts:
    No errors in Chrome console
    No relevant errors in Reactor log (can still PM the full log file)
    Reactor version: latest-24293-ea42a81d
    Hardware: Odroid N2+
    Linux version: Ubuntu 24.04.1 LTS
    3df2806f-9146-485b-9ec1-d056e91cefe5-image.png Dark mode enabled
    ff823023-c079-4684-b01f-d6ac6527d31a-image.png Light mode enabled
      OK. Check to make sure you've done all the npm updates/installed (see the warning in the release notes).
      Second issue is that dark mode on Ubuntu 24.04 is known to have issues (it's a platform issue, not a Reactor issue). Check from a browser running on another platform. This works for me on every browser I'm able to test, but Ubuntu Desktop isn't part of that. I can also see that at least one other user is successfully using dark mode.
        Bare metal or Docker?
          Bare metal.. forgot to add that
              Ha I obviously missed the first line in the release notes in my excitement for the dark mode.. also my update script also bit me in the ass here since it didn't run sudo npm i --no-save --no-package-lock --omit dev.
              All seems to be working well now, no more needing to use sunglasses when switching over to my Reactor tab 😉 .
              PS by stating my Linux version I was trying to show what version of Linux Reactor was running on and not the devices I was accessing the UI from.. so can't confirm that the UI shows correctly in Ubuntu
                @Pabla said in Dark Mode not Working - 24293:
                Outstanding. Love the easy ones!
                Got it. Couldn't really tell, so it was worth lobbing it over the fence to see if it got thrown back. In any case, thanks for clarifying, because I use that as a data point either way.
                  I'm getting the same issue even after running npm i --no-save --no-package-lock --omit dev, also tried npm run deps
                  Bare metal 24293 running on Ubuntu Server 22.04.5 LTS
                  Hard refreshed browser Chrome/Edge on Windows
                  What am I missing here?
                    Make sure you've hard-refreshed your browser after updating the packages. If you're still not getting dark mode, open your browser's console window (F12) and run the following commands exactly as shown:
                    1. $.fn.jquery — the browser should answer 3.7..1
                    2. $.ui.version — the browser should answer 1.14.0 (1.13.anything would be OK)
                    3. bootstrap.Tooltip.VERSION — the browser should answer 5.3.3
                      @toggledbits said in Dark Mode not Working - 24293:
                      Hm I'm getting 5.2.0 in both newly updated browsers.
                        OK. If you have a file called package-lock.json in the Reactor directory, remove it and run npm i --no-save --no-package-lock --omit dev again. Then do npm ls and see what version of Bootstrap is showing.
                          I can't find any package-lock.json and this is the output of npm ls
                          reactor-multi-system@1.3.0-24293 /home/homebridge/reactor
                          ├── @influxdata/influxdb-client@1.22.0
                          ├── @mdi/font@7.4.47
                          ├── @popperjs/core@2.11.6
                          ├── body-parser@1.20.1
                          ├── bootstrap-icons@1.11.3
                          ├── bootstrap@5.2.0
                          ├── digest-fetch@2.0.3
                          ├── diskusage-ng@1.0.2
                          ├── express@4.17.2
                          ├── feather-icons@4.28.0
                          ├── font-awesome@4.7.0
                          ├── gridstack@10.3.1
                          ├── jquery-ui@1.14.0
                          ├── jquery@3.7.1
                          ├── js-yaml@4.1.0
                          ├── node-fetch@2.6.7
                          ├── node-stream-zip@1.15.0
                          ├── nodemailer@6.8.0
                          ├── serve-static@1.15.0
                          ├── uuid@10.0.0
                          └── ws@7.5.9
                            OK. Edit your package.json file so that the dependencies line for bootstrap says ^5.3, and then run the npm i command (with all command line arguments previously given) again.
                              Yes, that did it! Thanks
                                100.8k
                              • Next Release?
