  3. Universal Remote Control
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
I run a B&B and am looking for a way to turn the lights off whenever a room is unoccupied for X amount of time. The guest should still be able to turn the lights on and off manually, but should not be able to disable the auto turn off feature if the room is unoccupied. I guess I am looking for a light switch with a built in presence sensor? I guess a presence sensor would be better as if it is a motion sensor, the lights may go off unwanted if the guest fails to make sufficient movement e.g. if the guest is lying down watching a film. Are there any products on the market that would work for my application?
11 Posts 3 Posters 902 Views 4 Watching
    Evening, everyone. Can't think of a better qualified bunch of people to ask so: What am I going to replace my Logitech Harmony with?
    Logitech have stated they are moving out of the market and I am therefore disinclined to purchase the Elite, never mind the price tag....
    Requirements are:
    1. IR control of 5 devices (one of which is somewhat esoteric so learning IR pretty much a necessity)
    2. Ability to control HiFi as well as video kit (should be covered by 1 but whatever)
    3. Pre-programmed activities for one button access
    4. Favourite channels
    5. Rechargeable (nice to have)
    6. If it needs a computer to set up: Mac compatible
    Anyone got a Pronto they'd sell me?
    A K 2 Replies Last reply
      Requirements are:
      How about a Virtual Pronto remote? If you can list out your devices - could probably work out if it can do the job.
      • A a-lurker
        @a-lurker thanks. Interesting but not sure that only voice controlled stuff is going to have a high WAF....
        Also the database site appears to be dead 😞
          Mmmm - nobody likes a dead database. Fortunately the codes are all here in GitHub.
          • A a-lurker
            @a-lurker sadly my device is not listed. Not surprised. It's a Cyrus streamer.
            The options seems horribly limited overall for a physical device. I would very much like Vera integration at some point, but still need something physical to grab. Apps on smart phones etc take far too long.
              Requirements are:
              K Offline
              K Offline
              kfxo
              @catmanv2 I have been keeping an eye on this project. Looks promising. I hope they deliver.
                "Cyrus Streamer' - pretty esoteric but it looks like it uses the RC5 protocol. Similar to Marantz. Have you got any Pronto codes that you can post here for the Cyrus like Power On, Power Off, Mute (actual model number may be of use too). I could probably work out what's what from the pronto codes. I use a BroadLink IR transmitter and and a Z-Wave scene controller ie it has buttons that trigger IR macros, turns power on and off to various devices, select inputs via http on the amp, etc. I suppose it depends on how many buttons you actually need to run your gear and what you are trying to achieve?
                • K kfxo
                  @kfxo said in Universal Remote Control:
                  Oh yes. That looks nice. Hopefully comes off and is not too spendy!
                  • A a-lurker
                    @a-lurker said in Universal Remote Control:
                    Allegedly the RC5 indeed, but never been able to get it to properly work. Sadly no Pronto codes. Mine was retired many moons ago. I have a Logitech that managed, sometimes, to learn some of the codes, but not many of the rest.
                    I think probably more buttons than most of the controllers I've seen, but interested to see any links? The other thing for WAF is that some of the buttons will need to be dynamic. I love my ZRC90 but no way is that going to cut it 😞
                      Have you got any sort of IR transmitter available to your Vera or openLuup? Can you get any pronto codes out of the Logitech with some learning device?
                      One of the problems with RC5 is that it has a toggle bit, which means every second time a button is pushed the code changes.
                        I'm not aware of being able to get anything from Logitech. One of the things I hated about it was the totally un-necessary cloud based set up. What would I need for the IR transmitter? I guess the Broadlink and some kind of blaster?
                          5.7k
                        • Shelly Wall Display XL
                          8.5k
                        • HA 2025.9.4 Supported Yet?
                        • Rule Set UI bug - RESOLVED
