I need to replace about 15 traditional wall light switches (no neutral wire) to turn on/off all lights with one operation inside the warehouse. And still maintain the ability to control each light individually.
The preference is not to set up a Wifi for each switch to reduce the number of devices connected to the network, and also, they change the Wifi password regularly, so they do not want to change all 15 switches.
I am looking for some solution that will achieve this with either Bluetooth/RF or any other technology.
The warehouse dimensions are about 100ftx100ft with sheetrock walls.
Please assist.
Just bought a couple of generic smart plugs and set them up easily using SmartLife app in the house I then plugged one into a workshop over 100m away This workshop has a hardwired internet connection with a separate wireless access router (not mesh) after doing a reset on the device and pairing to the new router it actually works from the house when my phone is connected to a completely separate wifi network - how is that possible ?
I did read something about these devices connecting to a server somewhere in China similar to IP cameras but there is no lag
I thought I had created a topic on this some time back, but can't find it to close the loop.
The issue was the lights on my drive appeared to be randomly switching on, with nothing from MSR logging and just a simple 'turn this on' in Openluup logs.
Finally got to the bottom of it this morning, which might help someone.
Turns out that somehow Alexa has decided that my drive lights are part of my Living room. If I tell her 'Living room lights on' the drive lights also come on. And if I tell her to turn them off, they also go off.
Which is madness because they are NOT in the living room group.
Current solution is to disable the drive lights in the Alexa app, which is fine as I never need to voice control them.
Hi All
Hopefully this place looks like a helpful forum as I’m quite new to all this!
I’ve had a few devices all working separately /through their proprietary apps but we’re just finishing off a large house extension and this has added to the list.
I’d ideally like to be able to view/switch a number of different devices on one screen/head end but have no idea where to start.
The devices we have/will have shortly are as follows;
Zigbee Smart Sockets
Zigbee smart switches (for lights)
Heatmiser Neo Underfloor Heating (this runs from a Samsung ASHP but that part is automatic)
Samsung VRF air conditioning (currently using Smart Things App)
Hive (2xLTHW heating circuits in the existing house and Hot Water)
Ring (doorbell!)
Hik Vision PoE CCTV
We have lots of appliances (Neff N70) which we can control remotely but not too fussed about controlling those at the
Moment)
Any help/recommendations would be appreciated!
Adrian
I have a legacy home automation set-up running on Windows XP. the computer and software have now died.
I have written a very nice Excel VBA program to replace the software and it can run on any modern Windows system.
My only remaining problem is to output the correct signal to a USB port to trigger the wireless switches.
Has anybody done a similar exercise. Please help.
Hi All,
Kind of new to Home Automation. Started off Using Amazon Echo units and added a Samsung SmartThings hub. I have mostly been using plug in modules for turning lights on and off. I live in a very rural area where the internet goes out a lot. I eventually want to change to to a non internet Hub so things will work without needing an internet connection. But I will post with those questions at a later date.
So, the task at hand is this: I have flood lights at each corner of my house. They are currently controlled by switches at the front and back doors. I would like to add Security Cameras to each corner also. I can easily find small Wifi switches to put into the electrical box where the flood lights are located, then I can terminate the leads together behind the Decora switch to have constant power. Then I can use the constant power up at the lights electrical box to power the security cameras. I would also like to have a wireless switch to take the place of the Decora switch to be able to turn the lights off and on.
I cannot seem to find a product like this. It seems I can find the small wired in switch boxes that will also come with external smart wall switches, but the wall switches are an external box that does not fit in or cover the existing Wall switch electrical box. I can also find Wireless Decora switches that come with a remote wired in small switch box , but they all seem to be RF and do not integrate with a Smart Hub.
I am hoping someone here knows of a product that matches what I am looking for. Any help would be appreciated.
Also any recommendations for Wireless Security cameras are welcome.
Thanks for any help.
Dear Forum,
I am just starting a smart home system. I've wanted to do this for 10 years at most and really would like to get a start. What I have are a couple of SONOFF wifi relays, some 433 (Hz/mHz) switches ( not wifi ) a couple of wifi lightbulbs, and I'd like to expand wifi thermostat, leak/water detectors, garage door openers and what ever else I can think of.
In the SONOFF items I have it's a particular app, the wifi bulbs are another app, and if I do a thermostat there might be another app. My wife is not a Luddite but she damn sure doesn't want to have to trouble shoot if/why a particular app breaks down.
So in what I do understand about smart home things is that I need/want a HUB. I spent 15 years doing some programming so I do have some computer ability, though I'd prefer to stay away from HAVING to line command operate the hub.
