  3. Discover IR codes for lost remote
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
49 Posts 5 Posters 38.7k Views 5 Watching
  • parkercP parkerc
    Thanks, but that’s ultimate where I’m struggling.
    I can’t work out how to take those 4 comma separated values, and make each one identifiable as a separate variable - D,S,F, protocol
    This line returns what I need,
    print ("$protocol $D $S $F",  etc) ,
    which tells me the values i need are in etc so any idea why this didn’t work ?
    local protocol, D, S, F = string.match(etc, '(%a+) (%d+) (%d+) (%d+)')
    print('Protocol = ' .. protocol)
    print('D = ' .. D)
    print('S = ' .. S)
    print('F = ' .. F)
    @parkerc said in Discover IR codes for lost remote:
    ...because the syntax is wrong.
    I've lost count of the number of times that I may have suggested to you that it might just be worthwhile to learn a little bit more about Lua. The effort that you are putting into this shows that a bit of learning will be a very good investment.
    This will split the parameters:
    local params = "([^,]+),([^,]+),([^,]+),([^,]+)"
    local protocol, D,S,F = etc: match(params)
    parkercP 1 Reply Last reply
      parkercP Offline
      parkercP Offline
      parkerc
      #27
      @akbooer said in Discover IR codes for lost remote:
      I know, and believe me when I say. I honestly try to lean aspects of Lua when I can. but - I don’t know if you recall my responses in the past - my job and other commitments leave me so little time to learn anything for any length of time. And when I do find a pocket of time to play, I’m eager to create something new and interesting , and obviously use that as time to learn in the process.
      To make it worse, not being a programmer, and not being able to work with LUA on a daily basis, so much of what I learn is sadly lost - through lack of use..
      Not meant to be a sob story, just something I have to work with - hence I’m always so grateful for your help and the help of others..
      • parkercP parkerc
        parkercP Offline
        parkercP Offline
        parkerc
        #28
        It looks like I finally have the main function in good shape 👍 Next on the list is to understand how the IrpTransmogrifier element fits in.
        FYI - I’ve added a logging facility to the code, so that I can keep track of the .csv files accessed and the codes sent.
        function scanIndexFiles ()
        	local lfs = require "lfs"
        	local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
        	local split = "^([^,]+),(.*)"  -- (func_name,protocol,D,S,F)
            local prontoCode = ''
            for filename in lfs.dir(dir) do
            	if filename: match "%.csv$" then
          	    print('Filename =' ..filename)
         	     for line in io.lines(dir .. filename) do
        			local func_name,etc = line: match (split)
        				if 'POWER' == func_name:upper() then
        				-- print ("$protocol $D $S $F",  etc)
        				print('D = ' .. D)
        				print('S = ' .. S)
        				print('F = ' .. F)
        			  local irptransmogrifierPath = "insert path here"
                      -- this may all need work depending on whatever "irptransmogrifier" does
                      local command = string.format("%sirptransmogrifier render -n D=%s,S=%s,F=%s protocol",irptransmogrifierPath,D,S,F,protocol)
        			  print(command)
                      local handle = assert(io.popen(command))
                      local prontoCode = handle:read("*a")
                      handle:close()
        			  print(prontoCode)
        				local time = os.date("%Y-%m-%d %H:%M:%S")
        				local file = io.open("/www/test_write.txt", 'a')
        				file:write(time .. "; " .. filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
        				file:close()
                      local INTERVAL_SECS = 2
                      --luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
        • parkercP Offline
          parkercP Offline
          parkerc
          #29
          Current sticking point is - what do I do about the ‘Java’ requirement for getting IrpTransmogrifier to run on Vera.. Any recommendations?
          To help narrow down my options; I’ve also posted this question on the Vera forum to see if anyone installed/used it.. -
          https://community.getvera.com/t/need-a-java-virtual-machine-jvm-java-runtime-environment-to-run-something/215388/2
          Hoping this is the final piece to the puzzle and then we’re hopefully good to go....
          JamVM seems the most likely...
            I’d be really surprised if that fitted. What type of Vera is it?
            • parkercP Offline
              parkercP Offline
              parkerc
              #31
              VeraPlus.
              The MIPS processor seems to be supported..
