  3. Discover IR codes for lost remote
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
49 Posts 5 Posters 37.1k Views 5 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    #36
    Hi all
    The plan on this now is to generates a CSV file, one line per signal, containing the filename, the ‘POWER’ command was found in, its protocol, and the D, S, and F parameters, that I can then import into IrScrutinizer (which is basically IrpTransmogrifier with a GUI), and then export that in the Pronto format .
    Currently the following code to create the .csv is not going recursively through all the folders, any advice ?
    function scanIndexFiles ()
    	local lfs = require "lfs"
    	local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
    	local split = "^([^,]+),(.*)"  -- (func_name,protocol,D,S,F)
    	local time = os.date("%Y-%m-%d %H:%M:%S")
        local prontoCode = ''
        for filename in lfs.dir(dir) do
        	if filename: match "%.csv$" then
    		for line in io.lines(dir .. filename) do
    			local func_name,etc = line: match (split)
    			local params = "([^,]+),([^,]+),([^,]+),([^,]+)"
    			local protocol, D,S,F = etc: match(params)
    				if 'POWER' == func_name:upper() then
    			local file = io.open("/www/powerircodes.txt", 'a')
    			print(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
    			file:write(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
    			file:close()
    scanIndexFiles()
    • parkercP Offline
      parkercP Offline
      parkerc
      #37
      If it’s not easy/desirable to work through the folders using code, I can alway go down through the entire sub- folder hierarchy and bring all the individual .csv files into one single directory.
      Update:
      Some really good progress has been made using the IrScrutinizer app on a windows PC, as that allows me to do a batch conversion of the raw format i gather , into the desired Pronto code format. 🙂
      Next challenge:
      What is the best export format from IrScrutinizer to use with Lua ? Txt, html, xml,
      See all the expert options here.. - http://www.harctoolbox.org/IrScrutinizer.html#The+Export+pane
      Once that’s’ s done, the final piece of this grand plan i guess, is to have Vera work through that entire exported list, in order - sending each command, wait for a response, and if nothing is seen after x seconds, move onto the next one..
      • parkercP Offline
        parkercP Offline
        parkerc
        #38
        If there is anyone still following this 🙂 -
        I’ve got all the .csv files into a single directory now, and everything is pretty much coming together - it’s just that my current issue seems to be with the code that’s extracting the ‘POWER’ line item information.
        Based on the following LuaTest output, if I’m interpreting it correctly it needs something to handle any errors found when working through each .csv file. I’ve tired to add an ‘elseif’ but it either just breaks it/or stops.
        Please could someone advise how do to get it ignore a file where it has a problem and move on seamlessly to the next one ?
        LuaTest 1.7
        Lua file: /etc/cmh-ludl/luatest.lua
        Results
        Runtime error: Line 14: attempt to index local 'etc' (a nil value)
        Locals
        [scanIndexFiles]
        lfs={ _VERSION="LuaFileSystem 1.6.2", symlinkattributes=function, lock_dir=function, dir=function, _DESCRIPTION="LuaFileSystem is a Lua library developed to complement the set of functions related to file systems offered by the standard Lua distribution", setmode=function, unlock=function, _COPYRIGHT="Copyright (C) 2003-2012 Kepler Project", currentdir=function, touch=function, mkdir=function, lock=function, link=function, attributes=function, chdir=function, rmdir=function }
        dir="mnt/nas/vera/ircodes/"
        split="^([^,]+),(.*)"
        prontoCode=""
        [main]
        Print output
        Filename =26,-1.csv
        Filename =232,26.csv
        Filename =88,23.csv
        Filename =3,1.csv
        Filename =64,-1.csv
        Filename =1,222.csv
        Filename =25,-1.csv
        Filename =20,-1.csv
        Filename =64,159.csv
        Filename =203,67.csv
        Filename =167,133.csv
        Filename =192,243.csv
        Code
           1   function scanIndexFiles ()
           2        local lfs = require "lfs"
           3        local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
           4        local split = "^([^,]+),(.*)"  -- (func_name,protocol,D,S,F)
           6       local prontoCode = ''
           8       for filename in lfs.dir(dir) do
           9            if filename: match "%.csv$" then
          10             print('Filename =' ..filename)
          11             for line in io.lines(dir .. filename) do
          12                  local func_name,etc = line: match (split)
          13                  local params = "([^,]+),([^,]+),([^,]+),([^,]+)"
          14                  local protocol, D,S,F = etc: match(params)
          15                       if 'POWER' == func_name:upper() then
          16                       -- print ("$protocol $D $S $F",  etc)
          17                       -- print('Protocol = ' .. protocol)
          18                       -- print('D = ' .. D)
          19                       -- print('S = ' .. S)
          20                       -- print('F = ' .. F)
          21                  local time = os.date("%Y-%m-%d %H:%M:%S")
          22                  local file = io.open("/www/powerircodes.txt", 'a')
          23        print(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
          24        file:write(filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
          25        -- file:write(time .. "; " .. filename .. "; " .. protocol .. "; " .. D .. "; " .. S .. "; " .. F .. "\n")
          26        file:close()
          27
          28               end
          29             end
          30          end
          31       end
          32   end
          33
          34   scanIndexFiles()
            local file = io.open "/www/powerircodes.txt"
                  if etc then
                      local info = table.concat ({filename, protocol, D, S, F}, "; ")
                      print(info)
                      file:write(info .. "\n")
            file:close()
          • parkercP Offline
            parkercP Offline
            parkerc
            #40
            Thanks so much @akbooer 🤩
            I’ve run it a couple of times now, but it doesn’t seem to write to the file? It prints to the screen ok, but not to the write?
