  3. Wink
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Wink
5 Posts 3 Posters 687 Views 2 Watching
  • propheadP Offline
    propheadP Offline
    prophead
    Pours one out for our wink brothers.
      It's terrible, they should give them more than a week.
      Infact they should not be allowed to treat customers that way
      The cloud model is flawed, they should reduce cloud dependency and therefore costs. They could charge for support package after 1 year and for third party intergration and remote connection . Existing customers would then be able to choose to support themselves or pay for support.
      Treating customers this way will backfire,
        Yep, one more down the cloud nonsense drain. We've seen too many already. When will people finally learn? Home Automation is not an application which benefits from cloud dependance. The cloud is actually a major liability to the system and should be avoided as much as possible.
          If i owned a wink i would shred it and use the $4.99 first months sub to post it to William (that's how you spell his name)
            It's not so different from what happened to Lowe's Iris and what I foresee for nest, ecobee, smartThings, etc... They will one day either get bought out, go bankrupt or will terminate their services. Who in their right mind would want to rely on cloud servers to do anything in the house when it takes more time and energy along with adding so much more failure points to send the data in and out than it does to process everything locally? All these also open your house to get hacked and giving your data to some company. Same applies to vera and their backup to server, event servers and all of their other flaky tunnel connections. Ignorance is bliss...
            Expect a lot of wink users to move over to other platforms now...
            • Time series documentation
            • Tuya Wifi to Tasmota flashing
            • Reset a delay
            • Single protocol?
            • HDMI oddness