I would like a list of HUB's that people have found to be the best. Even better are links to let's say Amazon for that hub.
Regards from Noob Smart Home,
Barry
Hello lovely people. Long time and all that. Hope you're all doing OK.
Bit of a left field one here, looking for extra eyes more than an answer and you're the most logical bunch I know 🙂
Part of our HA system is a Logitech Elite hub and remote control.
This is programmed to control my Cyrus Stereo, our TV, and HDMI switch and our Virgin V6 box.
I've been away for a couple of days. Got back this evening to (eventually) work out that the V6 box appears to be not accepting any commands from the Logitech.
Everything has been rebooted.
Logitech uses IR to control
Cyrus: Fine
TV: Fine
HDMI: Fine
Remote control uses Bluetooth to control Hub.
All commands from the Remote to the hub are executed (one might assume correctly) as the activity LED responds, and if you're controlling (say) the Cyrus, all works fine.
iOS App can be used to control Hub over the WLAN:
All commands from the App re executed (one might assume correctly) as the activity LED responds, and if you're controlling (say) the Cyrus, all works fine.
Native remote (that uses as far as I know bluetooth) to control the V6 box works fine.
V6 box refuses to acknowledge any command other than from the native remote. Remote or app provoke absolutely zero response from the V6 box.
This is annoying, but damned if I can think of any logical reason. One might assume a firmware update on the V6 box, but given that the Hub simply emulates the native remote, that seems unlikely.
I'm struggling to think of where even to start troubleshooting this, so any random thoughts would be appreciated.
My initial approach is to buy another hub in case there's a different radio set that's failed in the hub...
TIA!
I am trying to run a reaction that turns on lights if a sensor has not been tripped for 2 minutes. Basically, when a garage door is open, turn on inside lights if nothing has been sensed for 2 minutes. My question has to do with the expression/variable for "Last Seen". The variable never gets updated over time since the last seen event never changes.
In the screenshot above, the reaction checks for any garage door as well as the variable called "GarageLastEntry". The expression for this variable is displayed below:
The problem that I am experiencing is that the variable never changes over time. I understand that this is because the "last seen" variable does not change over time when there is no activity. In this screenshot, the value shows 0.029... This can also be seen as the current value in the original reaction screenshot above. After 10 minutes, this value should be 10. However, when a garage door is opened, the variable does not get updated and thus the rule does not become true since .029 is less than 2.
When I go to the variable and click on the > icon, the variable then gets updated as expected as seen below:
So the ultimate question is, how do I use a rule that can use a variable such as "last seen"? Do I need to create another variable or reaction that multiplies this by 1 every minute? From what I read in the manual, a variable is evaluated every time it is included in a reaction. But this is not what I am seeing.
I also want to ask another question related to this variable. It seems like Reactor continuously deletes this variable and I have to keep recreating it? I have never experienced this with MSR so wanted to ask if this is a common problem or if my definition is causing this.
Any info is appreciated!!!
BACKGROUND
I have been using 4 x Yale Contactless Connected Door Locks for several years (they use either a rfid tag or code to enter)
I have also been using 1 x Yale L1 Door Lock on the main front door and this connects via Yale Software
Yale contacted me to advise the L1 Lock software was being withdrawn and I needed to install a Yale Access Module into the existing lock and a Wi-Fi Bridge to link it with the newly released software
ALL of the above was working just fine.
RECENT
Yale emailed to advise I should add a Yale Access Module to each of the 4 other locks as this would link with the updated software via the Wi-Fi Bridge.
They offered a deal of just £4 each for these Modules so I got them.
THE PROBLEM
I found that only 2 of these modules would slot easily into the locks - two of them bent the pins and one of those snapped the female part in a lock (I do have a spare lock but thats not the point).
Anyway, I began to set-up the two fitted Modules with the Wi-Fi Bridge and I eventually found (thanks Google, NOT Yale) that I now need 1 x Wi-Fi Bridge PER LOCK (£50 each).
QUESTION
Does anyone know of a compatible Wi-Fi Bridge which works with Yale AND can handle multiple connections (ie 5 all 5 of my locks) ?
THANK YOU
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
Need help backing up Raspberry Pi
Hello
I have a 64GB SD card in my Raspberry Pi.
I read some guides online and the ones that looked easy to follow use a program call Win32 Disk Imager to make an image of the entire SD card.
I shutdown the Pi and when I insert the SD card in to my Windows 10 PC, I can see drive letter D:\ appear and its label is "boot"
Looking at this disk in Windows Disk management it looks a bit strange however as it has a massive unallocated area.
Anyway I proceeded to backup the disk D:\ using Win32 Disk Imager program.