            To get around that I’ve just been coping and pasting the print output into a text file
            I’m close to the final piece now, I’ve captured and converted all the ‘POWER’ codes listed across all of those .csv files and I’d like to convert them into a table, or .csv, with their associated command name as the variable name, so I can then call them.
            Example content of text1.txt (created by IrScrutinizer).
            Power
            0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0ACD
            Power$1
            0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
            Power$2
            0000 0068 0000 0022 0169 00B4 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0636
            And I’m now trying to get that above into a more usable format, such a Lua array/table or maybe another .csv. Below is th3 code I’ve been working on to do that, but i’m not having much success doing the conversion.
            function convertCodestoarray (filename)
              local dir = "mnt/nas/vera/ircodes/"   -- the path to the files
              print(dir .. filename)
                	if filename: match "%.txt$" then
            				local params = "([^,]+)/n([^,]+)"
            				local codename, prontocode = params
            				local params = table.concat ({codename, prontocode}, ", ")
            				print(params)
            					local file = io.open("powerircodes.csv", 'a')
                    			filename:write(params .. "\n")
            filename:close()
            convertCodestoarray("text1.txt")
            • parkercP parkerc
              Power
              Power$1
              Power$2
              				print(params)
              filename:close()
              @parkerc said in Discover IR codes for lost remote:
              No, the file is opened in the wrong mode... you should have spotted that. 😉
              local file = io.open ("/www/powerircodes.txt", “wb”)
              • parkercP Offline
                parkercP Offline
                parkerc
                Thanks again @akbooer 🤩
                Last ask 🤞- how would you convert the IrScrutinizer created file (the one with all the converted ProntoCodes posted above) into a list/table/array/.csv - that I can then use with @alurker’s original post for his Broadlink irsender ?
                • parkercP parkerc
                  Last ask
                  Last answer...
                  A demo program that reads lines from a string with your data format and converts to tables of numbers.
                  local t = [[
                  Power
                  Power$1
                  Power$2
                  local function decode(line)
                    local code = {}
                    for n in line: gmatch "%x+" do
                      code[#code+1] = tonumber(n,0x10)
                    return code
                  for l in t: gmatch "[^\n]+" do
                    if l: match "^%x+" then
                      print(pretty(decode(l)))
                  Gives this output:
                  {0,112,0,50,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,48,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,48,16,48,16,16,16,48,16,48,16,48,16,2765}
                  {0,108,34,2,347,173,22,22,22,22,22,22,22,22,22,22,22,22,22,65,22,22,22,65,22,65,22,65,22,65,22,65,22,22,22,65,22,65,22,22,22,65,22,22,22,22,22,65,22,22,22,22,22,22,22,65,22,22,22,65,22,65,22,22,22,65,22,65,22,65,22,1527,347,87,22,3692}
                  {0,104,0,34,361,180,23,68,23,68,23,23,23,23,23,23,23,68,23,23,23,68,23,23,23,23,23,68,23,68,23,68,23,23,23,68,23,23,23,68,23,23,23,23,23,68,23,68,23,23,23,23,23,68,23,23,23,68,23,68,23,23,23,23,23,68,23,68,23,23,23,1590}
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    #44
                    Thanks @akbooer, although I’m ideally trying to get the output of that array to be something like this..
                    Power = "0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0ACD"
                    Power$1 = "0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C"
                    Power$2 = "0000 0068 0000 0022 0169 00B4 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0636’
                    Running the script you chafed above retuned this...
