  4. Using MSR with BrowserMod to change pages/dashboards
6 Posts 3 Posters 3.0k Views 3 Watching
  • C Offline
    C Offline
    Cadwizzard
    Hass: 2022.11.3
    Hardware: Pi
    MSR: latest-22310-a6da8097
    I'm trying to use MSR in automations to change the page displayed on a wall tablet (Windows and Edge in Kiosk mode)
    Example use would be motion detected will change to the security dashboard, or heating turns on, shows the heating dashboard.
    Screenshot_20221122_193138.png I have Browser Mod installed and working and the entities are present in MSR. My only option for the entity which controls the page/dashboard displayed is "x_hass.call_service"
    What I need to change is the state of the entity
    Is this possible in MSR? Despite much searching i'm unsure what service to call to set the state?
    I have tried using service: browser_mod.navigate but get an error
    (this service detailed here https://smarthomescene.com/guides/how-to-setup-browser-mod-2-0-in-home-assistant/ )
    Also trying to lay the data out like this with/out quotes and other variations has not helped
      "/home-overview/heating"
    PablaP 1 Reply Last reply
    • C Cadwizzard
      Hass: 2022.11.3
      Hardware: Pi
      wrote on last edited by Pabla
      @cadwizzard I don't use Browser Mod but I will still try to help. First off whenever you call a service in MSR you need to first identify the service name, then in the data section you need to format it using YAML JSON.
      In your case I would set it up like this:
      To make sure I have this shown correctly can you head over to Home Assistant Developer Tools, Services and set up the service `Browser mod: navigate' and fill it out so that your device changes to the view you'd like it to. Then click go to yaml mode and send a screenshot of that.
      toggledbitsT C 2 Replies Last reply
        @pabla said in Using MSR with BrowserMod to change pages/dashboards:
        then in the data section you need to format it using YAML.
        Just a detail... that's JSON (as it should be).
          @toggledbits Corrected, HA uses YAML and MSR uses JSON
            I will make a future version of HassController accept either JSON or YAML in that field to make it easier to implement from a working HA example.
              C Offline
              C Offline
              Cadwizzard
              @pabla Thank You!
              Perfect guess on your part. This works as an example. Appreciate you pointing me in the right direction
              @toggledbits also appreciate your intent to make the UI yaml friendly at some point too. This json/yaml thing caught me out, along with the code formatting required.
              Thanks again to all 🙂
              Side note to anyone using kiosk type modes (like in windows especially). It might seem nice to have the browser restart after x hours in the kiosk settings to take you back to a home/start page in HA, but that will break browsermod and force you to re-register the browser (so, the better way is to use MSR or another way to control that behavior, if you want it)
