  3. Discover IR codes for lost remote
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
49 Posts 5 Posters 38.7k Views 5 Watching
    What were you thinking of using to send the codes?
    I note that luup has an ir table with a single function in it. Also, thanks to @a-lurker it's implemented in openLuup. IT mentions GC100 in the comments:
    -- IR module
    -- thanks to @a-lurker for this.
    -- see: http://forum.micasaverde.com/index.php/topic,37268.0.html
    local ir = {
      pronto_to_gc100 = function (pronto)
        -- replace the pronto code preamble with the GC100 preamble
    ...but I have absolutely no idea about its functionality, not ever having used an IR devices at this level. I would have thought that these codes ARE the pronto codes?? (...or are they IRP notation protocols?)
    parkercP Offline
    parkercP Offline
    parkerc
    @akbooer said in Discover IR codes for lost remote:
    I was ideally looking to use my Broadlink RM-Pro device and @a-lurker ‘s Vera plugin
    I’m getting a bit out of my depth here now too,..
    which is so often the case when I embark on these kind of HA adventures 🙂 .
    My interpretation is that when using irdb, you have to convert the code for them them to be Pronto codes. - http://irdb.tk/convert/
    If I use my Samsung TV as an example, that seems to use the necx2:7.7 protocol - which I’ve also seen written as NECx2, device 7.7. Either way that seems to be a very common TV code set for Samsung, Akai and some other brands.
    So, looking at their api, I assumed I could at least try to call a specific code.
    http://irdb.tk/api/code/?brand=Samsung&devicetype=TV
    And then..
    http://irdb.tk/api/code/?brand=Samsung&devicetype=TV&protocol=NECx2&device=7&subdevice=7&functionname=POWER
    but alas no ir code was returned only this json, which perhaps is not surprise... 😞
      "meta": {
        "model": "code",
        "next": "",
        "page": 1,
        "previous": ""
      "objects": [
          "function": "2",
          "protocol": "NECx2",
          "subdevice": "7",
          "devicetype": "TV",
          "device": "7",
          "functionname": "POWER"
    Any ideas on their api - http://irdb.tk/api ?
      parkec
      You haven't told us what hardware or software (MiOS/openLuup) you are using. If you read AK's code above you would just have to point to where the files are. Presumably the file(s) could be on a USB stick. You want to get AK's coe running first, on just one file first - one step at a time.
      Later you need this bit:
      bengtmartensson commented 16 hours ago •
      Just install IrpTransmogrifier as shell command and call it (as shell program) using (I think) os.execute or io.popen in Lua. No need to call java from lua
      pronto = $(irptransmogrifier render -n D=$D,S=$D,F=$F $protocol)
      The database looks like it could be huge and would take a while (who knows - a day?) to cycle around all the IR codes. Are you going to sit there and watch your device all day to catch when it turns on? AK's code needs to get the pronto code and then send it. Something like this (but totally untested):
      -- Send an IR code every two seconds
      -- Function needs to be global as it's a delay timeout target
      function sendProntoCodeToBroadLinkDevice(prontoCode)
         local BROADLINK_DEVICE_ID = 49
         luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, BROADLINK_DEVICE_ID)
      function scanIndexFiles ()
          local lfs = require "lfs"
          local dir = "codes/"   -- make this your path to the files
          local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
          local prontoCode = ''
          for file in lfs.dir(dir) do
              if file: match "%.csv$" then
                for line in io.lines(dir .. filename) do
                  local cmd_name,protocol,D,S,F = list: match (split)
                  if 'power' == cmd_name then
                    print ("$protocol $D $S $F",  protocol,D,S,F)
                    local irptransmogrifierPath = "insert path here"
                    -- this may all need work depending on whatever "irptransmogrifier" does
                    local command = string.format("%sirptransmogrifier render -n D=%s,S=%s,F=%s protocol",irptransmogrifierPath,D,S,F,protocol)
                    local handle = assert(io.popen(command))
                    local prontoCode = handle:read("*a")
                    handle:close()
                    local INTERVAL_SECS = 2
                    luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
      scanIndexFiles()
      Note: luup.call_delay only works in the openLuup window test window - I'm still not clear why. But the Vera and AltUI test windows won't run it correctly. You need the delay so the BroadLink device has time to send the code. (the function sleep() is not suitable)
      parkercP 1 Reply Last reply
      • A a-lurker
        parkec
                      handle:close()
        scanIndexFiles()
        parkercP Offline
        parkercP Offline
        parkerc
        @a-lurker said in Discover IR codes for lost remote:
        Sorry,, I’m looking first to Vera/MIOS , with the Broadlink RM Pro4, and your plug-in.
