  3. Discover IR codes for lost remote
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
49 Posts 5 Posters 38.7k Views 5 Watching
    parkec
    You haven't told us what hardware or software (MiOS/openLuup) you are using. If you read AK's code above you would just have to point to where the files are. Presumably the file(s) could be on a USB stick. You want to get AK's coe running first, on just one file first - one step at a time.
    Later you need this bit:
    bengtmartensson commented 16 hours ago •
    Just install IrpTransmogrifier as shell command and call it (as shell program) using (I think) os.execute or io.popen in Lua. No need to call java from lua
    pronto = $(irptransmogrifier render -n D=$D,S=$D,F=$F $protocol)
    The database looks like it could be huge and would take a while (who knows - a day?) to cycle around all the IR codes. Are you going to sit there and watch your device all day to catch when it turns on? AK's code needs to get the pronto code and then send it. Something like this (but totally untested):
    -- Send an IR code every two seconds
    -- Function needs to be global as it's a delay timeout target
    function sendProntoCodeToBroadLinkDevice(prontoCode)
       local BROADLINK_DEVICE_ID = 49
       luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, BROADLINK_DEVICE_ID)
    function scanIndexFiles ()
        local lfs = require "lfs"
        local dir = "codes/"   -- make this your path to the files
        local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
        local prontoCode = ''
        for file in lfs.dir(dir) do
            if file: match "%.csv$" then
              for line in io.lines(dir .. filename) do
                local cmd_name,protocol,D,S,F = list: match (split)
                if 'power' == cmd_name then
                  print ("$protocol $D $S $F",  protocol,D,S,F)
                  local irptransmogrifierPath = "insert path here"
                  -- this may all need work depending on whatever "irptransmogrifier" does
                  local command = string.format("%sirptransmogrifier render -n D=%s,S=%s,F=%s protocol",irptransmogrifierPath,D,S,F,protocol)
                  local handle = assert(io.popen(command))
                  local prontoCode = handle:read("*a")
                  handle:close()
                  local INTERVAL_SECS = 2
                  luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
    scanIndexFiles()
    Note: luup.call_delay only works in the openLuup window test window - I'm still not clear why. But the Vera and AltUI test windows won't run it correctly. You need the delay so the BroadLink device has time to send the code. (the function sleep() is not suitable)
    parkercP 1 Reply Last reply
    • A a-lurker
      parkec
                    handle:close()
      scanIndexFiles()
      parkercP Offline
      parkercP Offline
      parkerc
      @a-lurker said in Discover IR codes for lost remote:
      Sorry,, I’m looking first to Vera/MIOS , with the Broadlink RM Pro4, and your plug-in.
      To avoid sitting around as the devices in question register for an IP, which I can fix, I was thinking I can watch for that variable to be updated .e.g via ping test or another option could be to place a light sensor right in front of the power LED to react when the light comes on..
      Agreed, and here’s an example .csv of the Samsung TV code/set they store. /codes/
      functionname,protocol,device,subdevice,function
      INPUT SOURCE,NECx2,7,7,1
      POWER,NECx2,7,7,2
      1,NECx2,7,7,4
      2,NECx2,7,7,5
      3,NECx2,7,7,6
      VOLUME +,NECx2,7,7,7
      4,NECx2,7,7,8
      5,NECx2,7,7,9
      6,NECx2,7,7,10
      VOLUME -,NECx2,7,7,11
      7,NECx2,7,7,12
      8,NECx2,7,7,13
      9,NECx2,7,7,14
      MUTE,NECx2,7,7,15
      CHANNEL -,NECx2,7,7,16
      0,NECx2,7,7,17
      CHANNEL +,NECx2,7,7,18
      LAST,NECx2,7,7,19
      MENU,NECx2,7,7,26
      INFO,NECx2,7,7,31
      AD/SUBT,NECx2,7,7,37
      EXIT,NECx2,7,7,45
      E-MANUAL,NECx2,7,7,63
      TOOLS,NECx2,7,7,75
      GUIDE,NECx2,7,7,79
      RETURN,NECx2,7,7,88
      CUSOR UP,NECx2,7,7,96
      CURSOR DOWN,NECx2,7,7,97
      CURSOR RIGHT,NECx2,7,7,98
      CURSOR LEFT,NECx2,7,7,101
      ENTER,NECx2,7,7,104
      CH LIST,NECx2,7,7,107
      SMART HUB,NECx2,7,7,121
      3D,NECx2,7,7,159
      And overall size wise, I assume - as they are not storing every individual code and Ir format/type, instead it’s just the protocol and some other identifier - the whole irdb/code folder seems reasonably small.
