  4. EzloControler access credentials timeout?
12 Posts 2 Posters 2.4k Views 2 Watching
  • I Offline
    I Offline
    ibrewster
    wrote on last edited by ibrewster
    I have Multi-System reactor set to with both my Vera Plus and Ezlo Plus - and up to a while ago, both were working. Recently, however, I noticed that it didn't seem to be communicating with my Ezlo Plus correctly. Looking at the logs, I see this:
    [latest-22337]2022-12-09T03:44:49.980Z <EzloController:INFO> EzloController#ezlo: connecting to hub "90XXXXXX"
    [latest-22337]2022-12-09T03:44:49.980Z <EzloController:ERR> EzloController#ezlo: failed to get access credentials: [FetchError] network timeout at: https://vera-us-oem-autha11.mios.com/autha/auth/username/reactor?SHA1Password=<long_string>c&PK_Oem=1&TokenVersion=2 [-]
    [latest-22337]2022-12-09T03:44:49.980Z <EzloController:INFO> EzloController#ezlo will retry in 75000ms; this was attempt 17
    So apparently it is getting a timeout when trying to connect to vera to authorize? How can I fix this, or does it simply not work any more?
    • toggledbitsT Online
      toggledbitsT Online
      Is your Ezlo username really reactor? That seems a bit odd...
      Edit: I'm having no trouble connecting with (my own) correct account credentials.
      • I Offline
        I Offline
        ibrewster
        Yes, I set up a user specifically for reactor to use, with a username of reactor. Also, as I mentioned, when I originally set this up a while ago, it did work - only recently has it stopped working. Of course, if the user/password WAS wrong, (or something changed so it wouldn't work any more) I would expect a different error than "network timeout" 🙂
          toggledbitsT Online
          OK. Well, not having any problems with my regular access credentials. EzloController is working.
          • I Offline
            I Offline
            ibrewster
            Checking the log again this morning, I now have a different error - apparently whatever was causing the network timeout was resolved, but now I'm getting this (after a restart of reactor):
            [latest-22337]2022-12-09T14:29:41.939Z <EzloController:INFO> EzloController#ezlo successful local connection (authenticated) to "90000478"
            [latest-22337]2022-12-09T14:29:41.940Z <EzloController:INFO> EzloController#ezlo starting hub inventory
            [latest-22337]2022-12-09T14:29:41.980Z <EzloController:INFO> EzloController#ezlo hub "90000478" is h2.1 (undefined) firmware "2.0.33.2116.2"
            [latest-22337]2022-12-09T14:29:41.980Z <System:WARN> System#ezlo>system attempt by caller to set attribute value to undefined
            [latest-22337]2022-12-09T14:29:41.980Z <System:CRIT> Error: traceback [-]
            Error: traceback
                at System.setAttribute (/opt/reactor/server/lib/Entity.js:454:152)
                at EzloController._process_hub_info (/opt/reactor/server/lib/EzloController.js:1516:768)
                at /opt/reactor/server/lib/EzloController.js:1354:48
            [latest-22337]2022-12-09T14:29:42.138Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_5f5199de12a3b716d5ba2969: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.138Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
                at Group.setAttribute (/opt/reactor/server/lib/Entity.js:460:19)
                at Group.setAttributes (/opt/reactor/server/lib/Entity.js:511:39)
                at Group._syncAttribute (/opt/reactor/server/lib/entities/Group.js:110:31)
                at Group.addMember (/opt/reactor/server/lib/entities/Group.js:118:227)
                at /opt/reactor/server/lib/EzloController.js:1612:61
                at EzloController._process_hub_devices (/opt/reactor/server/lib/EzloController.js:1576:226)
                at /opt/reactor/server/lib/EzloController.js:1413:48
            [latest-22337]2022-12-09T14:29:42.139Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_5f5199de12a3b716d5ba296c: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.139Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.141Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_5f5199de12a3b716d5ba296e: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.141Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.142Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_5f5199de12a3b716d5ba2970: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.142Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.143Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_5f63e44712a3b715b80ffcd2: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.143Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.146Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_618063af12a3b712364c7dc8: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.146Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.148Z <EzloController:ERR> EzloController#ezlo error creating entity ValueSensor#ezlo>device_618063af12a3b712364c7dcf: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.149Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.150Z <EzloController:ERR> EzloController#ezlo error creating entity ValueSensor#ezlo>device_618063af12a3b712364c7dd1: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.150Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.153Z <EzloController:ERR> EzloController#ezlo error creating entity ValueSensor#ezlo>device_618063af12a3b712364c7dd3: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.154Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f8012a3b72072c17b25 [-]