        To avoid sitting around as the devices in question register for an IP, which I can fix, I was thinking I can watch for that variable to be updated .e.g via ping test or another option could be to place a light sensor right in front of the power LED to react when the light comes on..
        Agreed, and here’s an example .csv of the Samsung TV code/set they store. /codes/
        functionname,protocol,device,subdevice,function
        INPUT SOURCE,NECx2,7,7,1
        POWER,NECx2,7,7,2
        1,NECx2,7,7,4
        2,NECx2,7,7,5
        3,NECx2,7,7,6
        VOLUME +,NECx2,7,7,7
        4,NECx2,7,7,8
        5,NECx2,7,7,9
        6,NECx2,7,7,10
        VOLUME -,NECx2,7,7,11
        7,NECx2,7,7,12
        8,NECx2,7,7,13
        9,NECx2,7,7,14
        MUTE,NECx2,7,7,15
        CHANNEL -,NECx2,7,7,16
        0,NECx2,7,7,17
        CHANNEL +,NECx2,7,7,18
        LAST,NECx2,7,7,19
        MENU,NECx2,7,7,26
        INFO,NECx2,7,7,31
        AD/SUBT,NECx2,7,7,37
        EXIT,NECx2,7,7,45
        E-MANUAL,NECx2,7,7,63
        TOOLS,NECx2,7,7,75
        GUIDE,NECx2,7,7,79
        RETURN,NECx2,7,7,88
        CUSOR UP,NECx2,7,7,96
        CURSOR DOWN,NECx2,7,7,97
        CURSOR RIGHT,NECx2,7,7,98
        CURSOR LEFT,NECx2,7,7,101
        ENTER,NECx2,7,7,104
        CH LIST,NECx2,7,7,107
        SMART HUB,NECx2,7,7,121
        3D,NECx2,7,7,159
        And overall size wise, I assume - as they are not storing every individual code and Ir format/type, instead it’s just the protocol and some other identifier - the whole irdb/code folder seems reasonably small.
          Are you sure you can’t open those devices and look at the electronics? It seems to be simpler than this, to me 😉
          Maybe, also, some repair shop could help you. They usually deal with these kind of things and maybe they have something smarter to identify them. May be worth a try.
            parkercP Offline
            parkercP Offline
            parkerc
            @therealdb said in Discover IR codes for lost remote:
            These items are racked up so it;s not quite as easy as I’d like that option to be - but I am weighing up the hassle of doing that vs doing this 🙂
            The benefit of making this code/process work is that a) i will have learnt something new - b) This could then be something g that helps others and c) it would give the Broadlink plug-in access to a huge ir bank of codes for people to use. 🙏🤞
            • parkercP Offline
              parkercP Offline
              parkerc
              I’ve been working with the code that was shared (thanks so much), and have trimming it down a bit to work it through in sections, but - here’s my current issue - any ideas ?
              (I) if I put the .csv file in the main search folder it does not return any errors, but it also does not print anything out.
