  4. Quality of Life Request: Update Button
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
28 Posts 13 Posters 12.0k Views 13 Watching
  • Black CatB Black Cat
    @gwp1 said in Quality of Life Request: Update Button:
    You buy their hub and live within their infrastructure.
    Nup, you can use any old Laptop or RasPi. Runs on Windows or Lynx. i'd love to promote MSR to Homeseer users but it lacks the simplicity hence the backing of the request.
    Realistically, I'm not going to see it happen which is a shame as Patrick has put a lot of time into development for the 2%.
    @black-cat Interesting, I guess I missed that it's available as a paid download for install on whatever platform.
    Black CatB 1 Reply Last reply
      @black-cat said in Quality of Life Request: Update Button:
      I completely understand this position and I want you (all of you) to understand where I currently stand on this (boy, that's a lot of standing)...
      First, I agree that the upgrade issue is important. My long missive wasn't meant to say "not doing it," it was meant to communicate that it's not a simple issue, and isn't one of those features that suddenly appears in the next build after a couple of posts. There are some real issues with usability and stability that have to be taken into account. What I definitely don't want is to have it be a feature that bricks users when they've gotten small parts of the installation wrong, or their system is set up in some weird way. It's a nightmare for the user, obviously, to have their automation suddenly not working, and it's also a nightmare for me to remote-troubleshoot a system where I have no idea what's been done to it, how it got to where it is, what flailing may have happened since it went down, etc. Troubleshooting inside Reactor is hard enough; troubleshooting the rest of the universe around it is not a business I want to be in. I am confident that I can sufficiently engineer, at least for Linux users, a sufficiently robust pre-flight check of the system to reduce the risk of an upgrade going wrong, and that is where a lot of time will be spent. As I said, I already have a running upgrade facility in the recent builds. It does not have the depth of pre-flight that I feel it needs to make me confident that you can be confident in using it... yet.
      Backup and restore is a similar issue, although a slightly more contained problem. I already have a running backup facility in the system. What is not there is a UI for restore, and I've mentioned before, very often the UI for things is as much or more code than the feature itself. It's also a lot harder to test, not just because there are multiple browsers that have to be considered, but because the core features of the product are easy to write automated test tools for, while UI testing tends more toward spending screen time.
      The real usability issue for me, about which I am most concerned, is none of these, though. The real usability issue for me is settings. I don't want you to have to spend time learning or editing YAML (or JSON). I have long had a plan to write a settings subsystem for the UI. This is an incredibly complex problem to solve, and I've prototyped several approaches and, so far, not been satisfied with the results — it's very easy to back yourself into a corner. It cannot be done without changes in core as well, many of which will have to be evolved into the system over time. Evidence of this complexity can be seen in the Home Assistant world, where their team has literally spent years making the transition from YAML configuration of entities and integrations to UI-based.
      I've already read between the lines on this thread, and the backup thread. My current engineering plan is to focus entirely on these three usability issues for the foreseeable future. You will, for some time to come, see a minimum of new core features. I will continue bug-fix and device support updates, but I would guess at this point that you won't see any new major feature upgrades until late Q1 or early Q2 2023. It's going to be a long road. But I believe that the settings issue, in particular, is the real big mover in terms of getting me out of @Black-Cat 's "2%". Adding backup/restore and upgrade will put me on track to an appliance-ready product, which is really my long-term goal.
      Core functionality has been the focus for over two years. I agree it's time to make "expert mode" an option, not a requirement.
        @toggledbits I have a small script running in background to update msr via docker, at my command, when I'm outside and I don't want to ssh into the machine. I for one will love a flag or similar to know a new version is available and do my own thing. I've not looked at the entities, to be honest.
        Semplification (such as automatic device discovery and a click to add to the engine) is what will make a huge difference for the average brother in-law trying to lightly automate stuff - I agree.
          @therealdb said in Quality of Life Request: Update Button:
          Check out the reactor_system.update_available attribute on the Reactor System (reactor_system>system) entity.
            @toggledbits @therealdb I've used this to create a Pushover notification to my watch. This also surfaces in the Current Alerts pane.
              I'm getting Telegram.....
              I'd have Alexa tell me, but I have no idea what time of day updates might be made available 😉
                Black CatB Offline
                Black CatB Offline
                Black Cat
                #27
                So, there is no misconception about paid or free software, Homeseer is available as a 30-day free trial for anyone to test, it often comes up on special as well .
                Just to ease any further concerns it has also been around for over 20 years - try the freebie you might be surprised how good it is as an OS for HA.
                aka Zedrally
                • Black CatB Offline
                  Black CatB Offline
                  Black Cat
                  @toggledbits , thank you for your in-depth reply, there is no need to rush as there are no Raspberrys available (in our region) until mid-March (if we are lucky).
                  aka Zedrally
                    165.4k
