  3. Need help in finding the right smart switch for my kitchen lights
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
2 Posts 2 Posters 1.2k Views 2 Watching
    Madmaxneo
    wrote on last edited by Madmaxneo
    Hello,
    I have a kitchen light that can be controlled by two switches, using either to turn it off or on. I have been slowly changing things over to be a smart home but this is the first switch I am attempting to install.
    I am in a double wide modular home (mobile) that was built in 1994.
    At first I thought I would need a 3 way switch but when taking the normal switches apart I realized that was incorrect because the wiring on my switches are different than anything I could find online.
    For one a 3 way smart switch requires 5 wires and there are only 2 wires going into the primary switch with 3 wires going into the secondary switch from the primary switch (at least I think the 3 wires connect the two switches together). Images will be attached of the wiring.
    There are two wires (one black and one white) going into the first switch and 3 wires (black, white, and red) going out of that and into the second switch (I assume). The odd thing is the red wire going to the second switch is connected to the white wire going into the first switch and the white wire going into the second switch seems to be a bridge wire or a traveler wire. Not exactly sure. You will see what I mean in the images.
    I need to know what kind of smart switch I can use in this set up with one remaining a normal switch.
    Note that for some reason the images got switched around when uploading them. The image with 2 wires on one side and 3 on the other is what I think is the primary and the image with just 3 wires is the secondary.
      Most switches from GE and Leviton these days are three-way compatible/ready, but you need to use the companion switch of the same brand and product family (I think GE even has a package with the two together in the same box).
      However, you should not do this yourself. If you are asking here, you do not know what you need to know to do this job safely, and you need to hire a licensed electrician. Practically speaking, wire color means nothing; while there are standards and conventions, there is no telling if your home was wired to those from the start, or if work done since it was built did not alter the original conditions. Nobody here can safely advise you on the current purpose of each of these wires; it would take testing with a meter or other devices to ascertain how the wires are being used, and then, which terminals on the new switch would be connected to which wires on each end. The voltages present here can, and given the opportunity will kill you and/or burn your home down. The electrician would also be able to ascertain if a neutral is present for the new switch, which many require, and many older homes in North America were built without. If that's the case, you may need to find a switch that does not require a neutral (these are available); so consult the electrician before buying any replacement products.
        151.5k