            [latest-22337]2022-12-09T14:29:42.155Z <EzloController:ERR> EzloController#ezlo error creating entity Light#ezlo>device_6182b52012a3b7121fd6594b: [ReferenceError] Capability sys_group not extended (ezlo>room_5fed146312a3b716fad9f58d [-]
            [latest-22337]2022-12-09T14:29:42.155Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5fed146312a3b716fad9f58d [-]
            [latest-22337]2022-12-09T14:29:42.157Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_618ff90912a3b7122edeaccd: [ReferenceError] Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.157Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_5f451f7512a3b72072c17b24 [-]
            [latest-22337]2022-12-09T14:29:42.158Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_61901ff112a3b71209e73282: [ReferenceError] Capability sys_group not extended (ezlo>room_6190206412a3b71209e7328a [-]
            [latest-22337]2022-12-09T14:29:42.159Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_6190206412a3b71209e7328a [-]
            [latest-22337]2022-12-09T14:29:42.160Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6190203012a3b71209e73286: [ReferenceError] Capability sys_group not extended (ezlo>room_6190206412a3b71209e7328a [-]
            [latest-22337]2022-12-09T14:29:42.160Z <EzloController:CRIT> ReferenceError: Capability sys_group not extended (ezlo>room_6190206412a3b71209e7328a [-]
            [latest-22337]2022-12-09T14:29:42.161Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'switch') [-] failed to process devices: [undefined2]
            [latest-22337]2022-12-09T14:29:42.161Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'switch') [-]
                at EzloController._match_criterion (/opt/reactor/server/lib/EzloController.js:1119:84)
                at EzloController._map_device (/opt/reactor/server/lib/EzloController.js:1171:48)
                at /opt/reactor/server/lib/EzloController.js:1592:58
            [latest-22337]2022-12-09T14:29:42.162Z <EzloController:ERR> EzloController#ezlo failed to complete inventory: [TypeError] Cannot read properties of undefined (reading 'switch') [-]
            [latest-22337]2022-12-09T14:29:42.162Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'switch') [-]
            [latest-22337]2022-12-09T14:29:42.172Z <EzloController:NOTICE> EzloController#ezlo connection closed: 1002
            [latest-22337]2022-12-09T14:29:42.173Z <EzloController:INFO> EzloController#ezlo will retry in 5000ms; this was attempt 1
            • I Offline
              I Offline
              ibrewster
              So perhaps the network timeout errors were some sort of temporary ban on my IP due to repeated logins? Just a thought, may not make any sense.
                toggledbitsT Online
                OK. Your post is, unfortunately, short of the posting guidelines, so please review those. I'd like to know what platform you are running on, and how you install/run (docker, bare-metal, etc.) (and that on every new post you create, please -- see the guidelines in this category).
                • I Offline
                  I Offline
                  ibrewster
                  Reactor version: latest-22337-1a0a685f
                  OS: Ubuntu 22.04.1 LTS
                  Reactor installed vis Docker (docker-compose to be exact), version 20.10.12, build 20.10.12-0ubuntu4
                  Hub involved: Ezlo Plus Firmware 2.0.33.2116.2 Advanced Scenes 1.56
                    toggledbitsT Online
                    Intel processor?
                    • I Offline
                      I Offline
                      ibrewster
                      AMD EPYC 7262
                        toggledbitsT Online
                        OK. If you update your docker image and container, you should get version 22343. You apparently have an Ezlo device that is mentioning in its inventory an "item" (data element), but the item doesn't exist (it looks like an inconsistency in device data from Ezlos API). This version should complete inventory (unless there are other data consistency problems we haven't seen yet). There will continue to be warnings for setting undefined on an attribute, and possibly device match failing. Don't worry about those. I will be unavailable the rest of the day. I will contact you later to get a data collection from you so I can analyze their API responses in more detail and see if there's anything more I need to do about it.
                        I 1 Reply Last reply
                          I Offline
                          I Offline
                          ibrewster
                          Reactor version: latest-22343-ef2b8f75
                          OS: Ubuntu 22.04.1 LTS, AMD EPYC 7262
                          Yes, much better - things seem to be working now. I'd attach a log (as you mentioned there were warnings about setting undefined, among other things), but apparently I can't do that yet, so I'll stand by for directions on the data collection.
                          Thanks for your help.
                            155.5k
