  4. Help with controlling Hue lights through Home Assistant & Reactor
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 3 Posters 1.0k Views 3 Watching
    sethlampman
    Ok so I am trying to do something that I think is simple but apparently not LOL. I want to turn a hue light on yellow when a condition is met. Basically we have really high humidity here in the evenings. When the garage door is open and the humidity is over 60% then I want my hue garage door light to be yellow. If below 60% then I want it to be white. This is simple enough.
    Here is my problem. I cannot find anyway to control the hue color directly from Reactor. There is an x_hass_light.turn_on function but it doesn't do anything when you define a color.
    No problem, I will create a scene in Home Assistant and set my color there, then call that scene from Reactor. (Not elegant, but will work). Created a scene, works great and sets my color the way I want it.
    I go back into Reactor -> Entity Action -> Garage Door Yellow (scene name) and then there is this annoying little box that requires a selection when there is no selection available. There is nothing for me to select and I cannot save because it is expecting input.
    Can anyone give me some advice on how to accomplish what I am trying to do? I would like a way to do this 100% in reactor (set the light to a color of my choosing) but I am OK with a workaround by using HA scenes. I just need it to work without asking me for a section input that isnt there.
    My next step is to create a virtual switch in Vera, then create a an automation in HA that will trigger my color. Then use Reactor to trigger the virtual switch... I think that is kludge and will likely confuse me months later when I go to edit a rule and forget this workflow...
      So here's a pretty hacky way I go about creating actions within Reactor to control HA devices. If the entity doesn't support the commands that are built into MSR, I usually call a system service. To do so your entity would be your Home Assistant System or whatever you have it named. Your action would be x_hass_system.call_service.
      This part I am kind of going off my knowledge of HA since I don't have any Hue lights. What I usually do is create an automation and call the service that sets the hue lights color. Then I click edit in YAML, copy over everything after service and data then use a website like this one to convert the YAML to JSON. Using the JSON output, put that into the data section in the Reactor action (you can delete the automation since we don't need it anymore). Do a test run and see if it works, sometimes HA doesn't like having trigger in the data so you likely will have to play around with the converted JSON string to get it to work.
      If all else fails what you can do is create the automation in HA and trigger the automation in Reactor here a link to a thread where I did just that. The only downside is you have two places where a automation occurs which isn't ideal.
      • S sethlampman
        @sethlampman Huh. I never implemented the scene domain from HA. I'll get that into the next release (this weekend). If you don't want to wait, @Pabla 's method using call_service is correct (see example below of both workaround and final post-update method).
        Edit: Fixed an error in the graphic noted below.
        S 1 Reply Last reply
          sethlampman
          @toggledbits thanks that works great (the workaround). One slight typo though, you have script instead of scene in the graphic.
            163.5k
