  4. Updated to latest MSR 21243 and no entities are being executed I Hubitat
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
47 Posts 6 Posters 11.5k Views 6 Watching
    Matteburk
    After update no entities are being executed in Hubitat..... I can se in Recently Changed Entities that a motion sensor for example is triggered but the rule in it is not getting set
    im I missing something in the update @toggledbits ?
    getting this in msr log:
    Require stack:
    • /home/pi/reactor/server/lib/Engine.js
    • /home/pi/reactor/server/lib/httpapi.js
    • /home/pi/reactor/app.js
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
      at Function.Module._load (internal/modules/cjs/loader.js:725:27)
      at Module.require (internal/modules/cjs/loader.js:952:19)
      at require (internal/modules/cjs/helpers.js:88:18)
      at Engine._get_lexp_extensions (/home/pi/reactor/server/lib/Engine.js:862:25)
      at Rule.evaluateExpressions (/home/pi/reactor/server/lib/Rule.js:904:330)
      at Rule._evaluate (/home/pi/reactor/server/lib/Rule.js:994:344)
      at runMicrotasks (<anonymous>)
      at processTicksAndRejections (internal/process/task_queues.js:93:5)
      at async /home/pi/reactor/server/lib/Rule.js:963:17 {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
      '/home/pi/reactor/server/lib/Engine.js',
      '/home/pi/reactor/server/lib/httpapi.js',
      '/home/pi/reactor/app.js'
      When posting error messages, please don't (a) edit the error message down to what you think is relevant, and (b) not post context for the error -- several lines, ideally a dozen or two at least, before the error occurred.
      Also I need to know what platform you are on (e.g. are you bare metal, docker, etc. -- don't assume I remember from the last discussion we had, whenever that was).
        Matteburk
        Hi Sorry.. my bad....
        Im on RPi4 with ssd
        2021-09-02T04:01:04.708Z Rule:5:980:Rule.js Rule#rule-koqsgr9w._evaluate() mutex acquired, evaluating
        2021-09-02T04:01:04.709Z Rule:5:984:Rule.js Rule#rule-koqsgr9w update rate is 1/min limit 60/min
        2021-09-02T04:01:04.710Z Rule:5:904:Rule.js Rule#rule-koqsgr9w evaluateExpressions() with 0 expressions
        2021-09-02T04:01:04.712Z Rule:CRIT Error: Cannot find module 'common/util'
        Require stack:
          Require stack:
          Require stack:
          requireStack: [
          2021-09-02T04:01:04.715Z Rule:5:980:Rule.js Rule#rule-knhvm6nr._evaluate() mutex acquired, evaluating
          2021-09-02T04:01:04.716Z Rule:5:984:Rule.js Rule#rule-knhvm6nr update rate is 1/min limit 60/min
          2021-09-02T04:01:04.717Z Rule:5:904:Rule.js Rule#rule-knhvm6nr evaluateExpressions() with 0 expressions
          2021-09-02T04:01:04.719Z Rule:CRIT Error: Cannot find module 'common/util'
          Require stack:
          Require stack:
          Require stack:
          requireStack: [
        • M Matteburk
          Im on RPi4 with ssd
          Require stack:
            Require stack:
            Require stack:
            requireStack: [
            Require stack:
            Require stack:
            Require stack:
            requireStack: [
          @matteburk could check this post, although you probably have some other issue
            CrilleC Online
            CrilleC Online
            Looks like the same issue I'm having in this post which I haven't been able to solve yet.
            • J Offline
              J Offline
              Jaggz
              Had the same issue. Reaction as a group would not fire but entities within the Reaction would when manually selecting them (hit the little play button next to them). Everything else looked normal from a Status perspective (i.e. motion detected sending the rule into green status, etc). I fixed the problem by installing a fresh copy (leaving the reactor-data folder untouched).
                Make sure you are on the latest version, and NODE_PATH (environment variable) is defined correctly (how that is done depends on how you run Reactor).
                M 1 Reply Last reply
                  Matteburk
                  @toggledbits I run it with Node app.js
                  • M Matteburk
                    @matteburk OK. So the direct solution to your problem is to run it this way: NODE_PATH=$(pwd) node app.js
                    You really should be running it from systemd on the RPi, though. The command line startup is only for initial validation and setup, it's not meant to be the way to run MSR long term.
                    In the tools subdirectory, you'll find a file called reactor.service-example. To install MSR under systemd, do the following:
                    1. Copy the above-named file into your /etc/systemd/system directory and rename it to drop the -example part. For example:
                       sudo cp tools/reactor.service-example /etc/systemd/system/reactor.service
                    2. Edit the new file and change the pathnames to match your install directory. Remember that the file is installed in a restricted directory, so you need to use sudo with your editor:
                       sudo nano /etc/systemd/system/reactor.service
                    3. Once you have the file edited with correct names/parameters, stop your existing Reactor process.
                    4. Make systemd aware of the changed configuration file:
                       sudo systemctl daemon-reload
                    5. Start Reactor under systemd:
                       sudo systemctl start reactor
                    If you need to stop Reactor later, that's systemctl stop reactor. You can also restart a running Reactor with systemctl restart reactor.