              /mnt/nas/vera/ircodes/7,7.csv
              LuaTest 1.7
              Lua file: /etc/cmh-ludl/luatest.lua
              Results
              No errors
              Runtime: 51.4 ms
              Code returned: nil
              Print output
              (none)
              Code
                 2       local lfs = require "lfs"
                 3       local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
                 4       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
                 6       local prontoCode = ''
                 8       for file in lfs.dir(dir) do
                 9           if file: match "%.csv$" then
                10             for line in io.lines(dir .. filename) do
                11               local cmd_name,protocol,D,S,F = list: match (split)
                12               if 'power' == cmd_name then
                13                 print ("$protocol $D $S $F",  protocol,D,S,F)
                14               end
                15             end
                16          end
                17      end
              • When I run it again, I get this, should filename be local or specified ?
              LuaTest 1.7
              Results
              Runtime error: Line 9: attempt to concatenate global 'filename' (a nil value)
              Locals
              [main]
              lfs={ _VERSION="LuaFileSystem 1.6.2", symlinkattributes=function, lock_dir=function, dir=function, _DESCRIPTION="LuaFileSystem is a Lua library developed to complement the set of functions related to file systems offered by the standard Lua distribution", setmode=function, unlock=function, _COPYRIGHT="Copyright (C) 2003-2012 Kepler Project", currentdir=function, touch=function, mkdir=function, lock=function, link=function, attributes=function, chdir=function, rmdir=function }
              dir="mnt/nas/vera/ircodes/"
              split="[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"
              prontoCode=""
              Print output
              (none)
              Code
                 1       local lfs = require "lfs"
                 2       local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
                 3       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
                 5       local prontoCode = ''
                 7       for file in lfs.dir(dir) do
                 8           if file: match "%.csv$" then
                 9             for line in io.lines(dir .. filename) do
                10               local cmd_name,protocol,D,S,F = list: match (split)
                11               if 'POWER' == cmd_name then
                12                 print ("$protocol $D $S $F",  protocol,D,S,F)
                13               end
                14             end
                15          end
                16      end
              II) I know we are doing this in sections, but as there are many layers of manufacturer folders and device type sub folders, will the eventual end code systematically search for all *.csv files within all the levels below? E.g.
              /mnt/nas/vera/ircodes/Samsung/TV/7,7.csv
              /mnt/nas/vera/ircodes/Panasonic/TV/128,0.csv
              /mnt/nas/vera/ircodes/Panasonic/TV/128,1.csv
              /mnt/nas/vera/ircodes/Panasonic/TV/128,4.csv
              /mnt/nas/vera/ircodes/Panasonic/TV/128,9.csv
              /mnt/nas/vera/ircodes/Panasonic/DVD Player/128,0.csv /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,0.csv /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,16.csv
              /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,18.csv
              /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,28.csv
              /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,34.csv
              /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,4.csv
              /mnt/nas/vera/ircodes/Panasonic/Unknown_EUR7617010/170,3csv
              I found this online, is that the sort of thing we will need to factor i later on..
              Alex Ewerlöf  /  Jan 12, 2012
              Lua function to traverse all files in a folder recursively
              Here is a little function that uses Lua File System (lfs module) in order to traverse all the files in a folder and its sub folders (and their sub folders) recursively. DIR_SEP=”\” &#82…
              If I remove the ‘filename’ variable call, and specify a file, it then does this.
              LuaTest 1.7
              Results
              Runtime error: Line 10: attempt to index global 'list' (a nil value)
              Locals
              [main]
              prontoCode=""
              Print output
              (none)
              Code
                 9             for line in io.lines(dir .. '7,7.csv') do
                13               end
                14             end
                15          end
                16      end
                "list" should be "line"
                And /mnt/nas/vera/ircodes/Panasonic/Unknown_EUR7617010/170,3csv files are expected to end in ".csv"
                And "file" should probably be changed to "filename"
                Refer: https://keplerproject.github.io/luafilesystem/manual.html
                Also I see you changed "power" to "POWER", which is correct but it's safer to do this: 'POWER' == cmd_name:upper() to guarantee you get uppercase. You are also using commas in your filenames. While this is allowed in Linux, I'm not so sure it should be encouraged. If that's how they come, so be it.
