  3. MQTT – setup and use
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
    I’m speechless. No explanation.
    • C Offline
      C Offline
      christian_fabre
      ok thanks for trying to solve my problem.
      in the near future i will try to reinstall OpenLuup on my Raspbery, maybe this will fix this problem.
      Sorry for taking your precious time
        I haven’t given up. I can only think that, somehow, we are not running the same version of the code. You did confirm that your last install was, in fact, v21.5.2?
          Is @christian_fabre bridged to mosquitto? As when I reload OpenLuup I have to restart mosquitto to get them talking again.
          • C Offline
            C Offline
            christian_fabre
              @akbooer I will probably add more log, to see the exact payload sent. Sometimes those things are generating strange telemetry data, so maybe that's the case. I'll probably log what's going on around hadevice property as well. I was unable to re-produce it in my own install, so it should be something related to this particular model and its messages.
                #91
                @christian_fabre
                If you are still interested, testing v21.5.3 is available. I have made considerable changes.
                • C Offline
                  C Offline
                  christian_fabre
                  I just installed the testing version 21.5.3.
                  It works great for Shelly but also for Tasmota
                  Merci bien
                  • C christian_fabre
                    Merci bien
                    Merci bien
                    Je vous en pris.
                    Believe me... I'm happy. So sorry for all the mis-steps, but I learned a few things along the way, so it was a worthwhile exercise!
                      Merci bien
                      Je vous en pris.
                      @akbooer
                      Now that you got that figured out, one awesome thing which could be done would be integrate this:
                      GitHub - Koenkk/zigbee2mqtt: Zigbee 🐝 to MQTT bridge 🌉, get rid of your proprietary Zigbee bridges 🔨
                      Zigbee 🐝 to MQTT bridge 🌉, get rid of your proprietary Zigbee bridges 🔨 - Koenkk/zigbee2mqtt
                      By creating a bridge supporting it on openLuup. It would enable me to move zigbee from home assistant to run directly to openLuup and I would likely take advantage of it to get rid of my hue hub as well, running a single zigbee network through mqtt...
                        @akbooer
                        @rafale77 its topics are pretty organized, so it should be easy to do. The only difficult part is to get a reliable trace of messages, so an emulator could be written to facilitate development and testing.
                        • B Buxton
                          @akbooer I hate to add more to the pile... but I'm still seeing a receive error for the connection to mosquitto. openLuup 2021.04.29b
                          Here's the log error:
                          2021-05-01 14:22:38.815   openLuup.io.server:: MQTT:1882 connection closed  tcp{client}: 0x5579919e9c58
                          2021-05-01 14:22:38.816   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x5579919e9c58
                          2021-05-01 14:22:43.935   luup.io.incoming:: bytes received: 51, status: OK tcp{client}: 0x557990e7f528
                          2021-05-01 14:22:48.435   luup.io.incoming:: bytes received: 51, status: OK tcp{client}: 0x557990e7f528
                          2021-05-01 14:22:49.763   luup.variable_set:: 10181.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1619904116 now: 1619904168 #hooks:0
                          2021-05-01 14:22:50.158   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557991971ff8
                          2021-05-01 14:22:53.834   openLuup.io.server:: MQTT:1882 connection from 127.0.0.1 tcp{client}: 0x5579920dc0b8
                          2021-05-01 14:22:53.834   openLuup.mqtt:: client is in ERROR empty
                          2021-05-01 14:22:53.834   openLuup.mqtt:: credentials is in ERROR empty
                          2021-05-01 14:22:53.834   openLuup.mqtt:: subscriptions is in ERROR empty
                          using the below error trapping in function "MQTTservlet"
                            local function MQTTservlet (client)
                          	if client == nil then
                          	  _log ("client is in ERROR nil")
                          	else
                          	  	if table.concat(client) == "" then
                          		_log ("client is in ERROR empty")
                          		else
                          	   _log (table.concat {"MQTT ERROR: ", table.concat(client)})
                          	if credentials == nil then
                          	  _log ("credentials is in ERROR nil")
                          	else
                          	  	if table.concat(credentials) == "" then
                          		_log ("credentials is in ERROR empty")
                          		else
                          	   _log (table.concat {"MQTT ERROR: ", table.concat(credentials)})
                          	if subscriptions == nil then
                          	  _log ("subscriptions is in ERROR nil")
                          	else
                          	  	if table.concat(subscriptions) == "" then
                          		_log ("subscriptions is in ERROR empty")
                          		else
                          	    _log (table.concat {"MQTT ERROR: ", table.concat(subscriptions)})
                              return function () incoming (client, credentials, subscriptions) end
                          I can't find a deeper layer in the stack where I can trap for the incoming message to see what's in the message that is throwing the error. As near as I can tell, if openLuup tries to connect to a running mosquitto instance, then it fails to see the topics and messages, and passes empty--but not nil--strings when the servlet interface sees incoming bytes.
