  3. Need help backing up Raspberry Pi
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
21 Posts 5 Posters 8.2k Views 5 Watching
    Exactly the kind of tool I'd use (although CCC on the Mac basically means you don't have to) but figured the lack of user friendliness would be a down point here 😉
    ArcherS
    In Win32DiskImager there is a option for "read only allocated partitions". It is shown in the instruction linked from this thread.
    The same instruction also describes how to use Gparted in Linux to resize the .img if so required.
    • A ArcherS
      @archers said in Need help backing up Raspberry Pi:
      I did not tick that box as you can see in my screen shot above
        Don't forget that you're not looking at discs here. You're looking at partitions and mount points.
        What I am seeing is you've got a full 64G SD allocated and mounted to various points in your file system. Most of it is in /root and most of it is unused.
        As to why you ended up with a 27G backup, I have no idea other than Windows is probably not terribly happy reading Linux file systems and partition info. It was never terribly well supported.
        I don't really know many Windows tools these days, being a dyed in the wool BSD / Linux guy.
        If you only have Windows, I used to use Acronis (many years back). The other thing you could do is use a live Linux CD and use one of the tools there. Even the terribly basic dd would be able to do it.
        I would expect though that a properly functioning tool would create a 7Gish backup file. So yes, something is amiss. Can't tell if that means your backup is non-functional or not, though.
        Have you got another SD card? Restore to that, shut the pi down and try and boot from the newly restored card if you need to test.
        @catmanv2 said in Need help backing up Raspberry Pi:
        No I haven't. Not the same size anyway.
        I think I will buy another SanDisk 64GB SD card and make sure I can actually restore to a new card etc.
          @cw-kid said in Need help backing up Raspberry Pi:
          That's a sensible approach anyway.
          As for the 'Read only allocated partitions' it seems that Windows struggles to see the Pi partition (other than /boot) as allocated....
            I have got a USB stick with an Ubuntu desktop Live on it. I could run that up on my laptop instead.
            And then maybe use a different tool to do the job.
              You could indeed!
                I found these instructions for Linux / Ubuntu here using the dd command. Think I will give that a try.
                  Just make sure you get of and if correct 🙂
                  • toggledbitsT Online
                    toggledbitsT Online
                    If you'd run dd on an Ubuntu laptop for images, you might consider installing and running partclone instead. It's the workhouse underlying Clonezilla, and it will produce smaller backup images (it only copies used space; dd copies, all blocks used or not).
                    To make an image of a disk (/dev/sda2 in this example):
                    partclone -c -o /path/to/image-output -s /dev/sda2
                    And to restore that image later (same target device):
                    partclone -r -s /path/to/image-input -O /dev/sda2
                    Since the images can get very large (and may even grow larger than the filesystem allows), you can compress and split the image like this:
                    partclone -c -s /dev/sda2 -o - | gzip -c | | split -a 2 -b 2G - /path/to/imagefile.gz.
                    This will compress the output and split it into 2GB files, each having a '.gz.xx' ending, where xx is a two-letter code that keeps the parts sorted. To restore it:
                    cat /path/to/imagefile.gz.* | gunzip -c | partclone -r -s - -O /dev/sda2
                    • Black CatB Offline
                      Black CatB Offline
                      Black Cat
                      A simple to use "cloner" is Balena Etcher - it's gotten me out of trouble many times.
                      aka Zedrally
                      • Black CatB Black Cat
                        @black-cat said in Need help backing up Raspberry Pi:
                        Mac only, though, isn't it?
                          Black CatB Offline
                          Black Cat
                          No, I use Windows.
                          aka Zedrally
                            No, I use Windows.
                            No, I use Windows.
                            Every day's a school day! 🙂
                              632
                              146.9k