              GitHub - xranby/jamvm: JamVM is a new Java Virtual Machine conforming to the JVM specification edition 2 (blue book). Clone of git://git.code.sf.net/p/jamvm/code
              JamVM is a new Java Virtual Machine conforming to the JVM specification edition 2 (blue book). Clone of git://git.code.sf.net/p/jamvm/code - xranby/jamvm
              • parkercP parkerc
                VeraPlus.
                #32
                @parkerc
                Java on OpenWRT
                "...a Java VM is out of the question"
                  @parkerc
                  Java on OpenWRT
                  parkercP Offline
                  parkercP Offline
                  parkerc
                  #33
                  @parkerc
                  Java on OpenWRT
                  Interesting, as when I had read that part, I assumed he was just referring to your normal/standard approach to installing a Java VM on anything, as later in his point (3) he goes on to say ....
                  1. Finding a lightweight Java VM that runs on MIPS. If you Google for "java openwrt" there are a lot of forum postings lamenting the lack of a working JVM for OpenWRT. However, jamvm (an actively maintained lightweight JVM) has had an OpenWRT ipkg right there in the OpenWRT opkg repository for a couple of years.
                  Goes on in (4) to propose..
                  opkg install jamvm
                  Which, considering how Vera is set up, that’s not a package you can install via that route..
                  root@MiOS_5247999:/tmp/verair# opkg install jamvm
                  Unknown package 'jamvm'.
                  Collected errors:
                   * opkg_install_cmd: Cannot install package jamvm.
                  root@MiOS_ 5247999:/tmp/verair#
                  It would be good to have everything I need for this all on the same machine; looking at the specification of a VeraPlus, does anyone think it has the resources ?
                  Spec / Vera Plus
                  CPU = 880MHz MIPS SoC
                  Flash Memory = NAND 128MB
                  Memory = DDR3 256MB
                  • parkercP parkerc
                    @parkerc
                    Java on OpenWRT
                    opkg install jamvm
                    Collected errors:
                    Spec / Vera Plus
                    Memory = DDR3 256MB
                    #34
                    No.
                    Forget doing this on a Vera. It would be easier to use, say Windows. Any recent Win machine probably already has the JRE already installed. Just install Lua on the Win machine (refer Google), get the code working (can still use Vera to test the majority of the code) and the call the IR transmitter on Vera with a URL, just like any other function (refer MiOS wiki) can be executed.
                    The install info for IrpTransmogrifier already has a batch file available ready to run it (refer to IrpTransmogrifier GitHub release and documentation pages). Basically IrpTransmogrifier is a Java program and needs to be executed by something that knows how to do it eg JVE. Just like windows knows how to execute Windows executables.
                    What does IrpTransmogrifier do? Lots of stuff but in your case it can generate (or as they prefer "render") actual codes, when feed a little bit of information. ie the parameters that define a code in a concise manner - that is: protocol,D,S,F
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      #35
                      Agreed, it doesn't really matter where the ‘processing’ is done, (doing it all on Vera just seemed the easiest) - but I ultimately just need to have a facility where I can search, find and the raise a request (all of which is so far unproven/tested) for the ‘POWER’ IR commands via ...
                      irptransmogrifier render -p -n D=7,S=7,F=2 NECx2
                      ... and then have it (hopefully) return the command in the pronto code/format I want ....
                      0000 006C 0000 0022 00AD 00AD 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 06FB
                      .. and then once I have it, I just need to get that returned ‘code’ into your Broadlink request..
                      function sendProntoCodeToBroadLinkDevice(prontoCode)
                         local BROADLINK_DEVICE_ID = 49
                         luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, BROADLINK_DEVICE_ID)
                      It all seem so do-able when I started. 🤣
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        #36
                        Hi all
                        The plan on this now is to generates a CSV file, one line per signal, containing the filename, the ‘POWER’ command was found in, its protocol, and the D, S, and F parameters, that I can then import into IrScrutinizer (which is basically IrpTransmogrifier with a GUI), and then export that in the Pronto format .
                        Currently the following code to create the .csv is not going recursively through all the folders, any advice ?
