  2. Comments & Feedback
  3. Removing Orange Notification
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
H
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Other Forum feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
36 Posts 5 Posters 23.1k Views 4 Watching
    Driving me mad, personally......
    This one took me right to the first thread. Middle of the thread happens quite a lot as well....
      So how do we get rid of them then?
      @CatmanV2
      The mission statement one i clicked and when i returned it had gone. I could not do the same with darkmode. @DesT removed the other from mobile view, which i appreciate. They are still at bottom of desck top view , but not as annoying there.
      @rafale77 , yes it tends to be the middle of the thread or possible the position the 2nd to last time i viewed the thread. It is annoying and will be hell with threads in there 100's.
        I've clicked on the mission statement. The box remains 😞
        • DesTD Offline
          DesTD Offline
          DesT
          guys.... the orange box will always be there except on mobile. There's no "click and hidden" feature!
          • DesTD Offline
            DesTD Offline
            DesT
            All the "sidebar" widget, 2x orange box + forum stats are hidden on mobile to keep the essential.
            ElcidE 1 Reply Last reply
              DesTD Offline
              DesTD Offline
              DesT
              @CatmanV2 said in Removing Orange Notification:
              Officially, you can't! But I think the "dark mode" I can remove it, it's there to help people with the new theme and the new night mode...
                (And the first unread problem seems to be getting worse)
                DesTD Offline
                DesTD Offline
                DesT
                The first unread, I need to double check, as I think it's working fine but I need to understand "HOW" it's working!
                • DesTD DesT
                  @DesT
                  The first unread works sometimes... like the others are reporting, it often also takes me to the middle of the thread, very rarely to the top. Not sure what is going on with it.
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    I think that, the "first unread", is related to a "timeout" on how long you are reading. I would need to ask more detail about that to the "nodeBB" team!
                      Well it makes no sense to me, and behaves differently from every other forum I use or have used. Would love to hear what they say
                      • DesTD DesT
                        therealdbT DesTD 2 Replies Last reply
                        • ElcidE Elcid
                          I agree with @Elcid. I will simply remote it, if possible. I'm a fan of minimalism and on a community forum that's even more important. Thanks for the hard work @DesT !
                          DesTD 1 Reply Last reply
                            Yes thanks for your efforts @DesT
                              Absolutely!
                              • ElcidE Elcid
                                DesTD Offline
                                DesTD Offline
                                DesT
                                @Elcid I did some test and looks like your issue is coming from a conflict with the old theme on the forum! Can you try the same thing using "Incognito mode" ?
                                From the screenshot, looks like with the width of your browser, you should be in "mobile view" and the sidebar shoud completely be hidden
                                • DesTD Offline
                                  DesTD Offline
                                  DesT
                                  I did something now!
                                  I disable the last orange box and I will try to put the mission of the forum in the footer. And I change the last widget (stats) to be visible only to super moderator team!
                                  • DesTD DesT
                                    wrote on last edited by Elcid
                                    #23
                                    @DesT, yes i am in mobile view. Here is screenshot in mobile view from cognito. There is no light bulb dark mode option. Browser firefox
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      The light bulb in mobile is under the "burger menu" that you don't have in screenshot 'cause you are too wide to see it.
                                      BUT, one thing for sure. You are having a "cache" issue 'cause you are having item on the left side that are supposed to be under your "avatar" at the top right icon!
                                      You should really try to reload the forum/page and force an empty cache! In Firefox you can try to hit F12 to display the DEV tools and then F5 to reload the page!
                                      F12 again to hide the DEV tools
                                        #25
                                        No sign of a hamburger.
                                        I cleared cache and refreshed when you changed dark mode, as the forum would not load. once i did forum loaded fine.
                                        I have done it again to be sure. This is mobile firefox so f12 and f5 have no effect.
                                        The menu on left only appears when i drag left any where on screen.So copy and paste is a problem
                                        Edit/ the menu problem has cleared its self.
                                        • DesTD Offline
                                          DesTD Offline
                                          DesT
                                          Just for fun of testing... can you try with another browser ?
                                            164.5k
