  3. OpenLuup unavailable
openLuup email server
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup: Version Log
openLuup
ZWaveJS and MQTT
openLuup
Awesome MQTT - GitHub list
openLuup
openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
openLuup
openLuup
openLuup and room names
openLuup
openLuup
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
openLuup
openLuup
AltUI access over VPN
openLuup
openLuup
OpenLuup installation
openLuup
Unexpected stop of openLuup
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
88 Posts 6 Posters 56.4k Views 6 Watching
    Thanks for reporting that.
    I see that you have two essentially identical handlers. This is not a problem, but I would choose to move that processing to a helper function, indexing the device number list with the received topic.
    You say that you’ve seen this on several consecutive days. Does it always happen at the same time?
    To interpret the log:
    • the sending of a published message to TasmotaC02Ax has failed, because it found that the socket was closed.
    • this might indicate an issue with that device, or a timeout.
    • as a result, the server has cancelled the subscriptions from that device.
    The server is designed to cope with this situation, and I’ve tested clients going up and down all the time, without a problem. Nonetheless, the only mechanism that I know of which can totally freeze a system is an incomplete socket transaction due to network issues. AFAIK, there haven’t been any recent changes to other socket handling code (HTTP server, and the like.)
    ArcherS
    @akbooer I grabbed the logs from yesterday also and it is not exactly the same time, it was 04:22 if I read the logs correctly.
    I do not have the logs from the day before, but it was ok in the evening and frozen in the morning at approx 07:00 when I checked.
    As it seems it was two devices (TasmotaCO2Ax and TasmotaCO2An) that got an error.
    2021-03-17 04:22:26.339   luup.variable_set:: 236.urn:micasaverde-com:serviceId:GenericSensor1.CurrentLevel was: 587 now: 593 #hooks:0
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3e8cfd8
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d43678a8
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3e375d8
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3cf1848
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3dc5a88
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d46e2698
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d40adfc8
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d45a96a8
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3a55748
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3192208
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3f40118
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3b455a8
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3ea7548
    2021-03-17 04:22:26.340   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d47471d8
    2021-03-17 04:22:26.341   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d3b92588
    2021-03-17 04:22:26.341   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d37022a8
    2021-03-17 04:22:26.341   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d37bc3e8
    2021-03-17 04:22:26.341   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d43b3068
    2021-03-17 04:22:26.341   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d4d6c0f8
    2021-03-17 04:22:26.341   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d40f7b68
    2021-03-17 04:22:26.341   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5580d47249a8
    2021-03-17 04:22:26.341   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x5580d3abfcb8
    2021-03-17 04:22:26.341   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x5580d3abfcb8
    2021-03-17 04:22:26.341   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x5580d4268eb8
    2021-03-17 04:22:26.341   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x5580d4268eb8
    2021-03-17 04:22:26.341   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x5580d47d0f18
    2021-03-17 04:22:26.341   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x5580d47d0f18
    2021-03-17 04:22:26.341   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=175&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=44.1 HTTP/1.1 tcp{client}: 0x5580d3ab86f8
    2021-03-17 04:22:26.342   luup.variable_set:: 175.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 44.1 now: 44.1 #hooks:0
    2021-03-17 04:22:26.342   openLuup.server:: request completed (2 bytes, 1 chunks, 0 ms) tcp{client}: 0x5580d3ab86f8
    2021-03-17 04:22:26.344   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x5580d3718798
    2021-03-17 04:22:26.344   openLuup.mqtt:: closed tcp{client}: 0x5580d3718798
    2021-03-17 04:22:26.344   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax/# tcp{client}: 0x5580d3718798
    2021-03-17 04:22:26.344   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x5580d3718798
    2021-03-17 04:22:26.344   openLuup.mqtt:: TasmotaCO2Ax UNSUBSCRIBE from cmnd/TasmotaCO2Ax_fb/# tcp{client}: 0x5580d3718798
    2021-03-17 04:22:26.344   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/TasmotaCO2Ax/POWER : closed
    2021-03-17 04:22:26.344   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x5580d3faa808
    2021-03-17 04:22:26.344   openLuup.mqtt:: closed tcp{client}: 0x5580d3faa808
    2021-03-17 04:22:26.344   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An_fb/# tcp{client}: 0x5580d3faa808
    2021-03-17 04:22:26.344   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An/# tcp{client}: 0x5580d3faa808
    2021-03-17 04:22:26.344   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x5580d3faa808
    2021-03-17 04:22:26.344   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/TasmotaCO2An/POWER : closed
      Ooh, that’s interesting. That’s an awful lot of HTTP sockets being closed. I assume you don’t actually have many active HTTP connections at night. I think your system might be running out of file descriptors (which are used by the socket library.). This gives me somewhere to look...