                    Running Reactor under systemd will automatically restart it if it crashes, and start it up automatically when your RPi boots up.
                      Matteburk
                      @toggledbits@
                      Followed your instructions to run it under systemd but when i do nr 4 and 5 reactor won't start...
                      Should I write sudo systemctl start reactor under pi@raspberrypi as in picture?
                      /Mattias
                        This is correct. Check /var/log/syslog for startup errors.
                          Matteburk
                          This is what the log says:
                          Sep 5 00:00:00 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="383" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                          Sep 5 00:00:00 raspberrypi systemd[1]: logrotate.service: Succeeded.
                          Sep 5 00:00:00 raspberrypi systemd[1]: Started Rotate log files.
                          Sep 5 00:00:00 raspberrypi systemd[1]: man-db.service: Succeeded.
                          Sep 5 00:00:00 raspberrypi systemd[1]: Started Daily man-db regeneration.
                          Sep 5 00:00:02 raspberrypi colord[955]: failed to get session [pid 17774]: Inga data tillg\u00e4ngliga
                          Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                          Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9474.
                          Sep 5 00:00:05 raspberrypi systemd[1]: Stopped Multi System Reactor.
                          Sep 5 00:00:05 raspberrypi systemd[1]: Started Multi System Reactor.
                          Sep 5 00:00:05 raspberrypi systemd[17799]: reactor.service: Failed to determine user credentials: No such process
                          Sep 5 00:00:05 raspberrypi systemd[17799]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                          Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                          Sep 5 00:00:05 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                          Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                          Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9475.
                          Sep 5 00:00:10 raspberrypi systemd[1]: Stopped Multi System Reactor.
                          Sep 5 00:00:10 raspberrypi systemd[1]: Started Multi System Reactor.
                          Sep 5 00:00:10 raspberrypi systemd[17800]: reactor.service: Failed to determine user credentials: No such process
                          Sep 5 00:00:10 raspberrypi systemd[17800]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                          Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                          Sep 5 00:00:10 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                          Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                          Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9476.
                          Sep 5 00:00:15 raspberrypi systemd[1]: Stopped Multi System Reactor.
                          Sep 5 00:00:15 raspberrypi systemd[1]: Started Multi System Reactor.
                          Sep 5 00:00:15 raspberrypi systemd[17801]: reactor.service: Failed to determine user credentials: No such process
                          Sep 5 00:00:15 raspberrypi systemd[17801]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                          Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                          Sep 5 00:00:15 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                          Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                          Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9477.
                          Sep 5 00:00:21 raspberrypi systemd[1]: Stopped Multi System Reactor.
                          Sep 5 00:00:21 raspberrypi systemd[1]: Started Multi System Reactor.
                          Sep 5 00:00:21 raspberrypi systemd[17802]: reactor.service: Failed to determine user credentials: No such process
                          Sep 5 00:00:21 raspberrypi systemd[17802]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                          Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                          Sep 5 00:00:21 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                          Sep 5 00:00:26 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                          Sep 5 00:00:26 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 9478.
                            Looks like you haven't set the User= line correctly in the reactor.service file. It should be the name of the user that owns the directory in which Reactor is installed. While you are at it, check the pathname to the Reactor install (in the WorkingDirectory and Environment keys), and the pathname to the node executable used in the ExecStart key. If you're not sure where your node lives, just type which node on the command line and it will tell you.
                              Matteburk
                              I checked and changed the lines to this ( I guess something is wrong there)
                              [Unit]
                              After=network.target
                              [Service]
                              Type=simple
                              User=pi
                              WorkingDirectory=/home/pi/reactor
                              Environment=NODE_PATH=/home/pi/reactor
                              ExecStart=/home/pi/.local/lib/nodejs/node-v14.15.4-linux-armv7l/bin/node
                              Restart=on-failure
                              RestartSec=5s
                              [Install]
                              WantedBy=multi-user.target
                              and restarted reactor....... then I see this in log.....
                              Sep 5 15:26:16 raspberrypi systemd[9870]: reactor.service: Failed to determine user credentials: No such process
                              Sep 5 15:26:16 raspberrypi systemd[9870]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                              Sep 5 15:26:16 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                              Sep 5 15:26:16 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                              Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                              Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 20060.
                              Sep 5 15:26:21 raspberrypi systemd[1]: Stopped Multi System Reactor.
                              Sep 5 15:26:21 raspberrypi systemd[1]: Started Multi System Reactor.
