  3. Repeater for Hue
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
Repeater for Hue
7 Posts 3 Posters 2.1k Views 3 Watching
    So, I just installed (not permanently, lucky me) a new outdoor light strip under my pool SPA. While I'm waiting for more creative ways to properly fix it, I noticed that it's not getting the signal, unless I open the nearest window and take a bulb outside - not properly the ideal solution.
    Anyone has any tip or a decent repeater? I only have one bulb (it came free with Alexa, I don't like bulbs very much, I prefer zwave switches) and two light strips far away. The hub is centrally localed, but my outdoor walls are all concrete, plus brick on the inside, so I think the ZigBee signal is somewhat attenuated.
      I am trying to get a better understanding:
      What zigbee hub are you using? I suppose the hue is the bulb?
      Hue are really a bit weird for zigbee and are not even fully ZLL compliant. They seem to have problems being repeaters on the network and do not properly update status and require a constant poll from the hub. It is generally preferable to use a hue hub for these. The only hub handling this really well it appears to be this:
      Phoscon ConBee II Zigbee 3.0 Universal USB Gateway Including deCONZ and Phoscon Apps, Home Automation, Home Assistant, ioBroker, Zigbee2MQTT : Amazon.it: Computers
      As far as repeaters, for generic zigbee, the old centralite (now belonging to eZLO) plugs were a life saver for me as the vera's zigbee antenna is very weak. I generally try to avoid having a dedicated repeater so maybe add any other regular zigbee device in between? Something like this?
      LEDVANCE 1 Pack Smart Indoor Socket for Integrating Conventional Devices into Smart Home Compatible with Alexa, Google and Hue, SMART + ZB PLUG : Amazon.it: Industrial & Scientific
      This is what I used but got them for $6 back then.
      https://www.amazon.com/Centralite-3-ZigBee-Appliance-Module/dp/B01CKKVX30/ref=sr_1_2?dchild=1&keywords=centralite+outlet&qid=1589222823&sr=8-2
        I'm using a hue hub. I literally have 4 zigbee devices and I'm sure the problem is problem the placement of the outdoor wifi repeater. I'll try with a plug and a new arrangement for the wifi. Thanks!
          sender
          With a conbee2 you can "play" with the frequency channels to avoid busy wifi channels...
            The hue hub can do that too, albeit with 4 channels only: 11, 15, 20, 25. Other controllers can't. It's one of the reasons why I am considering switching to deconz... And why I avoid zigbee as much as possible. Others give you the choice to start at a certain frequency but you can't switch afterwards.
              I won't buy more zigbee devices, but for led strips this is the easiest path.
                So, I moved it near a window and it's reaching the new strip outside. Previously it was in a central location, in the closet where I have all the stuff (Vera, Zway, modems, eth switch and so on). While I was sleeping 🙂 I had an epiphany and moving it under my desk (which is in front of the pool - hard to focus these days :D) worked out.
                Now back to spend 50 EUR to buy new rails to hold a 30 Eur strip... crazy times we're living in!
                Thanks for the help.
                  154.4k
