  4. Running Lua Code ? And watching device properties?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
69 Posts 7 Posters 31.0k Views 6 Watching
  • T Tarkus
    I have been running Lua within my Vera reactor pretty successfully. In some cases the reason was to have some conditional logic on the activity side. I found that this enabled me to keep the condition side a bit simpler and clean. I was also running lua to send Global Cache IR codes to my older Tv's. I now am trying the CG plugin that Patrick sorted out for me. The small issue with that is I need to convert all my Global Cache codes to pronto hex. I only mention so others know it does not support CG codes. There is also some lua that I use to turn off my computer. In preliminary testing the big issue I see with lua in Vera scenes is stability. I tried moving some of my lua into scenes and invoking the scenes thru MSR and everything just became real unstable with Luup restarts. I understand that this may be issues with my Vera, etc... . I also had lua in Vera reactor activities that preceded delays or other devices commands and by moving the lua into a Vera scene will that mess with the timing? Will there be a lag on the Vera side in invoking the scene while MSR continues with the reaction? The bottom line for me is I will try to make this work and eliminates much of the lua that I can. Having some legacy devices with IR contol does not help the situation I still have a lot of work to do so I can't say if everything will work out. It will be a matter of functionality and stability for me otherwise I will just stick with Vera reactor until I can't anymore. I will say that I do wish there was lua support in MSR.
    Were you not using the GC100 plugin before? Because if you were, it should not work any differently through MSR. MSR only passes the string in whatever format. If GC100 understood other code types before (even though the action has "Pronto" in the name), it would still now. MSR doesn't modify or interpret that data.
      Tarkus
      @toggledbits No I was using Lua in Vera Reactor to pass the Global Cache codes. I have played around with the GC Plugin in the past but I have not used it in years up until MSR.
        FYI, I'm also trying to implement the "run lua" action for the (vera-specific) system device. That does not mean Lua will run in MSR -- it does not, can not, and will not. But Vera does give me the ability to pass it Lua and have it execute it. That fills me with dread, frankly, but if it's what you need, it can be done. It will also need a UI change to support it, since typing Lua into a small entry field won't due. If it works, it should make invoking functions in a Lua module (built as @therealdb has shown you to do) pretty easy.
        I'm sure this will be very handy for some users.
        I am good at the moment however, using the method therealdb showed me. Its working currently.
        I think you're missing what I'm saying. You don't need change your library structure or not do what @therealdb has suggested. It's a good, clean way to go. But if you do this from MSR right now as a Request action (that's what I assume you are doing) to run the function:
        http://ip-address:3480/data_request?id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunLua&Code=VeraScenes.turnLightsOn%28nil%29
        You can (21063 and after) just do this, assuming you've loaded the library in startup Lua:
        And if you haven't loaded it in startup Lua, you can just bring it in with the code, like this:
        T cw-kidC 2 Replies Last reply
        • K Offline
          K Offline
          kfxo
          @toggledbits This looks great. So much easier then having to write out the http request.
            Tarkus
              #60
              I thought you meant we could actually put the LUA code itself in to a MSR action "Set Reaction" and some how you were going to pass that to Vera.
              But I see what you meant now, so we still need to edit the VeraScenes.lua file and add our functions / LUA code etc.
              I can confirm the Play button works and the code is executed on my Vera Plus
              So instead of sending a HTTP Request to Vera to initiate the function we can now just specify the function in the MSR rule actions.
                You can, and that's exactly what's happening. Your call to your preloaded function is Lua code. You can also put this in and it will run on the Vera:
                function later()
                    luup.log("I'm running five seconds later!", 2)
                luup.log("I'm running now!")
                luup.call_delay( "later", 5 )
                You can put in any Lua you want. You can open a socket, send data, and close it. You can reload Luup (intentionally). You can write a file. No limits.
                The code structure proposed by @therealdb makes good sense and is just a better way to encapsulate those functions than to bury them in Reactor rules. It will make your maintenance easier to structure your code that way.
                  Even better then ! Best of both worlds.
                    This is how it will go:
                    That said, this won't work today, because I haven't yet connected the expressions to the action parameters (the {master_level} value in the dimming action won't work yet). That's coming, but not yet. You can, however, do exactly this in Vera Reactor to see how it works. It will work the same way in MSR.
                    Edit... let me explain how it works (on both Vera Reactor and MSR):
                    The expression keeps the current value of the master dimmer. So on my system, vera>device_105 is named "Virtual Dimmer 18". The trigger condition looks for any change in the dimming level of that dimmer. When it changes, the set reaction sets the current value (from the expression master_level) on the slave dimmer "Virtual Dimmer 20". Bob's your uncle.