                        			local file = io.open("/www/powerircodes.txt", 'a')
                        			print(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
                        			file:write(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
                        			file:close()
                        scanIndexFiles()
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          #37
                          If it’s not easy/desirable to work through the folders using code, I can alway go down through the entire sub- folder hierarchy and bring all the individual .csv files into one single directory.
                          Update:
                          Some really good progress has been made using the IrScrutinizer app on a windows PC, as that allows me to do a batch conversion of the raw format i gather , into the desired Pronto code format. 🙂
                          Next challenge:
                          What is the best export format from IrScrutinizer to use with Lua ? Txt, html, xml,
                          See all the expert options here.. - http://www.harctoolbox.org/IrScrutinizer.html#The+Export+pane
                          Once that’s’ s done, the final piece of this grand plan i guess, is to have Vera work through that entire exported list, in order - sending each command, wait for a response, and if nothing is seen after x seconds, move onto the next one..
                          • parkercP Offline
                            parkercP Offline
                            parkerc
                            #38
                            If there is anyone still following this 🙂 -
                            I’ve got all the .csv files into a single directory now, and everything is pretty much coming together - it’s just that my current issue seems to be with the code that’s extracting the ‘POWER’ line item information.
                            Based on the following LuaTest output, if I’m interpreting it correctly it needs something to handle any errors found when working through each .csv file. I’ve tired to add an ‘elseif’ but it either just breaks it/or stops.
                            Please could someone advise how do to get it ignore a file where it has a problem and move on seamlessly to the next one ?
                            LuaTest 1.7
                            Lua file: /etc/cmh-ludl/luatest.lua
                            Results
                            Runtime error: Line 14: attempt to index local 'etc' (a nil value)
                            Locals
                            [scanIndexFiles]
                            lfs={ _VERSION="LuaFileSystem 1.6.2", symlinkattributes=function, lock_dir=function, dir=function, _DESCRIPTION="LuaFileSystem is a Lua library developed to complement the set of functions related to file systems offered by the standard Lua distribution", setmode=function, unlock=function, _COPYRIGHT="Copyright (C) 2003-2012 Kepler Project", currentdir=function, touch=function, mkdir=function, lock=function, link=function, attributes=function, chdir=function, rmdir=function }
                            dir="mnt/nas/vera/ircodes/"
                            split="^([^,]+),(.*)"
                            prontoCode=""
                            [main]
                            Print output
                            Filename =26,-1.csv
                            Filename =232,26.csv
                            Filename =88,23.csv
                            Filename =3,1.csv
                            Filename =64,-1.csv
                            Filename =1,222.csv
                            Filename =25,-1.csv
                            Filename =20,-1.csv
                            Filename =64,159.csv
                            Filename =203,67.csv
                            Filename =167,133.csv
                            Filename =192,243.csv
                            Code
                               1   function scanIndexFiles ()
                               2        local lfs = require "lfs"
                               3        local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
                               4        local split = "^([^,]+),(.*)"  -- (func_name,protocol,D,S,F)
                               6       local prontoCode = ''
                               8       for filename in lfs.dir(dir) do
                               9            if filename: match "%.csv$" then
                              10             print('Filename =' ..filename)
                              11             for line in io.lines(dir .. filename) do
                              12                  local func_name,etc = line: match (split)
                              13                  local params = "([^,]+),([^,]+),([^,]+),([^,]+)"
                              14                  local protocol, D,S,F = etc: match(params)
                              15                       if 'POWER' == func_name:upper() then
                              16                       -- print ("$protocol $D $S $F",  etc)
                              17                       -- print('Protocol = ' .. protocol)
                              18                       -- print('D = ' .. D)
                              19                       -- print('S = ' .. S)
                              20                       -- print('F = ' .. F)
                              21                  local time = os.date("%Y-%m-%d %H:%M:%S")
                              22                  local file = io.open("/www/powerircodes.txt", 'a')
                              23        print(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
                              24        file:write(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
                              25        -- file:write(time .. "; " .. filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
                              26        file:close()
                              27
                              28               end
                              29             end
                              30          end
                              31       end
                              32   end
                              33
                              34   scanIndexFiles()
                                local file = io.open "/www/powerircodes.txt"
                                      if etc then
                                          local info = table.concat ({filename, protocol, D, S, F}, "; ")
                                          print(info)
                                          file:write(info .. "\n")
                                file:close()
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                #40
                                Thanks so much @akbooer 🤩
                                I’ve run it a couple of times now, but it doesn’t seem to write to the file? It prints to the screen ok, but not to the write?