                              Sep 5 15:26:21 raspberrypi systemd[9871]: reactor.service: Failed to determine user credentials: No such process
                              Sep 5 15:26:21 raspberrypi systemd[9871]: reactor.service: Failed at step USER spawning /usr/local/lib/nodejs/bin/node: No such process
                              Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Main process exited, code=exited, status=217/USER
                              Sep 5 15:26:21 raspberrypi systemd[1]: reactor.service: Failed with result 'exit-code'.
                              Sep 5 15:26:22 raspberrypi systemd[1]: Reloading.
                              Sep 5 15:26:22 raspberrypi systemd[1]: /etc/systemd/system/teamviewerd.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/teamviewerd.pid \u2192 /run/teamviewerd.pid; please update the unit file accordingly.
                              Sep 5 15:26:26 raspberrypi systemd[1]: reactor.service: Service RestartSec=5s expired, scheduling restart.
                              Sep 5 15:26:26 raspberrypi systemd[1]: reactor.service: Scheduled restart job, restart counter is at 20061.
                              Sep 5 15:26:26 raspberrypi systemd[1]: Stopped Multi System Reactor.
                              Sep 5 15:26:26 raspberrypi systemd[1]: Started Multi System Reactor.
                              Sep 5 15:26:27 raspberrypi systemd[1]: reactor.service: Succeeded.
                              Sep 5 15:26:42 raspberrypi systemd[1]: Started Multi System Reactor.
                              Sep 5 15:26:43 raspberrypi systemd[1]: reactor.service: Succeeded.
                              Sep 5 15:34:06 raspberrypi systemd[1]: Started Multi System Reactor.
                              Sep 5 15:34:06 raspberrypi systemd[1]: reactor.service: Succeeded.
                                It looks like it's referring to a different pathname for nodejs than you have configured in the service file. Did you make a change to that value somewhere along the way? If you make any changes to the config file, you need to do sudo systemctl daemon-reload to get systemd to read the updated config file. So the first step is to try sudo systemctl daemon-reload followed by sudo systemctl restart reactor.
                                If that doesn't work, it is reported elsewhere that sudo systemctl daemon-reexec may resolve this (or perhaps simply rebooting the whole system).
                                Then step three, if you're still not successful, is to see if Reactor is logging anything in its own log files.
                                  Matteburk
                                  I have followed your instructions but no success.
                                  Dont no what to do..... Here is the log from msr
                                  /Mattias
                                  Require stack:
                                    Require stack:
                                    2021-09-06T16:19:30.352Z Rule:5:980:Rule.js Rule#rule-ksn5u2pn._evaluate() mutex acquired, evaluating
                                    2021-09-06T16:19:30.352Z Rule:5:984:Rule.js Rule#rule-ksn5u2pn update rate is 0/min limit 60/min
                                    2021-09-06T16:19:30.353Z Rule:5:904:Rule.js Rule#rule-ksn5u2pn evaluateExpressions() with 0 expressions
                                    2021-09-06T16:19:30.354Z Rule:CRIT Error: Cannot find module 'common/util'
                                    Require stack:
                                    Require stack:
                                    2021-09-06T16:19:30.356Z Rule:5:980:Rule.js Rule#rule-ksm11ihr._evaluate() mutex acquired, evaluating
                                    2021-09-06T16:19:30.356Z Rule:5:984:Rule.js Rule#rule-ksm11ihr update rate is 0/min limit 60/min
                                    2021-09-06T16:19:30.357Z Rule:5:904:Rule.js Rule#rule-ksm11ihr evaluateExpressions() with 0 expressions
                                    2021-09-06T16:19:30.358Z Rule:CRIT Error: Cannot find module 'common/util'
                                    Require stack:
                                    Require stack:
                                  • M Matteburk
                                    /Mattias
                                    Require stack:
                                      Require stack:
                                      Require stack:
                                      Require stack:
                                      Require stack:
                                      Require stack:
                                    CrilleC Online
                                    CrilleC Online
                                    @matteburk Try installing 21200 just to see if you get MSR running again.
                                      The messages in the log you posted indicate that NODE_PATH is incorrectly set, so I now cannot be sure if we're back at your original problem because you have tried to run it from the command line and this log is from that, or if this log is from an attempted systemd startup, which makes no sense because the service file you published earlier sets the environment variable correctly.
                                      I've given you everything you need to get going again. I'm not sure what else to do. You need to figure it out, though, because this is how this and all future builds will be working, and right now, you're the only person I know of that isn't running, so I'm assuming its a local configuration issue and not a package/software issue.
                                      Can you stop any local startup, start again with systemd, and post the startup portion of the log file? I don't want to see the error message again, I need to see all the messages from a Reactor startup under systemd. That will start with the string Reactor <version> starting on <nodejs version> and give me everything up to Startup complete.
                                      M 2 Replies Last reply
                                        Matteburk
                                        @toggledbits ok... yes for sure it is me setting something up wrong... will struggle some more... 🙂
                                          Matteburk
                                          @crille tried .....