                    Is this related to PR 0000005 ? "Set Variable action not yet implemented" Which is now Closed.
                      @cw-kid here we go: https://github.com/dbochicchio/vera/tree/master/Library
                      I've added a sample to RunLua as well, so this should serve well our future us when in need of it 😉
                      Tarkus
                      @therealdb said in Running Lua Code ? And watching device properties?:
                      Does this work with lua that is using functions? The following runs as standalone code but will not run from the library. I tested another block of lua without functions and that works in the library.
                      module("VeraScenes", package.seeall) -- TODO: personalize it
                      -- Function / Samsung_tv_power_on
                      function matrixtest()
                          luup.log('VeraScenes.matrixtest')
                      local socket = require("socket")
                      function tcpclose(tcp)
                       tcp:close()
                      function Delay1()
                      --[[HDMI Matrix B1--]]
                      tcp = assert(socket.connect("192.168.255.204", 4998))
                      tcp:send("sendir,1:3,1,38000,1,69,341,171,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,21,22,64,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,21,22,64,22,64,22,64,22,1493,341,85,22,3669" .. "\r\n")
                      luup.call_delay("tcpclose", 1050, tcp)
                      luup.call_delay("Delay1", 1)
                      function Delay2()
                      --[[HDMI Matrix B2--]]
                      tcp:send("sendir,1:3,1,38000,1,69,343,171,21,21,22,21,22,21,22,21,21,21,22,21,22,21,21,21,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,21,22,21,22,21,21,22,21,21,22,63,22,21,22,63,22,63,22,63,22,1528,342,85,22,1528" .. "\r\n")
                      luup.call_delay("Delay2", 10)
                      • T Tarkus
                         tcp:close()
                        function Delay1()
                        function Delay2()
                        @tarkus I have also seen the same issue / limitation.
                        Seems if your LUA code has functions within it already, you can't use that code in the VeraScenes.lua file as it doesn't run the code.
                        I've had to run from MSR some Vera scenes with that LUA code instead for now.
                        Perhaps we are both doing it incorrectly which is quite possible.
                          #66
                          It's not a limitation. It's the way Lua works, combined with one way Luup is broken.
                          The problem is that you are declaring your delay callback/handler function in a module. It is therefore not a global function, it is a module function -- it is scoped within the module, not globally. To access functions inside a module, you have to use modulename.functionname(arguments), as you know, and the same is true for the delay handler/callback.
                          But the way Vera implemented luup.call_delay(), it takes a function name as a string, rather than a function reference. The function, therefore, has to be global. And it's not global, it's in a module.
                          One way to solve this problem (which all plugins experience, too, by the way) is to make a global alias. That means in your startup Lua, you do something like this:
                          mymodule = require( "mymodule" )         -- this line loads your module
                          -- Create a global alias for my delay handler
                          mymodule_delayhandler = mymodule.delayhandler
                          Then, in your module, instead of doing luup.call_delay( 'delayhandler', 5 ) you have to do luup.call_delay( 'mymodule_delayhandler', 5 ). This makes the delay use your global alias instead of the function name directly (which it can't).
                            Tarkus
                            So further testing seems to indicate that it is not the function causing the issue but rather either the multiple delays or just something in the structure of my code.
                              Thanks I will try that Global alias in my code. Both myself and Tarkus have a lot of delays in our code I think.
                                #69
                                Just trying this "Global Alias" for function delays, for the first time, but I can't get it working. I must be doing something wrong.
                                In the top of my VeraScenes.lua file I have added this code:
                                --Away Mode Scene
                                function mymodule_delayhandler()
                                local status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 419) --Status of Safe to Arm virtual switch
                                if status == "0" then --Safe to Arm
                                  luup.inet.wget("http://SEND-TTS-MESSAGE1")
                                else --Not Safe to Arm
                                  luup.inet.wget("http://SEND-TTS-MESSAGE2")
                                luup.call_delay( 'mymodule_delayhandler', 30 )
                                The test code checks the status of a virtual switch and sends a different HTTP request / TTS announcement etc.
                                I wanted a 30 second delay before anything happens at all.
                                When I call this function from a MSR rule by using
                                VeraScenes.mymodule_delayhandler()
                                I can hear the TTS announcement right away, so my 30 second delay is not happening.
                                What am I doing wrong?
                                @Tarkus Did you get this working?
                                  162.3k
