  4. Reactor: How to call Hass service for noob
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 3 Posters 1.1k Views 3 Watching
  • W Offline
    W Offline
    wokwon
    wrote on last edited by wokwon
    Reactor 23063 running on Windows Bare Metal.
    Home assistant 2023.3.1
    ESPHome 2023.2.4
    I've been trying a few ways using some results from search to call a Hass service as a reaction in a Reactor rule.
    Specifically, when the PIR in the room senses motion, wake the NsPanel screen.
    My Reactions otherwise so far are basic If this then that so I'm way behind what others are doing.
    What I want to call as a Reaction:
    What I've tried (a few variations on):
    What happens:
    [latest-23063]2023-03-07T07:45:21.688Z <wsapi:ERR> wsapi: error thrown handling client message [Object]{ "command": "perform", "entity": "WOKHASS1>system", "action": "x_hass_system.call_service", "parameters": { "service": "ESPHome: nspensuite_send_command_printf", "data": "page home" }, "qid": 75 }
    [latest-23063]2023-03-07T07:45:21.688Z <wsapi:CRIT> TypeError: Cannot read properties of null (reading '1') [-]
        at HassController.performOnEntity (C:\reactor\reactor\server\lib\HassController.js:584:108)
        at System.perform (C:\reactor\reactor\server\lib\Entity.js:707:56)
        at WSAPI.clientMessage (C:\reactor\reactor\server\wsapi\wsapi.js:499:48)
        at WebSocket.<anonymous> (C:\reactor\reactor\server\wsapi\wsapi.js:290:158)
        at WebSocket.emit (node:events:520:28)
        at WebSocket.emit (node:domain:475:12)
        at Receiver.receiverOnMessage (C:\reactor\reactor\node_modules\ws\lib\websocket.js:1059:20)
        at Receiver.emit (node:events:520:28)
        at Receiver.emit (node:domain:475:12)
        at Receiver.dataMessage (C:\reactor\reactor\node_modules\ws\lib\receiver.js:517:14)
    If someone can convert the 'call service' to a 'reaction' for me, or share their own similar thing I think that's what I need to achieve this goal.
    I suspect if I'm even close to being on the right track, my problems are probably formatting like curly braces etc and lack thereof.
    Thanks in advance.
    CrilleC 1 Reply Last reply
      • W wokwon
        ESPHome 2023.2.4
        What happens:
        Thanks in advance.
        @wokwon Your service should be esphome.nspensuite_send_command_printf and the data cmd: page home
        W 1 Reply Last reply
        • CrilleC Crille
          W Offline
          W Offline
          wokwon
          @Crille said in Reactor: How to call Hass service for noob:
          cmd: page home
          Perfect, it works, thank you so much.
            163.5k