                          If I restart mosquitto, openLuup then sees the topics and messages and the error messages stop--and the connection to mosquitto remains stable.
                          This behavior does not occur when I aim an IOT device directly at openLuup--in that the connection to the device always resumes when openLuup reloads--in other words, I don't need to restart the IOT device to enable the connection.
                          @buxton said in MQTT – setup and use:
                          OK, I’m ready to take a look at this. However the above statement makes no sense to me, since the server never connects to anything (because it’s a server – clients connect to it.)
                          B 1 Reply Last reply
                            B Offline
                            B Offline
                            Buxton
                            @akbooer Yes, that was poorly worded as it makes it sound like openLuup initiates the connection to Mosquitto.
                            The symptoms of the problem are that:
                            • if luup reloads, an occasional message that is sent to openLuup from Mosquitto causes a receive error in openLuup. It is unknown what that/those message(s) are.
                            • if mosquitto reloads, the openLuup error messages stop, so something changes in the way that openLuup sees the mosquitto data.
                            • this behavior does not occur with IOT devices.
                            A possible way to trouble shoot this is to place debug code at the incoming interface that will trap and display packets headed to the MQTT port. By comparing incoming timestamps with the error message timestamp, I should be able to tell what message is causing the receive error message--even though the message variable is empty at the time it causes the luup error. What is odd to me is that there is a lot of error trapping for bad messages in your code, but this message(s) seems to bypass all of that and arrives at the incoming routine empty.....
                              #98
                              I think we are being misled by your error messages. These tables are not empty...
                              local x = {a = 1, b = 2}
                              local y = table.concat (x)
                              print (y == '')
                              yields the expected result true.
                              • B Offline
                                B Offline
                                Buxton
                                Ah! Yes that explains the empty variable, though I'm going to have to dig into my lua book to understand why! I was assuming that the concat function returned a series of string values from a table, and therefore, the output could be sent to the log for display.
                                  #100
                                  It works only for a contiguous array of numbers and/or strings...
                                  local x = {"a ", 1, " b ", 2}
                                  print(y)
                                  gives
                                  a 1 b 2
                                    print(y)
                                    gives
                                    a 1 b 2
                                    B Offline
                                    B Offline
                                    Buxton
                                    @akbooer Ok, so the variable "message " contains more than just a value array.
                                    I've never been able to get zerobrane as a debugger working with openLuup, though the instructions on how to do so have been written about previously. I just couldn't get the debugger working on a target remote PC, so it's difficult to watch what's going on within the myriad method code in the object model you've created. I don't write code for a living--never have-- though I use SQL, VBA and Python in my day to day job. The debuggers for those languages are a breeze compared to setting up zerobrane and Vera.....
                                      #102
                                      Yes, the message structure is an object with various values and methods:
                                              -- variables
                                              length          = nb,             -- byte count for statistics
                                              packet_type     = packet_type,
                                              control_flags   = control_flags,
                                              body            = body,           -- may include variable header and payload
                                              ptr             = 0,              -- pointer to parse position in body
                                              packet_name     = pname,          -- string name of packet type
                                              -- methods
                                              read_bytes      = read_bytes,
                                              read_flag_byte  = read_flag_byte, -- converting octet to 8 separate flag bits
                                              read_word       = read_word,
                                              read_string     = read_utf8,
                                      It's that way, because MQTT message formats are dependent on the type of message, so the methods contain here do some of that job. However, for the publish / subscribe functions, the topic and message parameters are simple strings, so easy to print out.
                                      As for debugging, I run the entire openLuup system within ZeroBrane during development, so most things are directly traceable and the debugging facilities are very adequate. I've never, ever, tried to debug a remote system.
                                      Still keen to discover the cause of your bridged server issue...
                                      ...have you tried enabling DEBUG of the MQTT module itself? It provides some useful information.
                                                -- variables
                                                -- methods
                                        B Offline
                                        B Offline
                                        Buxton
                                        @akbooer Yeah, I've tried debug and there's nothing in the log that helps.
                                        If you ever do get the notion to connect to a remote instance, let me know the steps as the procedure that was outlined on the vera forum was fairly complex.
                                        • A ArcherS
                                          If you have blocked the Shelly in your router from Internet access you probably have to open it temporary for the downgrade.
                                          I also added my Shelly Button to OpenLuup and for some reason I could not downgrade it, but I managed to get it working anyway after a few attempts.
                                          (A bit strange since the post I found on the forum was on problems with the Button and v1.10.3.)
                                          Another tip is to use MqttExplorer if you do not already use it and see if the Shelly shows up there. If it does, then at least the Mqtt part of the Shelly most likely works.
                                          @archers said in MQTT – setup and use:
                                          Do we know if this issue has been solved yet?
                                          I’ll update all my device firmware if so, but I’m loathe to do so without some sort of confirmation. TIA.
                                          A 2 Replies Last reply
                                            164.9k
