  4. Critical Error after update
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
10 Posts 3 Posters 2.8k Views 3 Watching
    I updated MSR to 21239 and now no rules will run. The log files shows
    Rule:CRIT Error: Cannot find module 'common/util'
    I updated per the docs like always. I have also tried rebuilding the docker image from scratch with the same result. (not changing the data folders) This is Synology Docker Image, latest-generic-amd64. Build number from MSR says latest-21239-b87b5b9
    @toggledbits , What did a break?
    Log File:
    2021-08-28T16:19:12.102Z Rule:5:777:Rule.js Rule#rule-kpw0p0rl dependency notification entity-changed Entity#hubitat>12 from Entity#hubitat>12
    2021-08-28T16:19:12.103Z Rule:5:783:Rule.js Rule#rule-kpw0p0rl requesting eval; entity-changed Entity#hubitat>12
    2021-08-28T16:19:12.103Z Rule:5:993:Rule.js Rule#rule-kpw0p0rl (Pantry Light) evaluate() acquiring mutex
    2021-08-28T16:19:12.104Z Rule:5:997:Rule.js Rule#rule-kpw0p0rl._evaluate() mutex acquired, evaluating
    2021-08-28T16:19:12.104Z Rule:5:1001:Rule.js Rule#rule-kpw0p0rl update rate is 1/min limit 60/min
    2021-08-28T16:19:12.104Z Rule:5:921:Rule.js Rule#rule-kpw0p0rl evaluateExpressions() with 0 expressions
    2021-08-28T16:19:12.105Z Rule:CRIT Error: Cannot find module 'common/util'
    Require stack:
    • /opt/reactor/server/lib/Engine.js
    • /opt/reactor/server/lib/httpapi.js
    • /opt/reactor/app.js
      Require stack:
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      at Module.require (internal/modules/cjs/loader.js:974:19)
      at require (internal/modules/cjs/helpers.js:92:18)
      at Engine._get_lexp_extensions (/opt/reactor/server/lib/Engine.js:857:25)
      at Rule.evaluateExpressions (/opt/reactor/server/lib/Rule.js:921:286)
      at Rule._evaluate (/opt/reactor/server/lib/Rule.js:1011:323)
      at processTicksAndRejections (internal/process/task_queues.js:95:5)
      at async /opt/reactor/server/lib/Rule.js:980:17
    CrilleC 1 Reply Last reply
    • S SweetGenius
      Log File:
      Require stack:
        Require stack:
      CrilleC Online
      CrilleC Online
      @sweetgenius and @toggledbits I also had a lot of errors in my log after update on my bare metal Ubunu. I had to revert to 1.0.0-21200 to have a clean log again.
        How are you starting Reactor on Ubuntu?
          CrilleC Online
          CrilleC Online
          @toggledbits With systemd.
            Add the following line to the Service section of the service file in /etc/systemd/system:
            Environment=NODE_PATH=/home/myuser/reacto
            Then:
            sudo systemctl daemon-reload
            sudo systemctl restart reactor
              Then:
              CrilleC Online
              CrilleC Online
              @toggledbits I suspected you would suggest that so I've just tried that and updated but same errors so I reverted again.
                OK. You need to have that line in there, pointing to the correct (reactor) directory.
                I've just respun the builds as well, missing a new file. Please pull the docker image and redownload the bare metal package/reinstall.
                And while you're at it, do a npm update --no-save on the Ubuntu side.
                • CrilleC Online
                  CrilleC Online
                  Yes, definitely keeping the environment config and will do npm update. There's no new timestamps on the builds in latest directory though?
                    CrilleC Online
                    CrilleC Online
                    @toggledbits Still no luck. npm updated to latest and all other suggestions applied. Should there be a new filename or timestamp on the tar.qz download?
                    Reactor starts but when I run a reaction this shows in alerts:
                    Reaction task "1" failed due to an exception. Please see the log.
                    Require stack:
                    - /home/user/reactor/server/lib/Engine.js
                    - /home/user/reactor/server/lib/httpapi.js
                    - /home/user/reactor/app.js
                    and the log is full of related erros.
                      I pulled a new Docker image and it appears to have fixed the issue. Thank You.
                        164.5k
