On start up the log indicates the following:
2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value ""
2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value ""
2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value ""
2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value ""
2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value ""
2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value ""
2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value ""
2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true
2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } })
2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value)
2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value)
The MQTT variables are all set to "skip":
MQTT_BrightnessValue
MQTT_PowerStatusOff
MQTT_PowerStatusOn
However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to.
It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
I still use Vera controllers in combination with ReactorSensors. I have several Reactor sensors in use to retrieve weather data from Wunderground (i have a personal weather station), my smartmeter etc.
Recently I installed solar panels with a SolarEdge inverter. SolarEdge has an API to retrieve my power production data from their cloud.
Output is in json.
So I created a new Reactor Sensor. Connection is working (query okay).
But I encounter problems at the Value Expressions. Either I get ""query okay" but no data or I get "query okay but 1 expressions failed"
This is the json output
{"overview":{"lastUpdateTime":"2023-05-12 10:45:57","lifeTimeData":{"energy":476310.0,"revenue":216.577},"lastYearData":{"energy":433001.0},"lastMonthData":{"energy":433001.0},"lastDayData":{"energy":8262.0},"currentPower":{"power":5647.0},"measuredBy":"INVERTER"}}
So it has different layers/levels.
I tried to put in the Value Expressions field several combinations to get the energy data of today (8262.0), like:
response.lastDayData.energy
response.overview.lastDayData.energy
response.overview.lastUpdateTime.lastDayData.energy
all fail...
Who can help me with this ?
Just seen notification to Netatmo developers that the current password-based login is being disabled as from October.
Oath2 is now a requirement for apps needing access to Netatmo. This will require some changes to my venerable plug-in. I’m not sure how easy this will be with the current libraries in use.
Does anyone out there use the Netatmo plug-in?
Does anyone have any advice on using Oath2?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech.
I seem to be getting an odd timeout but no idea from where.
Debian Bullseye, bare metal
Good call from this morning:
2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8
2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8
2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8
2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388
2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=
Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388
2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say
2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22
2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi
ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0
2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388
2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0
2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8
2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248
2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8
2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388
2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8
2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8
2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8
2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e
8a13f3c8
2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8
2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget
2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37
2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0
2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8
2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8
2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8
2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8
2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28
Bad request from just now:
2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58
2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58
2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78
2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8
2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58
2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58
2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say
2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22
2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58
2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent
2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58
2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58
2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58
2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58
2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for
2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir
2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1
2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78
2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58
2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58
2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58
2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8
2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8
2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0
Any thoughts?
Cheers
Virtual HTTP Devices plug-in:
I wanted to try this out. Installed the plugin and created one device, which came up as a light bulb. So far so good. In AltUI I clicked on the On/Off slider on the page. The log shows that the Target is set to one. Likewise for the Variable list in AltUI. However the Status never gets set to one and the light bulb icon doesn't go yellow.
In some plugins you set the Target and then the plugin checks the physical device actually went on by checking an actual status report from the device, which can be used to set the variable Status.
In other cases a plugin will send a message to the physical device but that device will have no status feedback mechanism available. So the Status variable has to be set locally when the Target is set and everybody hopes the physical device all worked.
Not to sure what Virtual HTTP Devices plug-in does in this regard? Does the above go in anyway to explaining what I'm seeing? Is the plugin looking for status feedback?
I have a couple of issue with Openluup ATM. I'm going to work through them in the order that they appeared if that's OK
OpenLuup on bare metal (Debian Bullseye) running Z-way server and Z-wave.me
Issue:
I deleted a (I think) virtual switch in OpenLuup
Now when I call up all devices I have this in a 'tile'
Error displaying device 0-20510 - urn:schemas-upnp-org:device:BinaryLight:1
nil is not defined
And below (in room 101)
ReferenceError: nil is not defined
at eval (eval at evaluateConditions (http://192.168.70.249:3480/J_ALTUI_verabox.js:960:18), :1:1)
at Object.evaluateConditions (J_ALTUI_verabox.js:960:18)
at Object._evaluateConditions [as evaluateConditions] (J_ALTUI_verabox.js:1642:37)
at Object._evaluateConditions [as evaluateConditions] (J_ALTUI_multibox.js:629:89)
at Object. (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2572:23)
at Function.each (https://cdnjs.cloudflare.com/ajax/libs/jquery/3.5.1/jquery.min.js:2:2976)
at _getDeviceIconPath (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2569:10)
at _deviceIconHtml (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2739:18)
at _internalDeviceDraw (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2765:19)
at _deviceDraw (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2840:4)
Any ideas from anyone?
Full reboot has been done....
Cheers
I've been trying to figure out Reactor but I'm not very good at programming.
I have two scenes in VERA.
One scene should only run during the DAY and then stop running.
One scene should only run during the NIGHT and then stop running.
My scenes start off at the right times, but they do not turn off. I created a Sunrise/Sunset Reactor trigger and added it as a condition to each of my scenes.
