  3. Discover IR codes for lost remote
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
49 Posts 5 Posters 38.7k Views 5 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    #40
    Thanks so much @akbooer 🤩
    I’ve run it a couple of times now, but it doesn’t seem to write to the file? It prints to the screen ok, but not to the write?
    To get around that I’ve just been coping and pasting the print output into a text file
    I’m close to the final piece now, I’ve captured and converted all the ‘POWER’ codes listed across all of those .csv files and I’d like to convert them into a table, or .csv, with their associated command name as the variable name, so I can then call them.
    Example content of text1.txt (created by IrScrutinizer).
    Power
    0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0ACD
    Power$1
    0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
    Power$2
    0000 0068 0000 0022 0169 00B4 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0636
    And I’m now trying to get that above into a more usable format, such a Lua array/table or maybe another .csv. Below is th3 code I’ve been working on to do that, but i’m not having much success doing the conversion.
    function convertCodestoarray (filename)
      local lfs = require "lfs"
      local dir = "mnt/nas/vera/ircodes/"   -- the path to the files
      print(dir .. filename)
      for filename in lfs.dir(dir) do
        	if filename: match "%.txt$" then
    			for line in io.lines(dir .. filename) do
    				local params = "([^,]+)/n([^,]+)"
    				local codename, prontocode = params
    				local params = table.concat ({codename, prontocode}, ", ")
    				print(params)
    					local file = io.open("powerircodes.csv", 'a')
            			filename:write(params .. "\n")
    filename:close()
    convertCodestoarray("text1.txt")
    • parkercP parkerc
      Power
      Power$1
      Power$2
      				print(params)
      filename:close()
      @parkerc said in Discover IR codes for lost remote:
      No, the file is opened in the wrong mode... you should have spotted that. 😉
      local file = io.open ("/www/powerircodes.txt", “wb”)
      • parkercP Offline
        parkercP Offline
        parkerc
        Thanks again @akbooer 🤩
        Last ask 🤞- how would you convert the IrScrutinizer created file (the one with all the converted ProntoCodes posted above) into a list/table/array/.csv - that I can then use with @alurker’s original post for his Broadlink irsender ?
        • parkercP parkerc
          Last ask
          Last answer...
          A demo program that reads lines from a string with your data format and converts to tables of numbers.
          local t = [[
          Power
          Power$1
          Power$2
          local function decode(line)
            local code = {}
            for n in line: gmatch "%x+" do
              code[#code+1] = tonumber(n,0x10)
            return code
          for l in t: gmatch "[^\n]+" do
            if l: match "^%x+" then
              print(pretty(decode(l)))
          Gives this output:
          {0,112,0,50,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,48,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,48,16,48,16,16,16,48,16,48,16,48,16,2765}
          {0,108,34,2,347,173,22,22,22,22,22,22,22,22,22,22,22,22,22,65,22,22,22,65,22,65,22,65,22,65,22,65,22,22,22,65,22,65,22,22,22,65,22,22,22,22,22,65,22,22,22,22,22,22,22,65,22,22,22,65,22,65,22,22,22,65,22,65,22,65,22,1527,347,87,22,3692}
          {0,104,0,34,361,180,23,68,23,68,23,23,23,23,23,23,23,68,23,23,23,68,23,23,23,23,23,68,23,68,23,68,23,23,23,68,23,23,23,68,23,23,23,23,23,68,23,68,23,23,23,23,23,68,23,23,23,68,23,68,23,23,23,23,23,68,23,68,23,23,23,1590}
          • parkercP Offline
            parkercP Offline
            parkerc
            #44
            Thanks @akbooer, although I’m ideally trying to get the output of that array to be something like this..
            Power = "0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0ACD"
            Power$1 = "0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C"
            Power$2 = "0000 0068 0000 0022 0169 00B4 0017 0044 0017 0044 0017 0017 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0044 0017 0017 0017 0044 0017 0017 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0017 0017 0044 0017 0044 0017 0017 0017 0017 0017 0044 0017 0044 0017 0017 0017 0636’
            Running the script you chafed above retuned this...