        Are you sure you can’t open those devices and look at the electronics? It seems to be simpler than this, to me 😉
        Maybe, also, some repair shop could help you. They usually deal with these kind of things and maybe they have something smarter to identify them. May be worth a try.
          parkercP Offline
          parkercP Offline
          parkerc
          @therealdb said in Discover IR codes for lost remote:
          These items are racked up so it;s not quite as easy as I’d like that option to be - but I am weighing up the hassle of doing that vs doing this 🙂
          The benefit of making this code/process work is that a) i will have learnt something new - b) This could then be something g that helps others and c) it would give the Broadlink plug-in access to a huge ir bank of codes for people to use. 🙏🤞
          • parkercP Offline
            parkercP Offline
            parkerc
            I’ve been working with the code that was shared (thanks so much), and have trimming it down a bit to work it through in sections, but - here’s my current issue - any ideas ?
            (I) if I put the .csv file in the main search folder it does not return any errors, but it also does not print anything out.
            /mnt/nas/vera/ircodes/7,7.csv
            LuaTest 1.7
            Lua file: /etc/cmh-ludl/luatest.lua
            Results
            No errors
            Runtime: 51.4 ms
            Code returned: nil
            Print output
            (none)
            Code
               2       local lfs = require "lfs"
               3       local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
               4       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
               6       local prontoCode = ''
               8       for file in lfs.dir(dir) do
               9           if file: match "%.csv$" then
              10             for line in io.lines(dir .. filename) do
              11               local cmd_name,protocol,D,S,F = list: match (split)
              12               if 'power' == cmd_name then
              13                 print ("$protocol $D $S $F",  protocol,D,S,F)
              14               end
              15             end
              16          end
              17      end
            • When I run it again, I get this, should filename be local or specified ?
            LuaTest 1.7
            Results
            Runtime error: Line 9: attempt to concatenate global 'filename' (a nil value)
            Locals
            [main]
            lfs={ _VERSION="LuaFileSystem 1.6.2", symlinkattributes=function, lock_dir=function, dir=function, _DESCRIPTION="LuaFileSystem is a Lua library developed to complement the set of functions related to file systems offered by the standard Lua distribution", setmode=function, unlock=function, _COPYRIGHT="Copyright (C) 2003-2012 Kepler Project", currentdir=function, touch=function, mkdir=function, lock=function, link=function, attributes=function, chdir=function, rmdir=function }
            dir="mnt/nas/vera/ircodes/"
            split="[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"
            prontoCode=""
            Print output
            (none)
            Code
               1       local lfs = require "lfs"
               2       local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
               3       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
               5       local prontoCode = ''
               7       for file in lfs.dir(dir) do
               8           if file: match "%.csv$" then
               9             for line in io.lines(dir .. filename) do
              10               local cmd_name,protocol,D,S,F = list: match (split)
              11               if 'POWER' == cmd_name then
              12                 print ("$protocol $D $S $F",  protocol,D,S,F)
              13               end
              14             end
              15          end
              16      end
            II) I know we are doing this in sections, but as there are many layers of manufacturer folders and device type sub folders, will the eventual end code systematically search for all *.csv files within all the levels below? E.g.
            /mnt/nas/vera/ircodes/Samsung/TV/7,7.csv
            /mnt/nas/vera/ircodes/Panasonic/TV/128,0.csv
            /mnt/nas/vera/ircodes/Panasonic/TV/128,1.csv
            /mnt/nas/vera/ircodes/Panasonic/TV/128,4.csv
            /mnt/nas/vera/ircodes/Panasonic/TV/128,9.csv
            /mnt/nas/vera/ircodes/Panasonic/DVD Player/128,0.csv /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,0.csv /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,16.csv
            /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,18.csv
            /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,28.csv
            /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,34.csv
            /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,4.csv
            /mnt/nas/vera/ircodes/Panasonic/Unknown_EUR7617010/170,3csv
            I found this online, is that the sort of thing we will need to factor i later on..
            Alex Ewerlöf  /  Jan 12, 2012
            Lua function to traverse all files in a folder recursively
            Here is a little function that uses Lua File System (lfs module) in order to traverse all the files in a folder and its sub folders (and their sub folders) recursively. DIR_SEP=”\” &#82…
            If I remove the ‘filename’ variable call, and specify a file, it then does this.
            LuaTest 1.7
            Results
            Runtime error: Line 10: attempt to index global 'list' (a nil value)
            Locals
            [main]
            prontoCode=""
            Print output
            (none)
            Code
               9             for line in io.lines(dir .. '7,7.csv') do
              13               end
              14             end
              15          end
              16      end
              "list" should be "line"
              And /mnt/nas/vera/ircodes/Panasonic/Unknown_EUR7617010/170,3csv files are expected to end in ".csv"
              And "file" should probably be changed to "filename"
              Refer: https://keplerproject.github.io/luafilesystem/manual.html
              Also I see you changed "power" to "POWER", which is correct but it's safer to do this: 'POWER' == cmd_name:upper() to guarantee you get uppercase. You are also using commas in your filenames. While this is allowed in Linux, I'm not so sure it should be encouraged. If that's how they come, so be it.
