  3. Alexa TTS is sloooooooow
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
35 Posts 4 Posters 11.3k Views 4 Watching
    Hmmm, I have debug set to one and my log looks nothing like that....
    This is the LuaUPnP.log yes?
    LibraSunL 1 Reply Last reply
      @catmanv2 said in Alexa TTS is sloooooooow:
      Yes. I get a very verbose response set like that in Vera's LuaUPnP Log every time I attempt one of the Lua commands I use for testing. Some worked with previous revisions, others not, but right now ... literally nothing works for me.
      I'm wondering if maybe I have too many Alexa devices defined in my account... or something else unique to "me" that's causing VeraAlexa to choke.
      Whenever I update any component of the VeraAlexa plug-in (whether through WinSCP or by dragging files into App > Develop), I always set "Configured" back to 0 and restart Vera, so things have a chance to settle. The cookie is safely there, and "Configured" always sets to 1 without any trouble.
      It's as if the plug-in wants to work, but simply doesn't, for me. 😕
        @librasun are you on Vera or OpenLuup?
        What's in your .alexa.devicelist.all? If you've got duplicate entries it's probably worth deleting it and letting it re-create.
        I've just realised my 'new' Echo is not listed, but it's in the guess bedroom so doesn't get used.
          To answer your question, I inspected the contents of my .alexa.devicelist.json file (I see no 'all' file like you mentioned), and found -- after putting it through a JSON Pretty Print converter and filtering for accountName -- just a single copy of each device on my account.
          Egads, though, the file is 931 lines long, lol!
          If you're suggesting I delete that file, I'm game, but am generally loath to take stabs in the dark like that until I have more data.
            AFAIK you should have:
            .alexa.devicelist.txt
            .alexa.cookie
            I think the lack of some or more of these could be part of your issue. Are you on Vera still? I forget
            Totally get what you mean about deleting stuff. I tend to rename ;). My understanding is they should be created automagically.
              #21
              Yep, am still on Vera Plus. I'll do the rename you suggest IF I can find the .all file in question. Weird that I haven't seen it yet in WinSCP (which is definitely showing me any hidden/system files).
              When I do a search for alexa starting at Vera's root directory, here are the results (am I seeing duplicates?):
              /etc/cmh-ludl/L_AmazonAlexaHelper.lua.lzo
              /storage/cmh-ludl/L_AmazonAlexaHelper.lua.lzo
              /etc/cmh-ludl/alexa.png.lzo
              /etc/cmh-ludl/D_VeraAlexa1.xml.lzo
              /etc/cmh-ludl/I_VeraAlexa1.xml.lzo
              /etc/cmh-ludl/L_VeraAlexa1.lua.lzo
              /etc/cmh-ludl/S_VeraAlexa1.xml.lzo
              /storage/cmh-ludl/alexa.png.lzo
              /storage/cmh-ludl/D_VeraAlexa1.xml.lzo
              /storage/cmh-ludl/I_VeraAlexa1.xml.lzo
              /storage/cmh-ludl/L_VeraAlexa1.lua.lzo
              /storage/cmh-ludl/S_VeraAlexa1.xml.lzo
              /storage/alexa/.alexa.cookie
              /storage/alexa/.alexa.devicelist.json
              /storage/alexa/alexa_remote_control.sh.old
              /storage/alexa/.alexa.cmd
              /storage/alexa/.alexa.volume.4256c846877e416eaa3425d163619011
              /storage/alexa/.alexa.volume.90F00718703203T4
              /storage/alexa/.alexa.volume.d889f9dcc0ab4085bcb59494f81c3726
              /storage/alexa/.alexa.volume.eb48978706f5459f890ef0ec5aa9fce9
              /storage/alexa/.alexa.volume.G070RR138143018W
              /storage/alexa/.alexa.volume.G090LF1071750H4G
              /storage/alexa/.alexa.volume.G090LF1071750H7N
              /storage/alexa/.alexa.volume.G090LF1071750H8V
              /storage/alexa/.alexa.volume.G0W0TC039353F2SX
                #22
                I'm going the nuclear option now... deleting 'Alexa' device from Vera, removing ALL "Alexa" files from Vera (except the two belonging to "Helper"), rebooting, installing fresh VeraAlexa from Github repo, restarting Luup, creating device, restarting/refreshing, logging into Alexa.Amazon.com, configuring. turning on Debug, restarting/refreshing, etc., etc.
                Will report back momentarily...
                Took some real calisthenics to get the Cookie file again, but it's back, and VeraAlexa is now rebuilding my Devices list.
                Modifying my MSR test suite to reflect newly assigned device number... then will run some test Lua...