            LuaTest 1.7
            Lua file: /etc/cmh-ludl/luatest.lua
            Results
            No errors
            Runtime: 55.4 ms
            Code returned: nil
            Print output
            { [1]=0, [2]=112, [3]=0, [4]=50, [5]=128, [6]=64, [7]=16, [8]=16, [9]=16, [10]=48, [11]=16, [12]=16, [13]=16, [14]=16, [15]=16, [16]=16, [17]=16, [18]=16, [19]=16, [20]=16, [21]=16, [22]=16, [23]=16, [24]=16, [25]=16, [26]=16, [27]=16, [28]=16, [29]=16, [30]=16, [31]=16, [32]=16, [33]=16, [34]=48, [35]=16, [36]=16, [37]=16, [38]=16, [39]=16, [40]=16, [41]=16, [42]=16, [43]=16, [44]=16, [45]=16, [46]=16, [47]=16, [48]=48, [49]=16, [50]=16, [51]=16, [52]=16, [53]=16, [54]=48, [55]=16, [56]=16, [57]=16, [58]=16, [59]=16, [60]=16, [61]=16, [62]=16, [63]=16, [64]=16, [65]=16, [66]=16, [67]=16, [68]=48, [69]=16, [70]=16, [71]=16, [72]=48, [73]=16, [74]=16, [75]=16, [76]=48, [77]=16, [78]=48, [79]=16, [80]=48, [81]=16, [82]=48, [83]=16, [84]=16, [85]=16, [86]=16, [87]=16, [88]=48, [89]=16, [90]=16, [91]=16, [92]=48, [93]=16, [94]=48, [95]=16, [96]=16, [97]=16, [98]=48, [99]=16, [100]=48, [101]=16, [102]=48, [103]=16, [104]=2765 }
            { [1]=0, [2]=108, [3]=34, [4]=2, [5]=347, [6]=173, [7]=22, [8]=22, [9]=22, [10]=22, [11]=22, [12]=22, [13]=22, [14]=22, [15]=22, [16]=22, [17]=22, [18]=22, [19]=22, [20]=65, [21]=22, [22]=22, [23]=22, [24]=65, [25]=22, [26]=65, [27]=22, [28]=65, [29]=22, [30]=65, [31]=22, [32]=65, [33]=22, [34]=22, [35]=22, [36]=65, [37]=22, [38]=65, [39]=22, [40]=22, [41]=22, [42]=65, [43]=22, [44]=22, [45]=22, [46]=22, [47]=22, [48]=65, [49]=22, [50]=22, [51]=22, [52]=22, [53]=22, [54]=22, [55]=22, [56]=65, [57]=22, [58]=22, [59]=22, [60]=65, [61]=22, [62]=65, [63]=22, [64]=22, [65]=22, [66]=65, [67]=22, [68]=65, [69]=22, [70]=65, [71]=22, [72]=1527, [73]=347, [74]=87, [75]=22, [76]=3692 }
            { [1]=0, [2]=104, [3]=0, [4]=34, [5]=361, [6]=180, [7]=23, [8]=68, [9]=23, [10]=68, [11]=23, [12]=23, [13]=23, [14]=23, [15]=23, [16]=23, [17]=23, [18]=68, [19]=23, [20]=23, [21]=23, [22]=68, [23]=23, [24]=23, [25]=23, [26]=23, [27]=23, [28]=68, [29]=23, [30]=68, [31]=23, [32]=68, [33]=23, [34]=23, [35]=23, [36]=68, [37]=23, [38]=23, [39]=23, [40]=68, [41]=23, [42]=23, [43]=23, [44]=23, [45]=23, [46]=68, [47]=23, [48]=68, [49]=23, [50]=23, [51]=23, [52]=23, [53]=23, [54]=68, [55]=23, [56]=23, [57]=23, [58]=68, [59]=23, [60]=68, [61]=23, [62]=23, [63]=23, [64]=23, [65]=23, [66]=68, [67]=23, [68]=68, [69]=23, [70]=23, [71]=23, [72]=1590 }
            Sorry to ask this, but how can that be achieved?
            • parkercP Offline
              parkercP Offline
              parkerc
              #45
              I had been working on something like this, is it close?
              local ircodearray =  {}
              local rfile = io.open("mnt/nas/vera/text1.txt", "r")
              for line in rfile:lines() do
                  local commandname = line:match("^Powe.*")
              	local prontocode = line:match("^0000.*")
                  local ircodearray = {"local = " .. commandname, prontocode}
              print(ircodearray)
              • H Offline
                H Offline
                htcheng
                If you're looking for a specific brand/model, you might try https://irdb.globalcache.com/Home/About. Registering is free and access to normal users has rate limited access to the DB, but it does contain IR codes which can be converted to Pronto codes via other free programs. I've used it for a number of codes for my devices.