                • parkercP Offline
                  parkercP Offline
                  parkerc
                  #21
                  Thanks, I’ve made a few adjustments based on feedback, and using just one .csv file for now, which it seems to find ok, based on the print output, but it unfortunately doesn’t extract the POWER information?
                  LuaTest 1.7
                  Results
                  No errors
                  Runtime: 9.9 ms
                  Code returned: nil
                  Print output
                  7,7.csv
                  Code
                     4       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (func_name,protocol,D,S,F)
                     8       for filename in lfs.dir(dir) do
                     9           if filename: match "%.csv$" then
                    10                  print(filename)
                    11             for line in io.lines(dir .. filename) do
                    12               local func_name,protocol,D,S,F = line: match (split)
                    13                  -- print(line)
                    14                  -- print (line: match (split))
                    15               if 'POWER' == func_name:upper() then
                    16                 print ("$protocol $D $S $F",  protocol,D,S,F)
                    17                    print (func_name)
                    18               end
                    19             end
                    20          end
                    21      end
                    My fault. A rookie error in the code (which, obviously, I hadn't tested.)
                    For your purposes, it's probably good enough to use the search string:
                    local split = "([^,]+),(%.*)" -- (func_name,protocol,D,S,F)
                    So this I have tested, and it works.
                    local split = "^([^,]+),(.*)"  -- (func_name,protocol,D,S,F)
                          print(filename)
                            local func_name,etc = line: match (split)
                              print ("$protocol $D $S $F",  etc)
                    giving this output, for example:
                    7,7.csv
                    $protocol $D $S $F 	NECx2,7,7,2
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      #23
                      Thanks @akbooer
                      If I’m to use the irptransmogrifier command line interface, I’m going to need to get the format into something like this.
                      irptransmogrifier render -p -n D=7,S=7,F=2 NECx2
                      Here is the latest code,
                            print(filename)
                      	   for word in string.gmatch(etc, '([^,]+)') do
                          	     print(word)
                      Which I’ve tried to update so that the returned values can be seen individually
                      Print output
                      7,7.csv
                      NECx2
                      However I theoretically need them created into individual variables, however I’m not able to get name them ?
                      This was my attempt, which didn’t work..
                      local protocol, device, subdevice, function2 = string.match(etc, '(%a+) (%d+) (%d+) (%d+)')
                      print('Protocol = ' .. protocol)
                      print('Device = ' .. device)
                      print('SubDevice = ' .. subdevice)
                      print('Function = ' .. function2)
                        Once you get the variables you need, use this line instead of the above - I left out the "-p"
                        local command = string.format("%sirptransmogrifier render -p -n D=%s,S=%s,F=%s protocol",irptransmogrifierPath,D,S,F,protocol)
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          #25
                          Thanks, but that’s ultimate where I’m struggling.
                          I can’t work out how to take those 4 comma separated values, and make each one identifiable as a separate variable - D,S,F, protocol
                          This line returns what I need,
                          print ("$protocol $D $S $F",  etc) ,
                          which tells me the values i need are in etc so any idea why this didn’t work ?
                          local protocol, D, S, F = string.match(etc, '(%a+) (%d+) (%d+) (%d+)')
                          print('D = ' .. D)
                          print('S = ' .. S)
                          print('F = ' .. F)
                          • parkercP parkerc
                            print('D = ' .. D)
                            print('S = ' .. S)
                            print('F = ' .. F)
                            @parkerc said in Discover IR codes for lost remote:
                            ...because the syntax is wrong.
                            I've lost count of the number of times that I may have suggested to you that it might just be worthwhile to learn a little bit more about Lua. The effort that you are putting into this shows that a bit of learning will be a very good investment.
                            This will split the parameters:
                            local params = "([^,]+),([^,]+),([^,]+),([^,]+)"
                            local protocol, D,S,F = etc: match(params)
                              parkercP Offline
                              parkercP Offline
                              parkerc
                              #27
                              I know, and believe me when I say. I honestly try to lean aspects of Lua when I can. but - I don’t know if you recall my responses in the past - my job and other commitments leave me so little time to learn anything for any length of time. And when I do find a pocket of time to play, I’m eager to create something new and interesting , and obviously use that as time to learn in the process.