                                To get around that I’ve just been coping and pasting the print output into a text file
                                I’m close to the final piece now, I’ve captured and converted all the ‘POWER’ codes listed across all of those .csv files and I’d like to convert them into a table, or .csv, with their associated command name as the variable name, so I can then call them.
                                Example content of text1.txt (created by IrScrutinizer).
                                Power
                                0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0ACD
                                Power$1
                                0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
                                Power$2
                                0000 0068 0000 0022 0169 00B4 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0636
                                And I’m now trying to get that above into a more usable format, such a Lua array/table or maybe another .csv. Below is th3 code I’ve been working on to do that, but i’m not having much success doing the conversion.
                                function convertCodestoarray (filename)
                                  local dir = "mnt/nas/vera/ircodes/"   -- the path to the files
                                  print(dir .. filename)
                                    	if filename: match "%.txt$" then
                                				local params = "([^,]+)/n([^,]+)"
                                				local codename, prontocode = params
                                				local params = table.concat ({codename, prontocode}, ", ")
                                				print(params)
                                					local file = io.open("powerircodes.csv", 'a')
                                        			filename:write(params .. "\n")
                                filename:close()
                                convertCodestoarray("text1.txt")
                                • parkercP parkerc
                                  Power
                                  Power$1
                                  Power$2
                                  				print(params)
                                  filename:close()
                                  No, the file is opened in the wrong mode... you should have spotted that. 😉
                                  local file = io.open ("/www/powerircodes.txt", “wb”)
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    Thanks again @akbooer 🤩
                                    Last ask 🤞- how would you convert the IrScrutinizer created file (the one with all the converted ProntoCodes posted above) into a list/table/array/.csv - that I can then use with @alurker’s original post for his Broadlink irsender ?
                                    • parkercP parkerc
                                      Last ask
                                      Last answer...
                                      A demo program that reads lines from a string with your data format and converts to tables of numbers.
                                      local t = [[
                                      Power
                                      Power$1
                                      Power$2
                                      local function decode(line)
                                        local code = {}
                                        for n in line: gmatch "%x+" do
                                          code[#code+1] = tonumber(n,0x10)
                                        return code
                                      for l in t: gmatch "[^\n]+" do
                                        if l: match "^%x+" then
                                          print(pretty(decode(l)))
                                      Gives this output:
                                      {0,112,0,50,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,48,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,48,16,48,16,16,16,48,16,48,16,48,16,2765}
                                      {0,108,34,2,347,173,22,22,22,22,22,22,22,22,22,22,22,22,22,65,22,22,22,65,22,65,22,65,22,65,22,65,22,22,22,65,22,65,22,22,22,65,22,22,22,22,22,65,22,22,22,22,22,22,22,65,22,22,22,65,22,65,22,22,22,65,22,65,22,65,22,1527,347,87,22,3692}
                                      {0,104,0,34,361,180,23,68,23,68,23,23,23,23,23,23,23,68,23,23,23,68,23,23,23,23,23,68,23,68,23,68,23,23,23,68,23,23,23,68,23,23,23,23,23,68,23,68,23,23,23,23,23,68,23,23,23,68,23,68,23,23,23,23,23,68,23,68,23,23,23,1590}
                                      • parkercP Offline
                                        parkercP Offline
                                        parkerc
                                        #44
                                        Thanks @akbooer, although I’m ideally trying to get the output of that array to be something like this..
                                        Power = "0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0ACD"
                                        Power$1 = "0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C"
                                        Power$2 = "0000 0068 0000 0022 0169 00B4 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0636’
                                        Running the script you chafed above retuned this...
