  4. [SOLVED] Reactor and LIFX API
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
7 Posts 2 Posters 974 Views 2 Watching
    Has anyone played with the LIFX API thru Reactor? https://api.developer.lifx.com/docs/introduction is their info. I see a lot of curl noted and, admittedly, my API-foo ignorance is only surpassed by my Expressions ignorance.
    I know the API call requires authentication, just having a hard time formatting what goes where in the Reactor fields to facilitate this.
    My reason for tapping their API is that instructions sent from Reactor to the actual bulbs are hit or miss as far as what the results show. Thought was that, perhaps, calling their API may improve this.
    Solved here: https://smarthome.community/post/9919
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
      @gwp1 said in Reactor and LIFX API:
      Since Reactor would control LIFX bulbs through an existing integration with your hub, you're likely having the same problems with your hub, and the hub likely uses that same API. I would focus on troubleshooting the existing link.
      But based on what I read in the API docs, you can generate an access token in your account settings for LIFX. That simplifies things a lot, as you don't have to go through full OAuth2 on the fly. So that would be your first step: create an access token in your account settings.
      It then says that you can supply that token as either HTTP Basic authentication (harder) or an Authorization header (easy). To do that, all you need to do is add this in the Headers field of an HTTP Request action:
          Authorization: Bearer <auth-token-from-account>
      I would try something trivial like toggling a light first. The docs say that the request URL for this would be https://api.lifx.com/v1/lights/nnnn/toggle, where nnnn is the selector for which bulb(s) to change. Put the Authorization header as shown above in this and every request action. This action requires you to use POST, not GET. Other than the header, there is no data to send; all of the data needed is in the URL.
      The URL for this API is to a cloud target. You didn't describe at all how your existing integration is "hit or miss," but I assert that given that it's a cloud-based API and therefore has a ton of dependencies outside your control, doing this from Reactor directly is unlikely to improve average reliability over the long run, unless for some reason your hub's existing integration is terrible and nobody has bothered to notice or care to fix it.
        This is precisely what I was looking for, @toggledbits, thank you. I wanted to float this first so I could give it a kick before returning to the collective for alternate guidance. The issue at hand is that, whilst the lights will go on and off Reactor>Hubitat, they are ignoring the color-changing commands. I wanted to avoid cloud-based anything, obviously, but am looking to see if using the API nets me the same results. If NO, then on to troubleshooting which commands Reactor sends will accomplish the goal.
        Core 2026.1.1
          OK. While you're doing that, I'll retest Hubitat with the only color lamp I have, which isn't LIFX, but should still be using the same Hubitat commands/capabilities.
            @toggledbits Here's the options I see for LIFX in Reactor.
            Core 2026.1.1
              OK. Found a problem recent since 21270 that would affect RGB on Hubitat. Fixed in a build I'm working on now.
                Confirmed via testing that lights are responding to Reactor-issued commands again. Thanks for the quick turnaround, @toggledbits (and for saving my sanity.)
                Core 2026.1.1
                  2.0k
                  3.8k
                  3.3k