However, the Reactor trigger when tripping or untripping does not prevent my Vera scenes from running. It will start them correctly the first day, but after that, both scene stay running and fight with each other. What am I doing wrong?
Thanks for any help!
If you are interested, here are the actions I wish to perform with each scene.
FARM STAND - DAY (runs at Sunrise)
Turn ON a device called LETTUCE LAMP
2a) Every 60 min, turn ON a device called LETTUCE PUMP
2b) Wait 15 min then turn OFF a device called LETTUCE PUMP
FARM STAND - NIGHT (runs at Sunset)
Turn OFF a device called LETTUCE LAMP
2a) Every 135 min, turn ON a device called LETTUCE PUMP
This sounds simple, but I cannot figure out how to disable these scenes when the theyre not supposed to run.
Good evening, all.
Is there a simple readme to set up and use a Broadlink device with OpenLuup?
The readme on github points to a thread on the old forum, and thence to a rabbit hole.
Is it just a case of adding IP address of the device? Or does it need the MAC?
Then how do I fire commands? It looks like I need to find the codes and send via Lua?
TIA
Hi Patrick,
A quick question about your virtual sensor plugin. I saw that the child sensors rely on polling for sensor data updates. Was there a reason not to use a watch on the underlying (source) state variable as opposed to polling. I'm asking in the sense that I need a fairly rapid response to a rise in humidity, but am unsure how to set sensor polling without adding additional io drag to openLuup.
I currently use the state humidity variable directly in a reactor sensor (the data is captured via a bluetooth device with multiple humidity variables), however, these state humidity variables have a generated name making it difficult to determine what is what in group of approximately 10 state humidity variables. So a virtual sensor solves the naming problem, while creating some trigger delay due to polling.
Thx
I have Reactor running under openLuup (which is running inside vwout's Docker container).
On the activities tab, it tells me I should update to a newer version of the device information database. When I go to the Tools tab, for a fraction of a second I can see the green "Update Device Info" button along with the Troubleshooting & Support and Device Spy sections. But after that fraction of a second, they disappear and I only see the Test Tools and Update Device Information Database sections, to just above where the Green button used to be.
I've tried this on both Edge and Firefox with the same behavior (with extensions both on and off).
Any suggestions?
Tesla Plugin Not Logging in After v2.3
Vera/openLuup plugins
Posters
Views
Watching
Hello @mrFarmer , ever since the v2.3 update I haven't been able to login to my account attached are the logs. Before the update I was getting the wake-up error too. I rolled back to V2.2 and the plugin was stuck on "updating car status".
06 05/17/21 10:45:20.102 Device_Variable::m_szValue_set device: 168 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0x11c7b58/NONE duplicate:0 <0x7708d520> 06 05/17/21 10:45:20.103 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273198 now: 1621273520 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520> 01 05/17/21 10:45:20.160 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520> 01 05/17/21 10:45:25.101 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:25.101 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:25.102 luup_device_message missing args <0x73394520> 06 05/17/21 10:45:25.103 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273520 now: 1621273525 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520> 01 05/17/21 10:45:25.158 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520> 01 05/17/21 10:45:30.102 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:30.103 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:30.103 luup_device_message missing args <0x73394520> 06 05/17/21 10:45:30.104 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273525 now: 1621273530 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520> 01 05/17/21 10:45:30.165 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520> 01 05/17/21 10:45:35.101 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:35.102 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:35.102 luup_device_message missing args <0x73394520> 06 05/17/21 10:45:35.103 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273530 now: 1621273535 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520> 01 05/17/21 10:45:35.156 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520> 04 05/17/21 10:45:37.219 <Job ID="16" Name="pollnode #9 1 cmds" Device="129" Created="2021-05-17 10:45:37" Started="2021-05-17 10:45:37" Completed="2021-05-17 10:45:37" Duration="0.117271000" Runtime="0.116483000" Status="Successful" LastNote="" Node="9" NodeType="ZWaveDimmableLight" NodeDescription="Shed Inside Light"/> <0x7708d520> 02 05/17/21 10:45:37.219 Device_Basic::AddPoll 129 poll list full, deleting old one <0x7708d520> 06 05/17/21 10:45:37.220 Device_Variable::m_szValue_set device: 129 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x7708d520> 06 05/17/21 10:45:37.221 Device_Variable::m_szValue_set device: 129 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastPollSuccess was: 1621273204 now: 1621273537 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x7708d520> 06 05/17/21 10:45:37.221 Device_Variable::m_szValue_set device: 129 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: ConsecutivePollFails was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x7708d520> 01 05/17/21 10:45:40.100 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:40.101 luup_device_message missing args <0x73394520> 01 05/17/21 10:45:40.101 luup_device_message missing args <0x73394520> 06 05/17/21 10:45:40.103 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1621273535 now: 1621273540 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73394520> 01 05/17/21 10:45:40.157 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 400, errorMessage : HTTP/1.1 400 BAD REQUEST !! <0x73394520> 01 05/17/21 10:45:40.157 luup_log:901: Tesla Car_error: Could not login to Tesla API after 5 attempts. <0x73394520> <0x745ef520> 02 05/17/21 10:45:45.701 luvd_get_info mg conn can't read /etc/cmh-ludl//shared.js or /etc/cmh-lu//shared.js from filename /shared.js pPtrFile (null) <0x6ed5f520>``` -
