  4. Issue with this Night rule?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
10 Posts 2 Posters 1.6k Views 2 Watching
    I have a rule that turns on my interior porch entrance light when its night and the front door is opened.
    Its set to keep the light on for 1 minute and then turn it off.
    I've been back in the house for well over an hour but just noticed the porch light is still on and hasn't turned off.
    Its 21:17 pm here now.
    This is the rules summary card:
    I setup the Night rule as a Global Rule and its referenced in this rule.
    Any clues ?
    EDIT: I should add that this rule has worked OK previously and the light has turned off after I have entered and the minute has passed.
      Your "Civil Dusk till Civil Dawn" rule is showing false, and that will not meet the constraints. Can you show us that rule, too?
          Its not false but shows as false on my Porch light rule
            OK, using the new rule ID display, can you open a PR, and post the rules data files (storage/rules) for the two rules involved?
              By the way, there's nothing I can see in your screen shots that enforces a one minute time limit. Where's that?
              Looking at this again, it looks like the binary sensor hasn't tripped since 15:49, which would be before dusk. This explains why the dusk-dawn rule hasn't updated state -- that rule is in constraints, so the new state won't be fetched until the triggers go true and require that the constraints be evaluated. And since the binary sensor has been false since 15:49, it's expected that the constraint condition state would be "frozen" like this.
              I'm still getting used to looking at the constraints as well.
                @toggledbits said in Issue with this Night rule?:
                Where's that?
                In the Reaction, it turns the light on then I have a one minute delay and then it turns the light off
                  I'm not sure why that might be?
                  Vera itself detected that the door was opened and then closed at 8.02pm as it sent alerts to Telegram on my phone for both opened and closed.
                  Edit
                  Unless I didn't hard refresh the browser before taking screen shots.
                    Can MSR create a running log of when rules have been triggered?
                      The reactor.log file logs all rule sets and resets by default.
                      • Next Release?