        ArcherS
        @akbooer I have some 10 external devices reporting temperature etc to some 35 devices in OpenLuup. The sockets in the log are for the updates of these devices.
        Currently they are doing this via http, the intention is to move most of these to Mqtt, hopefully that will off load the http socket.
        When you say it, when I tested the Mqtt bridge from @therealdb I also had some problems with http endpoint crashes (see the posts around January 30:th in this thread).
        So looking at the socket sounds like a good idea.
        I will do some more tests to try and get some more info also.
          Also interesting!
          You're able to play with the backlog queue length in the HTTP (and any other) server too. Default is 2000, I don't know why I chose that, it is perhaps too big. But you can use this startup configuration line to change that:
          luup.atttr_set ("openLuup.HTTP.Backlog", 2000)         -- queue length
          see: http://w3.impa.br/~diego/software/luasocket/tcp.html#listen
          Might be interesting to see if this makes any difference (eg. make it a lot smaller.)
          Your help is much appreciated, since this is something that I can't reproduce at random on my own systems.
            @ArcherS
            The latest development v21.3.18 has added a little log analysis tool to the log console pages. It shows the maximum gap between log entries and the time at which that ocurred. In normal operation this should be less than 120 seconds (since openLuup writes cpu and memory statistics at that rate.)
            Should make it easier to spot any large breaks in the logs (obviously not if the entire system is frozen!)
              @ArcherS
              ArcherS
              @akbooer I installed it, will check it a few times tonight.
              • A ArcherS
                ArcherS
                I had the same crash this night. This time it became unavailable at 03:51.
                Last night I reinstalled the two Tasmota sensors I added before the crash so that they have the same Tasmota release as the older sensor that I had for the initial tests when it did not crash. This made no difference, so I can rule that one out.
                When looking in the log file from before the crash it looks very similar:
                021-03-19 03:51:48.344   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6338f7778
                2021-03-19 03:51:48.344   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6348fa9a8
                2021-03-19 03:51:48.344   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b63427b0d8
                2021-03-19 03:51:48.344   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b634b6da68
                2021-03-19 03:51:48.344   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b632a24e88
                2021-03-19 03:51:48.344   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b63443ef78
                2021-03-19 03:51:48.348   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55b633f49218
                2021-03-19 03:51:48.348   openLuup.mqtt:: closed tcp{client}: 0x55b633f49218
                2021-03-19 03:51:48.348   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55b633f49218
                2021-03-19 03:51:48.348   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55b633f49218
                2021-03-19 03:51:48.348   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55b633f49218
                2021-03-19 03:51:48.348   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/tasmota_test/POWER : closed
                At 08:38 it crashed again, this is the first time it has crashed so soon again:
                21-03-19 08:38:41.016   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=192&id=variableset&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=39.4 HTTP/1.1 tcp{client}: 0x55beb3bcdbd8
                2021-03-19 08:38:41.016   openLuup.server:: GET /data_request?id=lu_action&DeviceNum=164&id=variableset&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=-2.1 HTTP/1.1 tcp{client}: 0x55beb3da8618
                2021-03-19 08:38:41.016   luup.variable_set:: 192.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 38.6 now: 39.4 #hooks:0
                2021-03-19 08:38:41.016   openLuup.server:: request completed (2 bytes, 1 chunks, 0 ms) tcp{client}: 0x55beb3bcdbd8
                2021-03-19 08:38:41.016   luup.variable_set:: 164.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: -2.1 now: -2.1 #hooks:0
                2021-03-19 08:38:41.017   openLuup.server:: request completed (2 bytes, 1 chunks, 0 ms) tcp{client}: 0x55beb3da8618
                2021-03-19 08:38:41.022   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55beb3c83ca8
                2021-03-19 08:38:41.022   openLuup.mqtt:: closed tcp{client}: 0x55beb3c83ca8
                2021-03-19 08:38:41.022   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An_fb/# tcp{client}: 0x55beb3c83ca8
                2021-03-19 08:38:41.022   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55beb3c83ca8
                2021-03-19 08:38:41.022   openLuup.mqtt:: TasmotaCO2An UNSUBSCRIBE from cmnd/TasmotaCO2An/# tcp{client}: 0x55beb3c83ca8
                2021-03-19 08:38:41.022   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/TasmotaCO2An/POWER : closed
                I have also checked the log analysis tool and could see one device that was often very slow. This is temp data from a Shelly Uni brought in with Sitesensor. I notised the Shelly being very slow also when accessing via the webpage.
