  2. Comments & Feedback
  3. Removing Orange Notification
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Other Forum feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
36 Posts 5 Posters 22.9k Views 4 Watching
  • ElcidE Elcid
    DesTD Offline
    DesTD Offline
    DesT
    @Elcid I did some test and looks like your issue is coming from a conflict with the old theme on the forum! Can you try the same thing using "Incognito mode" ?
    From the screenshot, looks like with the width of your browser, you should be in "mobile view" and the sidebar shoud completely be hidden
    ElcidE 1 Reply Last reply
    • DesTD Offline
      DesTD Offline
      DesT
      I did something now!
      I disable the last orange box and I will try to put the mission of the forum in the footer. And I change the last widget (stats) to be visible only to super moderator team!
      • DesTD DesT
        ElcidE Offline
        ElcidE Offline
        Elcid
        wrote on last edited by Elcid
        #23
        @DesT, yes i am in mobile view. Here is screenshot in mobile view from cognito. There is no light bulb dark mode option. Browser firefox
        • DesTD Offline
          DesTD Offline
          DesT
          The light bulb in mobile is under the "burger menu" that you don't have in screenshot 'cause you are too wide to see it.
          BUT, one thing for sure. You are having a "cache" issue 'cause you are having item on the left side that are supposed to be under your "avatar" at the top right icon!
          You should really try to reload the forum/page and force an empty cache! In Firefox you can try to hit F12 to display the DEV tools and then F5 to reload the page!
          F12 again to hide the DEV tools
          • ElcidE Offline
            ElcidE Offline
            Elcid
            #25
            No sign of a hamburger.
            I cleared cache and refreshed when you changed dark mode, as the forum would not load. once i did forum loaded fine.
            I have done it again to be sure. This is mobile firefox so f12 and f5 have no effect.
            The menu on left only appears when i drag left any where on screen.So copy and paste is a problem
            Edit/ the menu problem has cleared its self.
            • DesTD Offline
              DesTD Offline
              DesT
              Just for fun of testing... can you try with another browser ?
              • ElcidE Offline
                ElcidE Offline
                Elcid
                I will load another and try
                for your info the menu has returned.
                  I agree with @Elcid. I will simply remote it, if possible. I'm a fan of minimalism and on a community forum that's even more important. Thanks for the hard work @DesT !
                  DesTD Offline
                  DesTD Offline
                  DesT
                  @therealdb said in Removing Orange Notification:
                  Trying hard on that 😉 I think that being in lockdown for COVID19 give me more free time than before the lockdown 😉
                  • ElcidE Offline
                    ElcidE Offline
                    Elcid
                    Ok no menu in duck and go.
                    no option for dark mode
                    DesTD 1 Reply Last reply
                    • ElcidE Elcid
                      DesTD Offline
                      DesTD Offline
                      DesT
                      @Elcid Are you using all these on Android ?
                      • ElcidE Offline
                        ElcidE Offline
                        Elcid
                        Yes android 8 running on an android tv box
                        • ElcidE Elcid
                          DesTD Offline
                          DesTD Offline
                          DesT
                          @Elcid said in Removing Orange Notification:
                          So you don't have F12 for Dev tools in your Firefox ?
                          Are you able to completely clear the cache of your firefox under Android ? Looks like you are not a FAN of "Chrome" but can you try with Incognito mode under Chrome App ?
                          • ElcidE Offline
                            ElcidE Offline
                            Elcid
                            yes can clear cache from firefox settings, or through android app settings.
                            Tried chrome, no dark option, menu on left like in firefox.
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              I just did 2 tests. Android 7 on my wife tablet and works perfectly with Chrome. I try another Android 8 on a 27" touch screen and same thing. Works perfectly too!
                              For sure, it's related to the "cache" and the CSS not loading perfectly.
                              • DesTD DesT
                                ElcidE Offline
                                ElcidE Offline
                                Elcid
                                @DesT
                                i reset chrome, so when i start it shows the start up splash screen with welcome and a short tutorial.
                                I go incognito and go to SmartHome, not logged in and i get
                                I loggin
                                • ElcidE Elcid
                                  @DesT
                                  I loggin
                                  ElcidE Offline
                                  ElcidE Offline
                                  Elcid
                                  #36
                                  I drag screen right, from any where on the screen
                                    163.0k
