  3. Need help backing up Raspberry Pi
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
21 Posts 5 Posters 8.9k Views 5 Watching
    @cw-kid a decent imager won't make your backup bigger, i.e. it won't back up the empty space. That being said, do you have some kind of limitation on your backup size? 64G is not exactly big on the current scale of things.
    If run df -h it will give you human readable sizes 😉 My reading of that is that it's currently 64G give or take, which is what you'd expect, but I'm not working at my best due to side effects 🙂
    Do df -h and see what the numbers come up as.
      @catmanv2
      59GB with 5.7G used ?
      So why did this Win32 Disk Imager program create a 27.4GB .img file ?
      If there is better imager program I should be using? I can swap to using that.
      The portable disk I stored the .img backup file on, is large enough to cope with a single .img file of 64GB in size if need be.
        Don't forget that you're not looking at discs here. You're looking at partitions and mount points.
        What I am seeing is you've got a full 64G SD allocated and mounted to various points in your file system. Most of it is in /root and most of it is unused.
        As to why you ended up with a 27G backup, I have no idea other than Windows is probably not terribly happy reading Linux file systems and partition info. It was never terribly well supported.
        I don't really know many Windows tools these days, being a dyed in the wool BSD / Linux guy.
        If you only have Windows, I used to use Acronis (many years back). The other thing you could do is use a live Linux CD and use one of the tools there. Even the terribly basic dd would be able to do it.
        I would expect though that a properly functioning tool would create a 7Gish backup file. So yes, something is amiss. Can't tell if that means your backup is non-functional or not, though.
        Have you got another SD card? Restore to that, shut the pi down and try and boot from the newly restored card if you need to test.
          Just to toss another alternative in here, I use Clonezilla for imaging just about everything. It's not very user-friendly; you need to know a bit, like be able to correctly and surely identify which disk (/dev/sda b c d e...) is the source and which is the target, but it's a wrapper for standard tools (partclone, mostly) that do a good job of making filesystem images that back up only the used space. It also automatically grows and shrinks filesystems to new target partitions (if they fit) on restores, etc. You just make a boot CD/DVD or USB stick and off you go. It supports pretty much all filesystem types (msdos, ext2/3/4, ntfs, and of course, raw/unknown), so there's little you can't back up with it. I keep a 1TB M.2 drive in a USB 3.1 enclosure to use as a target for the images and then copy them to my NAS for long-term storage.
            Exactly the kind of tool I'd use (although CCC on the Mac basically means you don't have to) but figured the lack of user friendliness would be a down point here 😉
              ArcherS
              In Win32DiskImager there is a option for "read only allocated partitions". It is shown in the instruction linked from this thread.
              The same instruction also describes how to use Gparted in Linux to resize the .img if so required.
              • A ArcherS
                @archers said in Need help backing up Raspberry Pi:
                I did not tick that box as you can see in my screen shot above
                  @catmanv2 said in Need help backing up Raspberry Pi:
                  No I haven't. Not the same size anyway.
                  I think I will buy another SanDisk 64GB SD card and make sure I can actually restore to a new card etc.
                    @cw-kid said in Need help backing up Raspberry Pi:
                    That's a sensible approach anyway.
                    As for the 'Read only allocated partitions' it seems that Windows struggles to see the Pi partition (other than /boot) as allocated....
                      I have got a USB stick with an Ubuntu desktop Live on it. I could run that up on my laptop instead.
                      And then maybe use a different tool to do the job.
                        You could indeed!
                          I found these instructions for Linux / Ubuntu here using the dd command. Think I will give that a try.
                            Just make sure you get of and if correct 🙂
                              If you'd run dd on an Ubuntu laptop for images, you might consider installing and running partclone instead. It's the workhouse underlying Clonezilla, and it will produce smaller backup images (it only copies used space; dd copies, all blocks used or not).
                              To make an image of a disk (/dev/sda2 in this example):
                              partclone -c -o /path/to/image-output -s /dev/sda2
                              And to restore that image later (same target device):
                              partclone -r -s /path/to/image-input -O /dev/sda2
                              Since the images can get very large (and may even grow larger than the filesystem allows), you can compress and split the image like this:
                              partclone -c -s /dev/sda2 -o - | gzip -c | | split -a 2 -b 2G - /path/to/imagefile.gz.
                              This will compress the output and split it into 2GB files, each having a '.gz.xx' ending, where xx is a two-letter code that keeps the parts sorted. To restore it:
                              cat /path/to/imagefile.gz.* | gunzip -c | partclone -r -s - -O /dev/sda2
                              • Black CatB Offline
                                Black CatB Offline
                                Black Cat
                                A simple to use "cloner" is Balena Etcher - it's gotten me out of trouble many times.
                                aka Zedrally
                                • Black CatB Black Cat
                                  @black-cat said in Need help backing up Raspberry Pi:
                                  Mac only, though, isn't it?
                                    Black CatB Offline
                                    Black Cat
                                    No, I use Windows.
                                    aka Zedrally
                                      No, I use Windows.
                                      No, I use Windows.
                                      Every day's a school day! 🙂
                                        162.9k