              • parkercP Offline
                parkercP Offline
                parkerc
                #21
                Thanks, I’ve made a few adjustments based on feedback, and using just one .csv file for now, which it seems to find ok, based on the print output, but it unfortunately doesn’t extract the POWER information?
                LuaTest 1.7
                Results
                No errors
                Runtime: 9.9 ms
                Code returned: nil
                Print output
                7,7.csv
                Code
                   4       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (func_name,protocol,D,S,F)
                   8       for filename in lfs.dir(dir) do
                   9           if filename: match "%.csv$" then
                  10                  print(filename)
                  11             for line in io.lines(dir .. filename) do
                  12               local func_name,protocol,D,S,F = line: match (split)
                  13                  -- print(line)
                  14                  -- print (line: match (split))
                  15               if 'POWER' == func_name:upper() then
                  16                 print ("$protocol $D $S $F",  protocol,D,S,F)
                  17                    print (func_name)
                  18               end
                  19             end
                  20          end
                  21      end
                  My fault. A rookie error in the code (which, obviously, I hadn't tested.)
                  For your purposes, it's probably good enough to use the search string:
                  local split = "([^,]+),(%.*)" -- (func_name,protocol,D,S,F)
                  So this I have tested, and it works.
                  local split = "^([^,]+),(.*)"  -- (func_name,protocol,D,S,F)
                        print(filename)
                          local func_name,etc = line: match (split)
                            print ("$protocol $D $S $F",  etc)
                  giving this output, for example:
                  7,7.csv
                  $protocol $D $S $F 	NECx2,7,7,2
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    #23
                    Thanks @akbooer
                    If I’m to use the irptransmogrifier command line interface, I’m going to need to get the format into something like this.
                    irptransmogrifier render -p -n D=7,S=7,F=2 NECx2
                    Here is the latest code,
                          print(filename)
                    	   for word in string.gmatch(etc, '([^,]+)') do
                        	     print(word)
                    Which I’ve tried to update so that the returned values can be seen individually
                    Print output
                    7,7.csv
                    NECx2
                    However I theoretically need them created into individual variables, however I’m not able to get name them ?
                    This was my attempt, which didn’t work..
                    local protocol, device, subdevice, function2 = string.match(etc, '(%a+) (%d+) (%d+) (%d+)')
                    print('Protocol = ' .. protocol)
                    print('Device = ' .. device)
                    print('SubDevice = ' .. subdevice)
                    print('Function = ' .. function2)
                      Once you get the variables you need, use this line instead of the above - I left out the "-p"
                      local command = string.format("%sirptransmogrifier render -p -n D=%s,S=%s,F=%s protocol",irptransmogrifierPath,D,S,F,protocol)
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        #25
                        Thanks, but that’s ultimate where I’m struggling.
                        I can’t work out how to take those 4 comma separated values, and make each one identifiable as a separate variable - D,S,F, protocol
                        This line returns what I need,
                        print ("$protocol $D $S $F",  etc) ,
                        which tells me the values i need are in etc so any idea why this didn’t work ?
                        local protocol, D, S, F = string.match(etc, '(%a+) (%d+) (%d+) (%d+)')
                        print('D = ' .. D)
                        print('S = ' .. S)
                        print('F = ' .. F)
                        • parkercP parkerc
                          print('D = ' .. D)
                          print('S = ' .. S)
                          print('F = ' .. F)
                          @parkerc said in Discover IR codes for lost remote:
                          ...because the syntax is wrong.
                          I've lost count of the number of times that I may have suggested to you that it might just be worthwhile to learn a little bit more about Lua. The effort that you are putting into this shows that a bit of learning will be a very good investment.
                          This will split the parameters:
                          local params = "([^,]+),([^,]+),([^,]+),([^,]+)"
                          local protocol, D,S,F = etc: match(params)
                            parkercP Offline
                            parkercP Offline
                            parkerc
                            #27
                            @akbooer said in Discover IR codes for lost remote:
                            I know, and believe me when I say. I honestly try to lean aspects of Lua when I can. but - I don’t know if you recall my responses in the past - my job and other commitments leave me so little time to learn anything for any length of time. And when I do find a pocket of time to play, I’m eager to create something new and interesting , and obviously use that as time to learn in the process.
                            To make it worse, not being a programmer, and not being able to work with LUA on a daily basis, so much of what I learn is sadly lost - through lack of use..