                                        LuaTest 1.7
                                        Results
                                        No errors
                                        Runtime: 55.4 ms
                                        Code returned: nil
                                        Print output
                                        { [1]=0, [2]=112, [3]=0, [4]=50, [5]=128, [6]=64, [7]=16, [8]=16, [9]=16, [10]=48, [11]=16, [12]=16, [13]=16, [14]=16, [15]=16, [16]=16, [17]=16, [18]=16, [19]=16, [20]=16, [21]=16, [22]=16, [23]=16, [24]=16, [25]=16, [26]=16, [27]=16, [28]=16, [29]=16, [30]=16, [31]=16, [32]=16, [33]=16, [34]=48, [35]=16, [36]=16, [37]=16, [38]=16, [39]=16, [40]=16, [41]=16, [42]=16, [43]=16, [44]=16, [45]=16, [46]=16, [47]=16, [48]=48, [49]=16, [50]=16, [51]=16, [52]=16, [53]=16, [54]=48, [55]=16, [56]=16, [57]=16, [58]=16, [59]=16, [60]=16, [61]=16, [62]=16, [63]=16, [64]=16, [65]=16, [66]=16, [67]=16, [68]=48, [69]=16, [70]=16, [71]=16, [72]=48, [73]=16, [74]=16, [75]=16, [76]=48, [77]=16, [78]=48, [79]=16, [80]=48, [81]=16, [82]=48, [83]=16, [84]=16, [85]=16, [86]=16, [87]=16, [88]=48, [89]=16, [90]=16, [91]=16, [92]=48, [93]=16, [94]=48, [95]=16, [96]=16, [97]=16, [98]=48, [99]=16, [100]=48, [101]=16, [102]=48, [103]=16, [104]=2765 }
                                        { [1]=0, [2]=108, [3]=34, [4]=2, [5]=347, [6]=173, [7]=22, [8]=22, [9]=22, [10]=22, [11]=22, [12]=22, [13]=22, [14]=22, [15]=22, [16]=22, [17]=22, [18]=22, [19]=22, [20]=65, [21]=22, [22]=22, [23]=22, [24]=65, [25]=22, [26]=65, [27]=22, [28]=65, [29]=22, [30]=65, [31]=22, [32]=65, [33]=22, [34]=22, [35]=22, [36]=65, [37]=22, [38]=65, [39]=22, [40]=22, [41]=22, [42]=65, [43]=22, [44]=22, [45]=22, [46]=22, [47]=22, [48]=65, [49]=22, [50]=22, [51]=22, [52]=22, [53]=22, [54]=22, [55]=22, [56]=65, [57]=22, [58]=22, [59]=22, [60]=65, [61]=22, [62]=65, [63]=22, [64]=22, [65]=22, [66]=65, [67]=22, [68]=65, [69]=22, [70]=65, [71]=22, [72]=1527, [73]=347, [74]=87, [75]=22, [76]=3692 }
                                        { [1]=0, [2]=104, [3]=0, [4]=34, [5]=361, [6]=180, [7]=23, [8]=68, [9]=23, [10]=68, [11]=23, [12]=23, [13]=23, [14]=23, [15]=23, [16]=23, [17]=23, [18]=68, [19]=23, [20]=23, [21]=23, [22]=68, [23]=23, [24]=23, [25]=23, [26]=23, [27]=23, [28]=68, [29]=23, [30]=68, [31]=23, [32]=68, [33]=23, [34]=23, [35]=23, [36]=68, [37]=23, [38]=23, [39]=23, [40]=68, [41]=23, [42]=23, [43]=23, [44]=23, [45]=23, [46]=68, [47]=23, [48]=68, [49]=23, [50]=23, [51]=23, [52]=23, [53]=23, [54]=68, [55]=23, [56]=23, [57]=23, [58]=68, [59]=23, [60]=68, [61]=23, [62]=23, [63]=23, [64]=23, [65]=23, [66]=68, [67]=23, [68]=68, [69]=23, [70]=23, [71]=23, [72]=1590 }
                                        Sorry to ask this, but how can that be achieved?
                                        • parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          #45
                                          I had been working on something like this, is it close?
                                          local ircodearray =  {}
                                          local rfile = io.open("mnt/nas/vera/text1.txt", "r")
                                          for line in rfile:lines() do
                                              local commandname = line:match("^Powe.*")
                                          	local prontocode = line:match("^0000.*")
                                              local ircodearray = {"local = " .. commandname, prontocode}
                                          print(ircodearray)
                                            163.7k