                    LuaTest 1.7
                    Results
                    No errors
                    Runtime: 55.4 ms
                    Code returned: nil
                    Print output
                    { [1]=0, [2]=112, [3]=0, [4]=50, [5]=128, [6]=64, [7]=16, [8]=16, [9]=16, [10]=48, [11]=16, [12]=16, [13]=16, [14]=16, [15]=16, [16]=16, [17]=16, [18]=16, [19]=16, [20]=16, [21]=16, [22]=16, [23]=16, [24]=16, [25]=16, [26]=16, [27]=16, [28]=16, [29]=16, [30]=16, [31]=16, [32]=16, [33]=16, [34]=48, [35]=16, [36]=16, [37]=16, [38]=16, [39]=16, [40]=16, [41]=16, [42]=16, [43]=16, [44]=16, [45]=16, [46]=16, [47]=16, [48]=48, [49]=16, [50]=16, [51]=16, [52]=16, [53]=16, [54]=48, [55]=16, [56]=16, [57]=16, [58]=16, [59]=16, [60]=16, [61]=16, [62]=16, [63]=16, [64]=16, [65]=16, [66]=16, [67]=16, [68]=48, [69]=16, [70]=16, [71]=16, [72]=48, [73]=16, [74]=16, [75]=16, [76]=48, [77]=16, [78]=48, [79]=16, [80]=48, [81]=16, [82]=48, [83]=16, [84]=16, [85]=16, [86]=16, [87]=16, [88]=48, [89]=16, [90]=16, [91]=16, [92]=48, [93]=16, [94]=48, [95]=16, [96]=16, [97]=16, [98]=48, [99]=16, [100]=48, [101]=16, [102]=48, [103]=16, [104]=2765 }
                    { [1]=0, [2]=108, [3]=34, [4]=2, [5]=347, [6]=173, [7]=22, [8]=22, [9]=22, [10]=22, [11]=22, [12]=22, [13]=22, [14]=22, [15]=22, [16]=22, [17]=22, [18]=22, [19]=22, [20]=65, [21]=22, [22]=22, [23]=22, [24]=65, [25]=22, [26]=65, [27]=22, [28]=65, [29]=22, [30]=65, [31]=22, [32]=65, [33]=22, [34]=22, [35]=22, [36]=65, [37]=22, [38]=65, [39]=22, [40]=22, [41]=22, [42]=65, [43]=22, [44]=22, [45]=22, [46]=22, [47]=22, [48]=65, [49]=22, [50]=22, [51]=22, [52]=22, [53]=22, [54]=22, [55]=22, [56]=65, [57]=22, [58]=22, [59]=22, [60]=65, [61]=22, [62]=65, [63]=22, [64]=22, [65]=22, [66]=65, [67]=22, [68]=65, [69]=22, [70]=65, [71]=22, [72]=1527, [73]=347, [74]=87, [75]=22, [76]=3692 }
                    { [1]=0, [2]=104, [3]=0, [4]=34, [5]=361, [6]=180, [7]=23, [8]=68, [9]=23, [10]=68, [11]=23, [12]=23, [13]=23, [14]=23, [15]=23, [16]=23, [17]=23, [18]=68, [19]=23, [20]=23, [21]=23, [22]=68, [23]=23, [24]=23, [25]=23, [26]=23, [27]=23, [28]=68, [29]=23, [30]=68, [31]=23, [32]=68, [33]=23, [34]=23, [35]=23, [36]=68, [37]=23, [38]=23, [39]=23, [40]=68, [41]=23, [42]=23, [43]=23, [44]=23, [45]=23, [46]=68, [47]=23, [48]=68, [49]=23, [50]=23, [51]=23, [52]=23, [53]=23, [54]=68, [55]=23, [56]=23, [57]=23, [58]=68, [59]=23, [60]=68, [61]=23, [62]=23, [63]=23, [64]=23, [65]=23, [66]=68, [67]=23, [68]=68, [69]=23, [70]=23, [71]=23, [72]=1590 }
                    Sorry to ask this, but how can that be achieved?
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      #45
                      I had been working on something like this, is it close?
                      local ircodearray =  {}
                      local rfile = io.open("mnt/nas/vera/text1.txt", "r")
                      for line in rfile:lines() do
                          local commandname = line:match("^Powe.*")
                      	local prontocode = line:match("^0000.*")
                          local ircodearray = {"local = " .. commandname, prontocode}
                      print(ircodearray)
                      • H Offline
                        H Offline
                        htcheng
                        If you're looking for a specific brand/model, you might try https://irdb.globalcache.com/Home/About. Registering is free and access to normal users has rate limited access to the DB, but it does contain IR codes which can be converted to Pronto codes via other free programs. I've used it for a number of codes for my devices.
