  4. Dark Mode not Working - 24293
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
13 Posts 3 Posters 2.8k Views 3 Watching
    wrote on last edited by Pabla
    Seems like switching the UI to the newly added dark mode (thank you for this) does nothing. The UI stays in light mode and only a few buttons turn into dark mode (see screenshot)
    Things I have tried:
    Hard refresh
    Different browser
    Different computer
    Restarting Reactor
    Failed troubleshooting attempts:
    No errors in Chrome console
    No relevant errors in Reactor log (can still PM the full log file)
    Reactor version: latest-24293-ea42a81d
    Hardware: Odroid N2+
    Linux version: Ubuntu 24.04.1 LTS
    3df2806f-9146-485b-9ec1-d056e91cefe5-image.png Dark mode enabled
    ff823023-c079-4684-b01f-d6ac6527d31a-image.png Light mode enabled
      OK. Check to make sure you've done all the npm updates/installed (see the warning in the release notes).
      Second issue is that dark mode on Ubuntu 24.04 is known to have issues (it's a platform issue, not a Reactor issue). Check from a browser running on another platform. This works for me on every browser I'm able to test, but Ubuntu Desktop isn't part of that. I can also see that at least one other user is successfully using dark mode.
        Bare metal or Docker?
          Bare metal.. forgot to add that
              Ha I obviously missed the first line in the release notes in my excitement for the dark mode.. also my update script also bit me in the ass here since it didn't run sudo npm i --no-save --no-package-lock --omit dev.
              All seems to be working well now, no more needing to use sunglasses when switching over to my Reactor tab 😉 .
              PS by stating my Linux version I was trying to show what version of Linux Reactor was running on and not the devices I was accessing the UI from.. so can't confirm that the UI shows correctly in Ubuntu
                @Pabla said in Dark Mode not Working - 24293:
                Outstanding. Love the easy ones!
                Got it. Couldn't really tell, so it was worth lobbing it over the fence to see if it got thrown back. In any case, thanks for clarifying, because I use that as a data point either way.
                  I'm getting the same issue even after running npm i --no-save --no-package-lock --omit dev, also tried npm run deps
                  Bare metal 24293 running on Ubuntu Server 22.04.5 LTS
                  Hard refreshed browser Chrome/Edge on Windows
                  What am I missing here?
                    Make sure you've hard-refreshed your browser after updating the packages. If you're still not getting dark mode, open your browser's console window (F12) and run the following commands exactly as shown:
                    1. $.fn.jquery — the browser should answer 3.7..1
                    2. $.ui.version — the browser should answer 1.14.0 (1.13.anything would be OK)
                    3. bootstrap.Tooltip.VERSION — the browser should answer 5.3.3
                      @toggledbits said in Dark Mode not Working - 24293:
                      Hm I'm getting 5.2.0 in both newly updated browsers.
                        OK. If you have a file called package-lock.json in the Reactor directory, remove it and run npm i --no-save --no-package-lock --omit dev again. Then do npm ls and see what version of Bootstrap is showing.
                          I can't find any package-lock.json and this is the output of npm ls
                          reactor-multi-system@1.3.0-24293 /home/homebridge/reactor
                          ├── @influxdata/influxdb-client@1.22.0
                          ├── @mdi/font@7.4.47
                          ├── @popperjs/core@2.11.6
                          ├── body-parser@1.20.1
                          ├── bootstrap-icons@1.11.3
                          ├── bootstrap@5.2.0
                          ├── digest-fetch@2.0.3
                          ├── diskusage-ng@1.0.2
                          ├── express@4.17.2
                          ├── feather-icons@4.28.0
                          ├── font-awesome@4.7.0
                          ├── gridstack@10.3.1
                          ├── jquery-ui@1.14.0
                          ├── jquery@3.7.1
                          ├── js-yaml@4.1.0
                          ├── node-fetch@2.6.7
                          ├── node-stream-zip@1.15.0
                          ├── nodemailer@6.8.0
                          ├── serve-static@1.15.0
                          ├── uuid@10.0.0
                          └── ws@7.5.9
                            OK. Edit your package.json file so that the dependencies line for bootstrap says ^5.3, and then run the npm i command (with all command line arguments previously given) again.
                              Yes, that did it! Thanks
                                131.2k
