  2. Comments & Feedback
  3. Removing Orange Notification
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Other Forum feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
36 Posts 5 Posters 22.2k Views 4 Watching
  • ElcidE Offline
    ElcidE Offline
    Elcid
    how to remove this notification, it's on every page and i see no way to dismiss it.
    • DesTD Offline
      DesTD Offline
      DesT
      @Elcid I changed it! This orange box should be only visible in non-mobile as you are missing another one.
      Both of them are not "only on non-mobile"
      • ElcidE Offline
        ElcidE Offline
        Elcid
        Cheers, Yes i t would allow me to remove the forum mission statment one, but the dark mode notification would not go. Once again thank you
          So how do we get rid of them then?
          ElcidE DesTD 2 Replies Last reply
            (And the first unread problem seems to be getting worse)
            DesTD 1 Reply Last reply
              I don't really ever get to the first post of the thread but I either get to the first unread or it appears, to the middle of the thread it seems and it is not very consistent. It is indeed a bit weird.
                Driving me mad, personally......
                This one took me right to the first thread. Middle of the thread happens quite a lot as well....
                  ElcidE Offline
                  ElcidE Offline
                  Elcid
                  @CatmanV2
                  The mission statement one i clicked and when i returned it had gone. I could not do the same with darkmode. @DesT removed the other from mobile view, which i appreciate. They are still at bottom of desck top view , but not as annoying there.
                  @rafale77 , yes it tends to be the middle of the thread or possible the position the 2nd to last time i viewed the thread. It is annoying and will be hell with threads in there 100's.
                    I've clicked on the mission statement. The box remains 😞
                    • DesTD Offline
                      DesTD Offline
                      DesT
                      guys.... the orange box will always be there except on mobile. There's no "click and hidden" feature!
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        All the "sidebar" widget, 2x orange box + forum stats are hidden on mobile to keep the essential.
                        ElcidE 1 Reply Last reply
                          DesTD Offline
                          DesTD Offline
                          DesT
                          @CatmanV2 said in Removing Orange Notification:
                          Officially, you can't! But I think the "dark mode" I can remove it, it's there to help people with the new theme and the new night mode...
                            DesTD Offline
                            DesTD Offline
                            DesT
                            The first unread, I need to double check, as I think it's working fine but I need to understand "HOW" it's working!
                            • DesTD DesT
                              @DesT
                              The first unread works sometimes... like the others are reporting, it often also takes me to the middle of the thread, very rarely to the top. Not sure what is going on with it.
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                I think that, the "first unread", is related to a "timeout" on how long you are reading. I would need to ask more detail about that to the "nodeBB" team!
                                  Well it makes no sense to me, and behaves differently from every other forum I use or have used. Would love to hear what they say
                                  • DesTD DesT
                                    ElcidE Offline
                                    ElcidE Offline
                                    Elcid
                                    therealdbT DesTD 2 Replies Last reply
                                    • ElcidE Elcid
                                      I agree with @Elcid. I will simply remote it, if possible. I'm a fan of minimalism and on a community forum that's even more important. Thanks for the hard work @DesT !
                                      • ElcidE Offline
                                        ElcidE Offline
                                        Elcid
                                        Yes thanks for your efforts @DesT
                                          Absolutely!
                                            157.7k