                After silent result, I immediately spotted this in Vera's log:
                JobHandler_LuaUPnP::HandleActionRequest can't handle service: urn:bochicchio-com:serviceId:VeraAlexa1 <0x70376520>
                Despite "Configured" insisting itself to 1, and the cookie file (and devices.json) being present, I continue to see this in LatestResponse:
                cookie does not exist. logging in ... device list does not exist. downloading ... no alexa command received
                Another one or two manual resets of Configured later, I finally get the expected idle phrase in LatestResponse:
                So am resuming tests. First one out of the chute gives the same error condition in Log:
                This is the point I normally go jump off a tall bridge. Bye!
                  OK, well that's a problem :(. (The log not the bridge)
                  Perhaps our guru on Alexa TTS can assist. I'm probably not going to be much help as I'm OpenLuup....
                    I've just come back from the dead, in order to report some modest successes since my past post.
                    1. I switched my "Default Echo" from "Living Room" to "Libra's Sonos Beam" (same device!!) and she finally spoke.
                    2. Further testing revealed that I can get other devices to speak and react to commands, so that's promising. This points to somehow my "Living Room" (the previously working device in 0.92) had become unwelcome by 0.97 and 0.98.
                    3. Now, for some reason -- maybe because I tested some "informal phrasing" -- Alexa answers me casually with "Aye, aye, captain!"
                      [That was unexpected yet humorous!]
                    So, as it stands, pretty much my entire checklist of test routines appears to be working, and I am happy to rejoin the living.
                    Thanks for the moral support from everyone. Glad I don't have to give up entirely on VeraAlexa!!
                      #25
                      @therealdb after all of today's failures and successes with VeraAlexa, I find this one Lua command does not produce the desired results (namely, tuning in radio station WWOZ through "Tune In"), as Alexa normally would when these words are spoken aloud:
                      luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e textcommand:'tune in wwoz' -d 'Sonos Beam'"}, 370)
                      // alexa responds "I'm not sure what video you want"
                      Do you think I'm doing something wrong? Or is Tune In not compatible somehow with this plug-in?
                      Thanks for any suggestions!
                      EDIT: Think I've solved it, by adding the words "radio station" before the call letters:
                      luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e textcommand:'tune in radio station wwoz' -d 'Sonos Beam'"}, 370)
                      //works, desired station plays
                        Can't get a multi-quote but:
                        1. Apostrophes in device names. That sounds like a bad idea. No idea how the system is going to react to that.
                        2. Aye aye captain: I want this. How can I make it happen 😉
                          #27
                          You and I think alike; I since took pains to eliminate any apostrophes from my Device Names (both in the Alexa app, officially, as well as very carefully in the .JSON file and in the plug-in itself). Pretty sure that was a problem. I even attempted to escape the apostrophe (\') but VeraAlexa didn't respond. As a matter of fact, when unable to decipher the assigned device, VeraAlexa seems to select another one (in my case, "Kitchen", the last one used during testing) as the default. Kinda unexpected.
                          @therealdb is this something that the plug-in needs to contend with going forward? After all, Amazon lets you name devices however you want, subject to few constraints, and often without the user's input. For example, "Libra's Ezlo Voi" was created not directly by me, but by my Ezlo Plus / VeraMobile app / who-knows-what service. 🙂
                          CatmanV2C therealdbT 2 Replies Last reply
                            @librasun Too much time supporting databases in production environments is my problem 😄
                              One day I'll reminisce about fixed-length fields in text files on old Applesoft DOS 3.3 floppy disks, wherein a single out-of-place comma could render the entire "database" unusable. 🙂 So yeah, I watch for that kinda stuff. That's why my default had been "Living Room" all this time (and I never thought to change that until this morning...glad I did!).
                                Guys, Just something to watch out for coming up with your Alexa devices:
                                Dan Goodin  /  May 29, 2021  /  Tech
                                Amazon devices will soon automatically share your Internet with neighbors
                                Amazon's experimental wireless mesh networking turns users into guinea pigs.
                                  #31
                                  @librasun glad you’ve solved it. Sorry to be late to this party, but a combination of week-end and different time zones made is to blame.
                                  I never thought of quotes, but it makes sense. My contribution to that is minimal, since we’re using an external bash script to do the work. I could add some warnings in our readme, but you’ll depend on something external. All that said, I have devices with quotes and I’ve never used as targets, and my VeraAlexa is still working…
                                    @rafale77 said in Alexa TTS is sloooooooow:
                                    Thanks. Not a hope in that working round here, but I'll be turning it off anyway.
                                      Hmmm not a setting over here in Rightpondia....
                                        @catmanv2 I think it’s available only in us. This is the only time for us across the pond to have an advantage 🤣
                                          Glad to hear! I am finding it quite bold that they are pushing this enabled this by default. Also it is not quite ready yet as they will be pushing the firmware updates. Just wanted to make sure you are aware.
                                            163.9k
