  4. [SOLVED] New iblind and zwaveJScontroller/MSR not communicating
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
solved
44 Posts 3 Posters 22.9k Views 3 Watching
  • T tamorgen
    @gwp1 ,
    I really don't have any sort of weekly config on mine. I haven't noticed mine drifting at all, but a weekly recalibrate wouldn't be a bad idea.
    I have rules for hourly refreshing the the cover, position, and switch positions that are now pretty much legacy of the old device class. I only have two of the IB2 devices left, and they're in non critical rooms ( guest bedroom and mudroom). I'll replace those later this year. Once those are gone, I'll be able to remove those three hourly rules.
    I have reactions set up for each set of windows in a room. Most rooms only have two windows, so I group those. The lone exception is my family room, where I have four windows, but on different walls. I have those set up on two separate reactions, which allows me to separately set the blinds to a partial open position when the sun is shining directly in. The largest events with the blinds are at sunrise, sunset, and when the house is vacant or someone arrives, when I'll set the reactions from the rule, and I have "Wait for completion" enabled after each call for a reaction. It takes a couple of minutes for all my blinds to open/close when it's called. I initially didn't do this, but iBlinds recommended not calling them all at once (thus the pause in between each call for a blind to open/close). For the most part, this has helped tremendously with the IB2 motors, although they still had their fair share of problems, which is why I've been replacing them all this year.
    I call the reactions from rulesets, so I don't have to reinvent the wheel each time I want to perform an action on a window. It also allows me to make an adjustment once and not 10 different times in different rules.
    @tamorgen we are very much aligned in our approach.
    • My office has four windows, one front-facing and three smaller side-facing. I group the three together.
    • My main room covers the single kitchen, single dining room, and two paired living room blinds.
    • My master bedroom has two paired together, the master bath a single that I do not group with the bedroom.
    • Guest rooms are single independents.
    I, too, do reactions for:
    • open (Day)
    • close (Evening/Night)
    • tilt (this is used for Away for all, also for "sun defer" as the sun moves around the house)
    I do reactions as well for the very same reason: single place to edit. I know @toggledbits will cringe but my "Open ALL" , "Tilt ALL", and "Close ALL" are reactions that contain the other room-specific reactions and are called by rulesets.
    I've increased my delays again back to 00:00:05 (was down to 00:00:02) just to see if that may help the initial issue that spawned this topic. I don't need to have all blinds close at once (sure, it would be cool) - it's still fun for guests when the actions start in the office at the front of the house and just file their way around until all are completed.
      @toggledbits we have fail!
      Added two more iblinds to the test. They failed to respond so I isolated one of them and did the following tests on node 8-0:
      LR Left OPEN: cover.open
      LR Left CLOSE: cover.close
      LR Left @20: position.set = .80 (resulting in the blind being tilted open 20%, "top inside").
      Results:
      cover.open = iblind opens, position of 50
      cover.close = iblind moves to position of 50 <---expected result, position 0
      position.set = iblind moves to position of 80
      As this Reaction was to run BOTH left and right blinds I removed the right blind and ran the left solo as the kitchen and DR are (both still working fine, btw). For reference, Kitchen was existing unit and was re-interviewed to be current, DR is a brand new unit. LR's are existing units re-interviewed.
      Log forthcoming.
      @gwp1 said in [SOLVED-ish] New iblind and zwaveJScontroller/MSR not communicating:
      Log forthcoming.
      Looked at the log. ZWaveJSController is consistently, correctly issuing the right commands and values for all actions in every case. ZWaveJS is responding with a successful acknowledgement of the command, and later passing an update notification with the node's position having a value consistent with the command previously given in every case. It appears that ZWaveJS understands what MSR is asking it to do, sending that to the device, and the device is sending back updates indicating it has done what has been asked. If that's not what the device actually does, then I assert it's firmware or hardware issue with the device.
      The log contains errors for an attempt to refresh (using the zwave_device.refresh action) non-existent node 7 (that is, ZWaveJS reports that the node doesn't exist; the entity may still exist as a zombie). That has no effect operationally, just bringing to your attention that after excluding/including devices, you may have missed a now-dead entity.
        Log forthcoming.
        @toggledbits Node 7-0 has cleaned itself up in MSR (it was cleared out in HA's ZWJSC). I got the same from the logs, was hoping you would see something I missed.
        The firmware is on the latest. I'll doublecheck the firmware on the ZWave Stick that runs these from HA. Thanks @toggledbits, as usual.
        Updating this thread to [SOLVED] as whatever the issue may be it's not MSR's.
          A final update here... adding in a minimum of 00:00:05 delays has resolved the issues.
            163.8k