It took a long time but it has created an .img file which is 27.4GB in file size.
I then put the SD card back in to the Pi and powered it on.
Here is a "df" output from the Pi
Looks like I am not using the full 64GB of the SD card.
When I first setup the Pi I was using a much smaller SD card and then I bought a decent Sandisk 64GB card and followed some other user guide found online to clone my original smaller card to the new card and expand etc.
So have I actually just backed up the Pi's SD card and all its contents successfully ?
Hi thanks for the reply.
I think my original SD card when I first got the Pi was like 8GB max.
I'm not sure which online guide I followed now to clone the SD card and move to the new SanDisk 64GB card as it was some time ago now.
If I expand the partition now then my Win32 Disk Imager backup with be even bigger at 64GB etc.
I have seen some other user guides for backing up a Pi that didn't image the entire SD card and the resulting backup file(s) were much smaller. But those guides look more difficult / involved to follow, with many more steps etc.
So now I am unsure how much space my Pi can currently use?
@cw-kid a decent imager won't make your backup bigger, i.e. it won't back up the empty space. That being said, do you have some kind of limitation on your backup size? 64G is not exactly big on the current scale of things.
If run df -h it will give you human readable sizes
My reading of that is that it's currently 64G give or take, which is what you'd expect, but I'm not working at my best due to side effects
Do df -h and see what the numbers come up as.
59GB with 5.7G used ?
So why did this Win32 Disk Imager program create a 27.4GB .img file ?
If there is better imager program I should be using? I can swap to using that.
The portable disk I stored the .img backup file on, is large enough to cope with a single .img file of 64GB in size if need be.
Don't forget that you're not looking at discs here. You're looking at partitions and mount points.
What I am seeing is you've got a full 64G SD allocated and mounted to various points in your file system. Most of it is in /root and most of it is unused.As to why you ended up with a 27G backup, I have no idea other than Windows is probably not terribly happy reading Linux file systems and partition info. It was never terribly well supported.
I don't really know many Windows tools these days, being a dyed in the wool BSD / Linux guy.
If you only have Windows, I used to use Acronis (many years back). The other thing you could do is use a live Linux CD and use one of the tools there. Even the terribly basic dd would be able to do it.
I would expect though that a properly functioning tool would create a 7Gish backup file. So yes, something is amiss. Can't tell if that means your backup is non-functional or not, though.
Have you got another SD card? Restore to that, shut the pi down and try and boot from the newly restored card if you need to test.
Just to toss another alternative in here, I use Clonezilla for imaging just about everything. It's not very user-friendly; you need to know a bit, like be able to correctly and surely identify which disk (/dev/sda b c d e...) is the source and which is the target, but it's a wrapper for standard tools (partclone, mostly) that do a good job of making filesystem images that back up only the used space. It also automatically grows and shrinks filesystems to new target partitions (if they fit) on restores, etc. You just make a boot CD/DVD or USB stick and off you go. It supports pretty much all filesystem types (msdos, ext2/3/4, ntfs, and of course, raw/unknown), so there's little you can't back up with it. I keep a 1TB M.2 drive in a USB 3.1 enclosure to use as a target for the images and then copy them to my NAS for long-term storage.
@catmanv2 said in Need help backing up Raspberry Pi:
No I haven't. Not the same size anyway.
I think I will buy another SanDisk 64GB SD card and make sure I can actually restore to a new card etc.
@cw-kid said in Need help backing up Raspberry Pi:
That's a sensible approach anyway.
As for the 'Read only allocated partitions' it seems that Windows struggles to see the Pi partition (other than /boot) as allocated....C
If you'd run
dd
on an Ubuntu laptop for images, you might consider installing and runningpartclone
instead. It's the workhouse underlying Clonezilla, and it will produce smaller backup images (it only copies used space; dd copies, all blocks used or not).To make an image of a disk (
/dev/sda2
in this example):partclone -c -o /path/to/image-output -s /dev/sda2
And to restore that image later (same target device):
partclone -r -s /path/to/image-input -O /dev/sda2
Since the images can get very large (and may even grow larger than the filesystem allows), you can compress and split the image like this:
partclone -c -s /dev/sda2 -o - | gzip -c | | split -a 2 -b 2G - /path/to/imagefile.gz.
This will compress the output and split it into 2GB files, each having a '.gz.xx' ending, where xx is a two-letter code that keeps the parts sorted. To restore it:
cat /path/to/imagefile.gz.* | gunzip -c | partclone -r -s - -O /dev/sda2
@black-cat said in Need help backing up Raspberry Pi:
A simple to use "cloner" is Balena Etcher - it's gotten me out of trouble many times.
Mac only, though, isn't it?
