  4. Dark Mode not Working - 24293
13 Posts 3 Posters 3.1k Views 3 Watching
    Bare metal or Docker?
      Bare metal.. forgot to add that
        OK. Check to make sure you've done all the npm updates/installed (see the warning in the release notes).
        Second issue is that dark mode on Ubuntu 24.04 is known to have issues (it's a platform issue, not a Reactor issue). Check from a browser running on another platform. This works for me on every browser I'm able to test, but Ubuntu Desktop isn't part of that. I can also see that at least one other user is successfully using dark mode.
          wrote on last edited by Pabla
          Ha I obviously missed the first line in the release notes in my excitement for the dark mode.. also my update script also bit me in the ass here since it didn't run sudo npm i --no-save --no-package-lock --omit dev.
          All seems to be working well now, no more needing to use sunglasses when switching over to my Reactor tab 😉 .
          PS by stating my Linux version I was trying to show what version of Linux Reactor was running on and not the devices I was accessing the UI from.. so can't confirm that the UI shows correctly in Ubuntu
            @Pabla said in Dark Mode not Working - 24293:
            Outstanding. Love the easy ones!
            Got it. Couldn't really tell, so it was worth lobbing it over the fence to see if it got thrown back. In any case, thanks for clarifying, because I use that as a data point either way.
              I'm getting the same issue even after running npm i --no-save --no-package-lock --omit dev, also tried npm run deps
              Bare metal 24293 running on Ubuntu Server 22.04.5 LTS
              Hard refreshed browser Chrome/Edge on Windows
              What am I missing here?
                Make sure you've hard-refreshed your browser after updating the packages. If you're still not getting dark mode, open your browser's console window (F12) and run the following commands exactly as shown:
                1. $.fn.jquery — the browser should answer 3.7..1
                2. $.ui.version — the browser should answer 1.14.0 (1.13.anything would be OK)
                3. bootstrap.Tooltip.VERSION — the browser should answer 5.3.3
                  @toggledbits said in Dark Mode not Working - 24293:
                  Hm I'm getting 5.2.0 in both newly updated browsers.
                    OK. If you have a file called package-lock.json in the Reactor directory, remove it and run npm i --no-save --no-package-lock --omit dev again. Then do npm ls and see what version of Bootstrap is showing.
                      I can't find any package-lock.json and this is the output of npm ls
                      reactor-multi-system@1.3.0-24293 /home/homebridge/reactor
                      ├── @influxdata/influxdb-client@1.22.0
                      ├── @mdi/font@7.4.47
                      ├── @popperjs/core@2.11.6
                      ├── body-parser@1.20.1
                      ├── bootstrap-icons@1.11.3
                      ├── bootstrap@5.2.0
                      ├── digest-fetch@2.0.3
                      ├── diskusage-ng@1.0.2
                      ├── express@4.17.2
                      ├── feather-icons@4.28.0
                      ├── font-awesome@4.7.0
                      ├── gridstack@10.3.1
                      ├── jquery-ui@1.14.0
                      ├── jquery@3.7.1
                      ├── js-yaml@4.1.0
                      ├── node-fetch@2.6.7
                      ├── node-stream-zip@1.15.0
                      ├── nodemailer@6.8.0
                      ├── serve-static@1.15.0
                      ├── uuid@10.0.0
                      └── ws@7.5.9
                        OK. Edit your package.json file so that the dependencies line for bootstrap says ^5.3, and then run the npm i command (with all command line arguments previously given) again.
                          Yes, that did it! Thanks
                            158.3k
