  4. [MSR] reactor-espresense to track ESPresense BTLE devices/beacons
2 Posts 2 Posters 823 Views 3 Watching
    My main objective was to track cars/motorcycles in real time, as they are leaving/entering the property, and I've experimented with different solutions, including WiFi devices, but I was not satisfied.
    So, I have approached ESPresense to track BLE devices. I'm not yet 100% satisfied with my main use case (we'll see), but I learnt a couple of things about proximity along the way, so I've built a controller to natively track beacons/devices in MSR. The devices and beacons could be tracked inside Home Assistant, but I don't like the way it's doing it, and I wanted a very device-oriented solution, instead of a room one.
    Introducing reactor-espresense.
    You'll have a device containing various info, like the current room where the beacon/device is currently in, the distance, and so on, for each BTLE device you'll choose to map. Configuration is needed to map your devices, and a look at the doc to understand how devices/beacons are detected away is suggested.
    I've not invested into commands so much, but it's on my TODO list.
    Feel free to post your requests/comments. Thanks!
      @therealdb Gonna keep an eye on this as I've just implemented a slew of these around the house via MQTT in Home Assistant.
        154.3k