                              To make it worse, not being a programmer, and not being able to work with LUA on a daily basis, so much of what I learn is sadly lost - through lack of use..
                              Not meant to be a sob story, just something I have to work with - hence I’m always so grateful for your help and the help of others..
                              • parkercP parkerc
                                parkercP Offline
                                parkercP Offline
                                parkerc
                                #28
                                It looks like I finally have the main function in good shape 👍 Next on the list is to understand how the IrpTransmogrifier element fits in.
                                FYI - I’ve added a logging facility to the code, so that I can keep track of the .csv files accessed and the codes sent.
                                  	    print('Filename =' ..filename)
                                				-- print ("$protocol $D $S $F",  etc)
                                				print('D = ' .. D)
                                				print('S = ' .. S)
                                				print('F = ' .. F)
                                			  print(command)
                                              handle:close()
                                			  print(prontoCode)
                                				local time = os.date("%Y-%m-%d %H:%M:%S")
                                				local file = io.open("/www/test_write.txt", 'a')
                                				file:write(time .. "; " .. filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
                                				file:close()
                                              --luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  #29
                                  Current sticking point is - what do I do about the ‘Java’ requirement for getting IrpTransmogrifier to run on Vera.. Any recommendations?
                                  To help narrow down my options; I’ve also posted this question on the Vera forum to see if anyone installed/used it.. -
                                  https://community.getvera.com/t/need-a-java-virtual-machine-jvm-java-runtime-environment-to-run-something/215388/2
                                  Hoping this is the final piece to the puzzle and then we’re hopefully good to go....
                                  JamVM seems the most likely...
                                    I’d be really surprised if that fitted. What type of Vera is it?
                                    • parkercP Offline
                                      parkercP Offline
                                      parkerc
                                      #31
                                      VeraPlus.
                                      The MIPS processor seems to be supported..
                                      GitHub - xranby/jamvm: JamVM is a new Java Virtual Machine conforming to the JVM specification edition 2 (blue book). Clone of git://git.code.sf.net/p/jamvm/code
                                      JamVM is a new Java Virtual Machine conforming to the JVM specification edition 2 (blue book). Clone of git://git.code.sf.net/p/jamvm/code - xranby/jamvm
                                      • parkercP parkerc
                                        VeraPlus.
                                        #32
                                        @parkerc
                                        Java on OpenWRT
                                        "...a Java VM is out of the question"
                                          @parkerc
                                          Java on OpenWRT
                                          parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          #33
                                          @parkerc
                                          Java on OpenWRT
                                          Interesting, as when I had read that part, I assumed he was just referring to your normal/standard approach to installing a Java VM on anything, as later in his point (3) he goes on to say ....
                                          1. Finding a lightweight Java VM that runs on MIPS. If you Google for "java openwrt" there are a lot of forum postings lamenting the lack of a working JVM for OpenWRT. However, jamvm (an actively maintained lightweight JVM) has had an OpenWRT ipkg right there in the OpenWRT opkg repository for a couple of years.
                                          Goes on in (4) to propose..
                                          opkg install jamvm
                                          Which, considering how Vera is set up, that’s not a package you can install via that route..
                                          root@MiOS_5247999:/tmp/verair# opkg install jamvm
                                          Unknown package 'jamvm'.
                                          Collected errors:
                                           * opkg_install_cmd: Cannot install package jamvm.
                                          root@MiOS_ 5247999:/tmp/verair#
                                          It would be good to have everything I need for this all on the same machine; looking at the specification of a VeraPlus, does anyone think it has the resources ?
                                          Spec / Vera Plus
                                          CPU = 880MHz MIPS SoC
                                          Flash Memory = NAND 128MB
                                          Memory = DDR3 256MB
                                            163.7k