                I could see the following in the log file just before the the first crash:
                # lines: 1214, maximum gap: 42.646s @ 2021-03-19 03:51:46.785
                2021-03-19 03:51:04.137   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LastRun was: 1616121064 now: 1616122264 #hooks:0
                2021-03-19 03:51:04.137   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LastQuery was: 1616121064 now: 1616122264 #hooks:0
                2021-03-19 03:51:04.137   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LastEval was: 1616121064 now: 1616122264 #hooks:0
                2021-03-19 03:51:04.137   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Last query OK now: Requesting JSON... #hooks:0
                2021-03-19 03:51:04.137   luup_log:206: SiteSensor: Requesting JSON data
                2021-03-19 03:51:04.137   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 03:31:04: SiteSensor: Requesting JSON data|03:31:04: SiteSensor: "GET" "http://192.168.1.31/status", headers={  }|0... now: 03:51:04: SiteSensor: Requesting JSON data #hooks:0
                2021-03-19 03:51:04.138   luup_log:206: SiteSensor: "GET" "http://192.168.1.31/status", headers={  }
                2021-03-19 03:51:04.138   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 03:51:04: SiteSensor: Requesting JSON data now: 03:51:04: SiteSensor: Requesting JSON data|03:51:04: SiteSensor: "GET" "http://192.168.1.31/status", headers={  } #hooks:0
                2021-03-19 03:51:46.785   luup_log:206: SiteSensor: Response is 908 bytes in "/tmp/Q_SiteSensor_206.txt"
                2021-03-19 03:51:46.785   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 03:51:04: SiteSensor: Requesting JSON data|03:51:04: SiteSensor: "GET" "http://192.168.1.31/status", headers={  } now: 03:51:04: SiteSensor: Requesting JSON data|03:51:04: SiteSensor: "GET" "http://192.168.1.31/status", headers={  }|0... #hooks:0
                2021-03-19 03:51:46.786   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Requesting JSON... now: Parsing response... #hooks:0
                2021-03-19 03:51:46.787   luup.set_failure:: status = 0
                2021-03-19 03:51:46.787   luup.variable_set:: 206.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                2021-03-19 03:51:46.787   luup.variable_set:: 206.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                2021-03-19 03:51:46.787   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Parsing response... now: Retrieving last response... #hooks:0
                2021-03-19 03:51:46.788   luup_log:206: SiteSensor: Eval #1: "response.ext_temperature[\"0\"].tC"=(number)24.44
                2021-03-19 03:51:46.788   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 03:51:04: SiteSensor: Requesting JSON data|03:51:04: SiteSensor: "GET" "http://192.168.1.31/status", headers={  }|0... now: 03:51:04: SiteSensor: Requesting JSON data|03:51:04: SiteSensor: "GET" "http://192.168.1.31/status", headers={  }|0... #hooks:0
                It was again very slow just before the second crash:
                # lines: 1598, maximum gap: 46.871s @ 2021-03-19 08:38:34.554
                2021-03-19 08:37:47.682   luup_log:206: SiteSensor: "GET" "http://192.168.1.31/status", headers={  }
                2021-03-19 08:37:47.682   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 08:37:47: SiteSensor: Requesting JSON data now: 08:37:47: SiteSensor: Requesting JSON data|08:37:47: SiteSensor: "GET" "http://192.168.1.31/status", headers={  } #hooks:0
                2021-03-19 08:38:34.554   luup_log:206: SiteSensor: Request returned no data, status 500
                2021-03-19 08:38:34.554   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 08:37:47: SiteSensor: Requesting JSON data|08:37:47: SiteSensor: "GET" "http://192.168.1.31/status", headers={  } now: 08:37:47: SiteSensor: Requesting JSON data|08:37:47: SiteSensor: "GET" "http://192.168.1.31/status", headers={  }|0... #hooks:0
                2021-03-19 08:38:34.554   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.Failed was: 0 now: 1 #hooks:0
                2021-03-19 08:38:34.554   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.FailedSince was:  now: 1616139514 #hooks:0
                2021-03-19 08:38:34.554   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.LastFail was: 1616052193 now: 1616139514 #hooks:0
                2021-03-19 08:38:34.555   luup.set_failure:: status = 1
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 1 #hooks:0
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 1616139514 #hooks:0
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1616052265 now: 1616139514 #hooks:0
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:micasaverde-com:serviceId:SecuritySensor1.ArmedTripped was: 0 now: 1 #hooks:0
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Requesting JSON... now: Retrieving last response... #hooks:0
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Retrieving last response... now: Last query failed, HTTP status 500 #hooks:0
                2021-03-19 08:38:34.555   luup.variable_set:: 206.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 1 now: 1 #hooks:0
                After the second crash I deactivated the Sitesensor fetching this data from the Shelly. At least I have not seen so long delays after that.