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          #47
                          Thanks @htchemg - I’ve actually already tried that route, I had a GC-100 for years, but sadly they do not have the manufacturer and/or model I need listed. Hence I’m sadly trying this long winded route to discover what it is 😢
                          • parkercP Offline
                            parkercP Offline
                            parkerc
                            #48
                            I fear, I may have hit my Vera/Lua wall.
                            I seem to have been able to partially rework the output from IrScrutinizer, but I can’t seem to get it into an appropriate format for @a-lurker’s code to then run through them all in sequence..
                            Input file (text1.txt) from IrScrutinizer
                            Power
                            Power$1
                            Power$2
                            0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0019 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0019 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
                            Current Output file (text2.txt)
                            The ‘print’ looks positive, however I can’t seem to get each line in the correct format in the text2.txt file, it always spans 2 lines.
                            local Power
                            local Power$1
                            local Power$2
                            local Power$3
                             = "0000 006D 0011 000E 0013 005F 0013 0026 0026 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0227 0013 005F 0013 0026 0013 0013 0026 0013 0013 0026 0013 0013 0013 0013 0013 0013 0013 0013 0026 0026 0026 0026 0013 0013 0026 0026 0013 1054
                            Latest code is below.. All ideas/suggestions welcome
                            -- https://oc.cil.li/topic/1524-how-can-i-store-each-line-of-a-file-in-an-array-in-lua/#comment-6763
                            -- CP: does not Work
                            -- v0.9
                            function sendProntoCodeToBroadLinkDevice(prontoCode)
                               local BROADLINK_DEVICE_ID = 49
                               luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, BROADLINK_DEVICE_ID)
                            local write_file_path = "/mnt/nas/vera/text2.txt" -- # path to your file here
                            local read_file_path = "/mnt/nas/vera/text1.txt" -- # path to your file here
                            local pattern1 = "^.*Power.*$" -- # your pattern to find
                            local pattern2 = "^.*0000.*$" -- # your pattern to find
                            local matches = {}
                            io.open(write_file_path,"w+"):close()
                            local function contains(str, pattern)
                              return string.match(str, pattern) and true or false
                            for line in io.lines(read_file_path) do
                              if contains(line, pattern1) then
                            	  command = (line)
                            	-- table.insert(matches, line1)
                            	if contains(line, pattern2) then
                            		ProntoCode = (line)
                            	-- table.insert(matches, line1, line2)
                            	local irstr = command .. "" .. ProntoCode
                            	--print(irstr)
                            	print(string.format('local %s = "%s"\n',command,ProntoCode))
                            	local file = io.open(write_file_path, 'a')
                            	-- file:write(command .. "" .. ProntoCode .. "\n")
                            	-- file:write(irstr .. "\n")
                            	file:write(string.format('local %s = "%s"\n',command,ProntoCode))
                            	file:close()
                            local INTERVAL_SECS = 2
                            luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
                            • parkercP Offline
                              parkercP Offline
                              parkerc
                              Well, they say in life "nothing ventured, nothing gained" and thanks to this forum and stackoverflow, I’ve got a working solution.
                              Code is below, any feedback on optimisation is always appreciated.
                              io.open("/mnt/nas/vera/text5.txt", 'a'):close()
                              --local logFile = io.open(write_file_path, 'w')
                              local logs = {} -- We will use this to log the messages to log.txt later
                              local i = 1;for line in io.lines(read_file_path) do
                              if (line:find(pattern1) or not line:find('%A')) and line:len() > 1 then
                              	local powerref = line
                              	logs[#logs+ 1] = 'Command: ' .. powerref
                                elseif line:find(pattern2) then
                              	  local prontoCode = line
                              	  local x = 1 do
                              	  x = x + 1
                              	  local pause = os.clock()
                              	  print('"' ..prontoCode..'"')
                              	  luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, 49)
                                   --  x = x + 1
                                   --  local pause = os.clock()
                                    repeat until os.clock() > pause + 3
                              	  local xfile = io.open("/mnt/nas/vera/text5.txt", 'a')
                              		xfile:write(time .. " - " .. prontoCode .. "\n")
                              		xfile:close()
                              		 logs[#logs + 1] = 'Sequence: ' .. line
                                end; i = i + 1 -- Raise the line number
                              logFile:write(table.concat(logs, '\n'))
                              logFile:flush()
                                316
                                151.0k