                • parkercP Offline
                  parkercP Offline
                  parkerc
                  #47
                  Thanks @htchemg - I’ve actually already tried that route, I had a GC-100 for years, but sadly they do not have the manufacturer and/or model I need listed. Hence I’m sadly trying this long winded route to discover what it is 😢
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    #48
                    I fear, I may have hit my Vera/Lua wall.
                    I seem to have been able to partially rework the output from IrScrutinizer, but I can’t seem to get it into an appropriate format for @a-lurker’s code to then run through them all in sequence..
                    Input file (text1.txt) from IrScrutinizer
                    Power
                    Power$1
                    Power$2
                    0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0019 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0019 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
                    Current Output file (text2.txt)
                    The ‘print’ looks positive, however I can’t seem to get each line in the correct format in the text2.txt file, it always spans 2 lines.
                    local Power
                    local Power$1
                    local Power$2
                    local Power$3
                     = "0000 006D 0011 000E 0013 005F 0013 0026 0026 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0227 0013 005F 0013 0026 0013 0013 0026 0013 0013 0026 0013 0013 0013 0013 0013 0013 0013 0013 0026 0026 0026 0026 0013 0013 0026 0026 0013 1054
                    Latest code is below.. All ideas/suggestions welcome
                    -- https://oc.cil.li/topic/1524-how-can-i-store-each-line-of-a-file-in-an-array-in-lua/#comment-6763
                    -- CP: does not Work
                    -- v0.9
                    function sendProntoCodeToBroadLinkDevice(prontoCode)
                       local BROADLINK_DEVICE_ID = 49
                       luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, BROADLINK_DEVICE_ID)
                    local write_file_path = "/mnt/nas/vera/text2.txt" -- # path to your file here
                    local read_file_path = "/mnt/nas/vera/text1.txt" -- # path to your file here
                    local pattern1 = "^.*Power.*$" -- # your pattern to find
                    local pattern2 = "^.*0000.*$" -- # your pattern to find
                    local matches = {}
                    io.open(write_file_path,"w+"):close()
                    local function contains(str, pattern)
                      return string.match(str, pattern) and true or false
                    for line in io.lines(read_file_path) do
                      if contains(line, pattern1) then
                    	  command = (line)
                    	-- table.insert(matches, line1)
                    	if contains(line, pattern2) then
                    		ProntoCode = (line)
                    	-- table.insert(matches, line1, line2)
                    	local irstr = command .. "" .. ProntoCode
                    	--print(irstr)
                    	print(string.format('local %s = "%s"\n',command,ProntoCode))
                    	local file = io.open(write_file_path, 'a')
                    	-- file:write(command .. "" .. ProntoCode .. "\n")
                    	-- file:write(irstr .. "\n")
                    	file:write(string.format('local %s = "%s"\n',command,ProntoCode))
                    	file:close()
                    local INTERVAL_SECS = 2
                    luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
                    • parkercP Offline
                      parkercP Offline
                      parkerc
                      Well, they say in life "nothing ventured, nothing gained" and thanks to this forum and stackoverflow, I’ve got a working solution.
                      Code is below, any feedback on optimisation is always appreciated.
                      io.open("/mnt/nas/vera/text5.txt", 'a'):close()
                      --local logFile = io.open(write_file_path, 'w')
                      local logs = {} -- We will use this to log the messages to log.txt later
                      local i = 1;for line in io.lines(read_file_path) do
                      if (line:find(pattern1) or not line:find('%A')) and line:len() > 1 then
                      	local powerref = line
                      	logs[#logs+ 1] = 'Command: ' .. powerref
                        elseif line:find(pattern2) then
                      	  local prontoCode = line
                      	  local x = 1 do
                      	  x = x + 1
                      	  local pause = os.clock()
                      	  print('"' ..prontoCode..'"')
                      	  luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, 49)
                           --  x = x + 1
                           --  local pause = os.clock()
                            repeat until os.clock() > pause + 3
                      	local time = os.date("%Y-%m-%d %H:%M:%S")
                      	  local xfile = io.open("/mnt/nas/vera/text5.txt", 'a')
                      		xfile:write(time .. " - " .. prontoCode .. "\n")
                      		xfile:close()
                      		 logs[#logs + 1] = 'Sequence: ' .. line
                        end; i = i + 1 -- Raise the line number
                      logFile:write(table.concat(logs, '\n'))
                      logFile:flush()
                        163.7k