                I have not yet changed the server backlog.
                I will continue to do some testing, but I am not quite sure what I am chasing at the moment.
                  OK, well thanks again for all that. I will take a while to consider this. However, my first suggestion would anyway have been to disable SiteSenso, if at all possible, and see how it goes.
                  Once again, there is nothing amiss with a break in the log of up to 120s, and, indeed, in my latest edit (internal, as yet) I have disabled the gap warning message unless is exceeds 120 seconds.
                    ArcherS
                    @akbooer yes that was my thought also and see how it goes.
                    Btw I typically have delays of 2-4 seconds. At times a bit longer, those often being Sitesensors or Netmon pinging PCs that are offline.
                    That Shelly was the one device often being really slow. In fact it is often slow accessing via the browser also.
                    The strange thing is that all the devices have been up and running on my system for a really long time, but maybe adding the Mqtt on top was the last small straw. Strange anyway.
                      You mention a slow Shelly. This should not be a problem, but, again, worth just taking it out of the loop sometime? Why is it 'slow'?
                        ArcherS
                        @akbooer I do not fully know. It is a Shelly Uni with two relays and one temp sensor.
                        I have read so-so reports on the Shelly Uni in fact.
                        It is situated close to the wifi access point, but I moved it a bit just now and it got better wifi quality numbers.
                        It is sitting in the midst of the electrical central, could be one reason perhaps.
                        The idea is to move it to Mqtt for the temp reporting and then it should work better. I turned off that Sitesensor for now to test if it helps anything.
                          That's great, thanks. Just to let you know that I am taking this very seriously and I now have a fairly continuous stream of UDP updates going from my VeraLite to three different openLuup systems (Rpi, BeagleBone Black, Synology Docker) via the UDP -> MQTT bridge, with MQTT Explorer running on an iMac subscribed to one or other of those. From time to time the iMac sleeps, so the Explorer disconnects and then later reconnects. All openLuup instances are running the latest v21.3.19 looking for large gaps in the logs (or, indeed, a system freeze.)
                          So I am stress-testing this as far as I can without having your exact configuration.
                            @ArcherS
                            Can you just remind me what machine architecture you’re running on?
                              @ArcherS
                              ArcherS
                              @akbooer I'm running on an an old 2,27x4 GHz Fujitsu i3 Esprimo SFF PC with Ubuntu 18.04.5 and 4GB RAM and a 120 GB SSD.
                              My Z-way server is on a separate Raspberry Pi 3B+ with a Razberry board. Then one old UI5 Vera Lite and a UI7 Vera Plus, both almost completely offloaded, just a few virtual devices left on them.
                              • A ArcherS
                                ArcherS
                                This morning no crash. Not sure which of the changes I made that made the difference. Still good progress and something to continue working from.
                                This is what I did yesterday:
                                • Updated to OpenLuup 21.3.19 from 21.3.18
                                • Removed the line luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", "0") from Lua Startup. I tested reloading without the line and it was not needed anymore as it seems
                                • Deactivated a few Sitesensors; the slow Shelly Uni, one fetching weather data and three more fetching some local data
                                • Deleted two devices from Netmon that does not exist anymore, i.e. never respond to ping
                                • Cut the power to my three test Mqtt devices, i.e. no active Mqtt devices reporting anything over Mqtt all night
                                  Progress indeed. A slow build back should isolate the culprit.
                                  For my part, I’ve spotted a difference in behaviour between my RPi and Docker instances when there’s a network outage, resulting in an error message "no route to host" on the RPi which blocks the system for longer than 2 minutes. Needs further investigation.
                                    ArcherS
                                    @akbooer yes exactly my plan. I started one of the Mqtt sensors this morning to see what happens. No other changes until tomorrow is the plan. 🙂
                                    Interesting finding on the network outage!
                                      @ArcherS
                                      The latest development version v21.3.20 has a new console page openLuup > System > Required which shows key system modules, and also those required by each plugin.
                                      I am seeing some small version differences between my systems, but I don't think this is the issue. I would, nevertheless, be interested in your version of this page:
                                      Incidentally, this system (running in a Docker on my Synology NAS) ran overnight with over 100,000 MQTT messages sent to MQTT Explorer, totalling over 18 Mb of data without any issues at all.
                                      A rafale77R 2 Replies Last reply
                                        @ArcherS
                                        ArcherS
                                        @akbooer I installed v2.3.20, this is what it shows:
                                        Your data sounds promising. 🙂
                                        I can add that despite the problems my system still feels really fast when it is up and running.
                                        M 1 Reply Last reply
                                          @ArcherS
                                          @akbooer
                                          Just for the sake of sharing mine:
                                            154.0k