Hi Pabla,
Tesla made a change to obtain the tokens again
So need some time to find the new way. As long as the tokens are there it will still be working.Cheers Rene
Hi Pabla,
Here are some more logs
01 06/07/21 9:03:18.593 luup_log:901: Tesla Car_error: Unable to wake up car in set time. <0x72937520> 01 06/07/21 9:03:18.596 luup_log:901: Tesla Car_error: Wake up error. Reason #408, Unable to wakeup car.. <0x72937520> 06 06/07/21 9:03:18.596 Device_Variable::m_szValue_set device: 901 service: urn:upnp-org:serviceId:altui1 variable: DisplayLine2 was: Not ready for regular polling. Check settings or reload luup. now: Wake up error. Reason Unable to wakeup car. #hooks: 0 upnp: 0 skip: 0 v:0x1a2b990/NONE duplicate:0 <0x72937520> 06 06/07/21 9:03:18.848 Device_Variable::m_szValue_set device: 1304 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.851 Device_Variable::m_szValue_set device: 1321 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.882 Device_Variable::m_szValue_set device: 1305 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.885 Device_Variable::m_szValue_set device: 1306 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.888 Device_Variable::m_szValue_set device: 1307 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.890 Device_Variable::m_szValue_set device: 1308 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.892 Device_Variable::m_szValue_set device: 1309 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.895 Device_Variable::m_szValue_set device: 1310 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.896 Device_Variable::m_szValue_set device: 1311 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.900 Device_Variable::m_szValue_set device: 1312 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.904 Device_Variable::m_szValue_set device: 1313 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.906 Device_Variable::m_szValue_set device: 1314 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.908 Device_Variable::m_szValue_set device: 1315 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.911 Device_Variable::m_szValue_set device: 1316 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.912 Device_Variable::m_szValue_set device: 1317 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.918 Device_Variable::m_szValue_set device: 1318 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.926 Device_Variable::m_szValue_set device: 1319 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.928 Device_Variable::m_szValue_set device: 1320 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.931 Device_Variable::m_szValue_set device: 1323 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:18.942 Device_Variable::m_szValue_set device: 1324 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1623081783 now: 1623081798 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72537520> 06 06/07/21 9:03:19.180 Device_Variable::m_szValue_set device: 901 service: urn:upnp-org:serviceId:altui1 variable: DisplayLine2 was: Wake up error. Reason Unable to wakeup car. now: Not ready for regular polling. Check settings or reload luup. #hooks: 0 upnp: 0 skip: 0 v:0x1a2b990/NONE duplicate:0 <0x6e4fe520> 01 06/07/21 9:03:19.181 luup_device_message missing args <0x6e4fe520> 01 06/07/21 9:03:19.182 luup_device_message missing args <0x6e4fe520> 01 06/07/21 9:03:19.182 luup_device_message missing args <0x6e4fe520> 06 06/07/21 9:03:19.183 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1623077691 now: 1623081799 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x6e4fe520> 01 06/07/21 9:03:19.515 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 428, errorMessage : Vehicle in deep sleep. <0x6e4fe520> 06 06/07/21 9:03:19.517 Device_Variable::m_szValue_set device: 901 service: urn:upnp-org:serviceId:altui1 variable: DisplayLine2 was: Not ready for regular polling. Check settings or reload luup. now: Updating car status... #hooks: 0 upnp: 0 skip: 0 v:0x1a2b990/NONE duplicate:0 <0x6e4fe520> 01 06/07/21 9:03:24.101 luup_device_message missing args <0x72937520> 01 06/07/21 9:03:24.102 luup_device_message missing args <0x72937520> 01 06/07/21 9:03:24.102 luup_device_message missing args <0x72937520> 06 06/07/21 9:03:24.103 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1623081799 now: 1623081804 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72937520> 01 06/07/21 9:03:24.594 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 428, errorMessage : Vehicle in deep sleep. <0x72937520> 01 06/07/21 9:03:29.101 luup_device_message missing args <0x72937520> 01 06/07/21 9:03:29.102 luup_device_message missing args <0x72937520> 01 06/07/21 9:03:29.102 luup_device_message missing args <0x72937520> 06 06/07/21 9:03:29.104 Device_Variable::m_szValue_set device: 901 service: urn:rboer-com:serviceId:TeslaCar1 variable: LastLogin was: 1623081804 now: 1623081809 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72937520> 01 06/07/21 9:03:29.469 luup_log:901: Tesla Car_error: Unable to select vehicle. errorCode : 428, errorMessage : Vehicle in deep sleep. <0x72937520>```
