  3. I'm bored :D
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
I run a B&B and am looking for a way to turn the lights off whenever a room is unoccupied for X amount of time. The guest should still be able to turn the lights on and off manually, but should not be able to disable the auto turn off feature if the room is unoccupied. I guess I am looking for a light switch with a built in presence sensor? I guess a presence sensor would be better as if it is a motion sensor, the lights may go off unwanted if the guest fails to make sufficient movement e.g. if the guest is lying down watching a film. Are there any products on the market that would work for my application?
Looking for Bluetooth device for smartphone audio transmission
Hello, I am in search of a device capable of using Bluetooth to connect with a smartphone and serve as its primary sound source on demand. This device should function similarly to conventional Bluetooth headphones, which automatically become the phone's sound output upon activation. However, this device should differ in that it transmits the audio signal to an amplifier via a jack, SPDIF, or similar connection. Alternatively, it could be an integrated amplifier that directly sends the signal to passive speakers. The control of this process should be manageable through an API such as MQTT, REST, MODBUS, or similar. Are you aware of any devices that operate in this manner? The concept is as follows: upon entering the bathroom, I would press a wall-mounted switch. This switch would send a signal to the Bluetooth device, prompting it to connect to my smartphone and seamlessly continue playing the audiobook I am currently listening to. Instead of using the phone's speakers, it would seamlessly start playing through ceiling-mounted speakers. Many thanks
I'm bored :D
10 Posts 7 Posters 943 Views 7 Watching
    What are the projects you're working on?
    Summer is over, and that (unfortunately) means more time indoor and (luckily) more time to build things.
    I have almost nothing in my backlog and it's boring 🙂
    I appreciate a couple of (crazy) ideas.
      For me I just removed the vera which I used as pure ser2net device for zigbee and replaced it with a conbee 2 stick. The idea is first to consolidate my 2 zigbee network and get rid of the philips hue 2 hub which would enable me to have only 1 zigbee mesh. If this is successful then I would work on bypassing home assistant for zigbee network control and bridge openLuup into deconz.
      If you really want a big project, you could look at doing deep neural video processing. This is a very large topic I invested a couple of months on and enabled me to replace video movement detection with specific object detections along with facial recognition. All done locally of course. Coding is done in C or Python. I know that C is right down your alley! 😉
      A little further down the road I am thinking about replacing all my amazon echo with a local version likely based on Rhasppy when that project gets a little bit more mature and I find the time and courage to make the jump.
      Other than that, everything just works... I have had no need to touch or tinker with anything...
        My once four, then three, and recently only two-Vera home system is now down to one, with Vera hosting my beloved four-button MiniMote hand Controllers, a few lights, and a couple of meter readers. About to clone this to a UZB and see how that goes. Shelly now doing some switches, lights, and timed thermostats.
        I really need a replacement (WiFi) for the MiniMotes, but don’t see anything suitable. May have to make my own (3D printer anyone?)
        Other than that, the Prolog-based plugin for openLuup HA logic is coming along very slowly.
        Not doing anything right now, though, since we have a power outage (internet runs on UPS.)
        • Black CatB Offline
          Black CatB Offline
          Black Cat
          I invested in a 3D Printer...eventually.
          Turns out there not that expensive after all. +1 to a Ender V2. Easy to put together and great youtube support.
          The hardest part has been learning CAD- Autodesk, probably should say the most frustrating part, but now fairly conversant and can design complex designs.
          That was my winter, now we are looking at Spring & Summer and the end of lockdown.
          The EnderV2 is turning out adapters and wall brackets, quality is better than good and is merchantable.
          aka Zedrally
            The problem may be that we are all caught in liminal time due to COVID.
            I had thought I would get the Sonos system to issues voice commands to Alexa but I'm not sure what the point would be, except for some idle amusement.
            Something else I would like to know; how to calculate the R value (insulation effectiveness) of our house (metric units only please). It seems to me that when you get a step change in the outside weather, which can be a significant step change where I live. Then the inside temperature decays exponentially to meet the new outside temperature. Depending on the R value of the house the decay will be rapid (poor insulation) or slow (good insulation). Any idea how to calculate the R value, given the outside temp step change delta and the inside temperature change that results after x time? A few points: assumes the outside weather changes abruptly. No heat sources inside the house or though windows. Convection of heat may affect results.
              Lately, I've
              • built an integration with SmartBot push buttons (with retry, ack and battery and status report back to luup)
              • bought a Kuando BusyLight and integrated into my routine (so, when I'm on a call, it automatically turns to red)
              • built an app with integrated notifications on my home PC (dark, entryways, etc) via MQTT.
              • built a couple of new wifi-based sensors (light, temp, humidity and distance)
              • finished my tablet dashboard
              • built a system to track electrical consumption, in preparation for solar
              • built a new system to rotate my exterior color lights (milight+hue)
              @rafale I'll probably do some image recognition for the cams (I did for a customer, but it was in cloud) and a couple of more sensors.
              @akbooer finding a wifi remote is not easy. because wifi isn't really suited for battery operated devices.
              @a-lurker summer here in South Italy wasn't bad as I was expecting. we managed to do very good, even if cases are rising again lately. I never got so much spare time for sure, since I used to travel a lot for work (and pleasure) and I'm at home, beach excluded, since my last vacation in Miami+Bahamas in February. I have voice enabled announcements via Alexa and my wife loves them. I have a good insulated house (very new), but I'm not sure it'd be easy to do.
                Lately, I've
                @therealdb said in I'm bored 😄:
                Indeed so. Curiously, this was the promise of ZWave - that is was low power. Ironic, then, then many of the major failings of Zwave (certainly in the Vera world) were based around battery devices (polling, or not, etc.)
                There are low power WiFi devices and (single) buttons, but truly hard to find anything more capable. Maybe that's the one things that will keep my Zwave system going (albeit on ZWay, not on Vera.)
                  I would not confuse the vera failures with zwave failures. Battery operated devices operate brilliantly with zwave. Vera's problem was around the background "maintenance" they thought was going to make user configuration easier. It just made it a complete nightmare.
                  There are now cheap low powered wifi devices but... I would still prefer not to mix up low bandwidth network for home automation with the high bandwidth of wifi as it will (at least until full wifi6 implementation is effective) eat up wifi bandwidth. It is more of a scalability issue than anything else. Once you start having a lot of devices, the wifi band airtime will start getting congested which is why for these types of appliances, I try to avoid wifi. The amount of wifi channels is also very limited as the trend is to broaden channels to allow more per device bandwidth and to also to use more and more channels to support more devices simultaneously...
                  • MatohlM Offline
                    MatohlM Offline
                    Matohl
                    This winter I will work on my project to get small ESP sensor connected to a RPi to warn me if the plans needs some water, in planning for several years. I will also as @therealdb work with the tablet dashboards- And integrate some electronics into my Millenium-Falcon, Tie-fighter models. (Yes, I'm still married) 😄
                      Finally fixed Mrs C's iPhone locator. Adding some more logic now we're actually going out of the house (for a while)
                      What I'm toying with now is some ideas for
                      a) Smart shower (assuming I get another job that means I need to get up and get in the shower)
                      b) IR control for scene setting per my old Philips Pronto and (to a lesser extent) my Harmony. The Harmony hub is the obvs choice, and given my Harmony One is on its last legs this may be first.
                        562
                      • Expose MSR entities
                      • Little Bobby tables...
                        727
                      • Gradually turn on lights.
                        966
                        56.0k
