  4. Another install issue
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
22 Posts 5 Posters 5.6k Views 4 Watching
    Tarkus
    I am stuck at step 7 of
    New Install: Linux (various) - Bare Metal (without Docker)
    I do not see the file config/reactor.yaml in the reactor directory.
      Then you either skipped step 6, or you didn't do it correctly.
        Tarkus
        @toggledbits cp dist-config/* config/
        was entered without error
          Tarkus
          There were some errors after step 5. I have a log but cant seem to figure out how to attach it to this reply.
            Run the following commands and copy-paste the output in reply here:
            pwd
            ls -l
            ls -l dist-config
            ls -l config
              Tarkus
              Patrick there is really not an easy way that I know of to copy and paste so attached a picture.
                I'm asking this seriously, and in the friendliest way possible... I'm level-setting my expectations... are you new to Linux command line?
                  Tarkus
                  yes I have implemented nodejs on this device for another applications but I am a novice at linux. This is installed on my nvidia shield android tv box running termux.
                    OK. When a file reference/name is in the form "config/reactor.yaml", that means "a file called reactor.yaml in a subdirectory called config under the current directory". In Linux filenames, the "/" is a directory/path separator. Your screen shot shows that file is there in the config subdirectory.
                    I suggest you spend a little time looking at some general Linux command line tutorials. We can keep giving you specific instructions here, but it's better if you get the fundamentals of how the file system works and the basic commands that are most used in navigating the file system before you start working with MSR, at least at this stage. It's critical that you always know where you are in the file system, and where what you want is in the file system, and how to bridge the gap between them if necessary (i.e. construct a pathname that refers to the correct file).
                    In any case, you need a text editor. "nano" is a good choice, I think. You can just type "nano" by itself on the command line. If it takes you into an editor, it's installed and you're ready to go, just exit nano by typing CTRL-X. If you got an error saying that nano doesn't exist, you need to install it. Once available, you can edit the config file:
                    # This is a comment
                    # Use this form of the command if you are sitting in the "reactor" directory
                    nano config/reactor.yaml
                    # Or you can actually change directory to config and edit it there, two steps:
                    cd config
                    nano reactor.yaml
                      Well I learned something today.... I never knew the "dir" command existed in linux and thought it was a dos/windows command. I always used "ls" to list folder content. I am not familiar at all with the shield and I am wondering if it has a package distribution manager.
                        Tarkus
                        Sorry, did not realize config was referring to a directory. Got it can I copy reactor.yaml to my downloads folder ( I have access to that folder on my PC) then edit it using notepad ++ then copy it back?
                          Yes you can. As @toggledbits said though, it would be good to get familiar with the linux commands. As you will be configuring MSR, you may need to modify the config file quite often. Getting access to a text editor is essential and my previous post on the package distribution was to try to see if you can install packages (like nano) from the command line. It is essential when navigating and working on linux.
                            Tarkus
                            Yes I understand, just trying to wrap this up before I start my work day.
                              wrote on last edited by Elcid
                              Just to add if you are using android and termux, you do not need to do this via command line. you can use a file explorer to extract the download file, and to move the config file. you can also edit the the yml file. I use x-plorer app.
                              The only thing that needs to be done via command line is to run the app.
                              [edit] your android device would need to be rooted to do this though. location of reactor files /data/data/com.termux/files/home/reactor
                              • ElcidE Elcid
                                Tarkus
                                @elcid good to know. I have the x-plorer app. Thanks
                                  Ohh Android! like my oven... You can then also install an SSH server app so you can login to it from telnet/terminal and run everything from the command line. That's the other extreme.
                                    I think x-plorer has ssh capabilities, not sure is it acts a ssh server though. But termux probably does have an ssh addon
                                      @toggledbits, is the "configuration by yaml" a temporary measure, or permanent? I'm asking because I know by own experience that command line and text editing with it's need for precision is something that drives some to find other solutions. Especially apps that actually has a GUI. 🙂
                                      Think thats why i went for Vera instead of HA or openHAB back in the day.. 😉
                                        Tarkus
                                        Ok, install complete. Was able to access MSR via browser. Thanks for the help!
                                          Configuration by YAML is likely here to stay, but will not be the primary way of handling configuration. A "Settings" subsystem/UI is planned.
                                          • Next Release?
                                            1.0k