                            Not meant to be a sob story, just something I have to work with - hence I’m always so grateful for your help and the help of others..
                            • parkercP parkerc
                              parkercP Offline
                              parkercP Offline
                              parkerc
                              #28
                              It looks like I finally have the main function in good shape 👍 Next on the list is to understand how the IrpTransmogrifier element fits in.
                              FYI - I’ve added a logging facility to the code, so that I can keep track of the .csv files accessed and the codes sent.
                                	    print('Filename =' ..filename)
                              				-- print ("$protocol $D $S $F",  etc)
                              				print('D = ' .. D)
                              				print('S = ' .. S)
                              				print('F = ' .. F)
                              			  print(command)
                                            handle:close()
                              			  print(prontoCode)
                              				local time = os.date("%Y-%m-%d %H:%M:%S")
                              				local file = io.open("/www/test_write.txt", 'a')
                              				file:write(time .. "; " .. filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
                              				file:close()
                                            --luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                #29
                                Current sticking point is - what do I do about the ‘Java’ requirement for getting IrpTransmogrifier to run on Vera.. Any recommendations?
                                To help narrow down my options; I’ve also posted this question on the Vera forum to see if anyone installed/used it.. -
                                https://community.getvera.com/t/need-a-java-virtual-machine-jvm-java-runtime-environment-to-run-something/215388/2
                                Hoping this is the final piece to the puzzle and then we’re hopefully good to go....
                                JamVM seems the most likely...
                                  I’d be really surprised if that fitted. What type of Vera is it?
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    #31
                                    VeraPlus.
                                    The MIPS processor seems to be supported..
                                    GitHub - xranby/jamvm: JamVM is a new Java Virtual Machine conforming to the JVM specification edition 2 (blue book). Clone of git://git.code.sf.net/p/jamvm/code
                                    JamVM is a new Java Virtual Machine conforming to the JVM specification edition 2 (blue book). Clone of git://git.code.sf.net/p/jamvm/code - xranby/jamvm
                                    • parkercP parkerc
                                      VeraPlus.
                                      #32
                                      @parkerc
                                      Java on OpenWRT
                                      "...a Java VM is out of the question"
                                        @parkerc
                                        Java on OpenWRT
                                        parkercP Offline
                                        parkercP Offline
                                        parkerc
                                        #33
                                        @parkerc
                                        Java on OpenWRT
                                        Interesting, as when I had read that part, I assumed he was just referring to your normal/standard approach to installing a Java VM on anything, as later in his point (3) he goes on to say ....
                                        1. Finding a lightweight Java VM that runs on MIPS. If you Google for "java openwrt" there are a lot of forum postings lamenting the lack of a working JVM for OpenWRT. However, jamvm (an actively maintained lightweight JVM) has had an OpenWRT ipkg right there in the OpenWRT opkg repository for a couple of years.
                                        Goes on in (4) to propose..
                                        opkg install jamvm
                                        Which, considering how Vera is set up, that’s not a package you can install via that route..
                                        root@MiOS_5247999:/tmp/verair# opkg install jamvm
                                        Unknown package 'jamvm'.
                                        Collected errors:
                                         * opkg_install_cmd: Cannot install package jamvm.
                                        root@MiOS_ 5247999:/tmp/verair#
                                        It would be good to have everything I need for this all on the same machine; looking at the specification of a VeraPlus, does anyone think it has the resources ?
                                        Spec / Vera Plus
                                        CPU = 880MHz MIPS SoC
                                        Flash Memory = NAND 128MB
                                        Memory = DDR3 256MB
                                        • parkercP parkerc
                                          @parkerc
                                          Java on OpenWRT
                                          opkg install jamvm
                                          Collected errors:
                                          Spec / Vera Plus
                                          Memory = DDR3 256MB
                                          #34
                                          No.
                                          Forget doing this on a Vera. It would be easier to use, say Windows. Any recent Win machine probably already has the JRE already installed. Just install Lua on the Win machine (refer Google), get the code working (can still use Vera to test the majority of the code) and the call the IR transmitter on Vera with a URL, just like any other function (refer MiOS wiki) can be executed.
                                          The install info for IrpTransmogrifier already has a batch file available ready to run it (refer to IrpTransmogrifier GitHub release and documentation pages). Basically IrpTransmogrifier is a Java program and needs to be executed by something that knows how to do it eg JVE. Just like windows knows how to execute Windows executables.
                                          What does IrpTransmogrifier do? Lots of stuff but in your case it can generate (or as they prefer "render") actual codes, when feed a little bit of information. ie the parameters that define a code in a concise manner - that is: protocol,D,S,F
                                            163.7k
