  4. TILT-ZWAVE2.5-ECO tilt_sensor.state (primary) = NULL
14 Posts 2 Posters 3.1k Views 2 Watching
  • SnowmanS Offline
    SnowmanS Offline
    Snowman
    @togglebits I am curious as to why the tilt_sensor.state (primary) = NULL. I believe it should show true or false. I have to use binary_sensor.state instead in my rules.
    Again, not sure if this is related to Reactor/ZwaveJSController implementation or the actual Z-Wave JS UI docker version. I have copied, below, the attributes of the tilt sensor in hopes it can help.
    Thanks in advance.
    Reactor version 23302
    ZWaveJSController version 23254
    Z-Wave JS UI version 9.3.0.724519f
    zwave-js version 12.2.3
    battery_power.level=0.99
    battery_power.since=1699401727360
    binary_sensor.state=false
    tamper.state=true
    tilt_sensor.state=null
    x_debug.dt={"entity_class":"Binary Sensor","match":"deviceClass.generic.key=7","description":"Z-Wave Plus Tilt Sensor","default_name":"Tilt Sensor","model":"TILTZWAVE2.5-ECO","capabilities":["tilt_sensor"],"primary_attribute":"tilt_sensor.state","values":[{"valueId":"32:currentValue:","capabilities":{"tilt_sensor":{"attributes":{"state":{}}}}}],"manufacturerId":330,"productType":4,"productId":3}
    x_zwave_values.Battery_isLow=false
    x_zwave_values.Battery_level=99
    x_zwave_values.Binary_Sensor_Any=false
    x_zwave_values.Configuration_Basic_Sets_for_Association_Group_2=0
    x_zwave_values.Configuration_Send_Reports=0
    x_zwave_values.Manufacturer_Specific_manufacturerId=330
    x_zwave_values.Manufacturer_Specific_productId=3
    x_zwave_values.Manufacturer_Specific_productType=4
    x_zwave_values.Notification_Access_Control_Door_state=23
    x_zwave_values.Notification_Access_Control_Door_state_simple=23
    x_zwave_values.Notification_Home_Security_Cover_status=3
    x_zwave_values.Notification_Power_Management_Battery_maintenance_status=0
    x_zwave_values.Notification_UNKNOWN_0x46=23
    x_zwave_values.Notification_alarmLevel=0
    x_zwave_values.Notification_alarmType=0
    x_zwave_values.Version_firmwareVersions=["10.1"]
    x_zwave_values.Version_hardwareVersion=2
    x_zwave_values.Version_libraryType=6
    x_zwave_values.Version_protocolVersion="4.5"
    x_zwave_values.Wake_Up_controllerNodeId=1
    x_zwave_values.Wake_Up_wakeUpInterval=14400
    zwave_device.capabilities=[48,112,113,114,128,132,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Notification Sensor"
    zwave_device.impl_sig="23305:1:22057:1"
    zwave_device.is_beaming=false
    zwave_device.is_listening=false
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.last_wakeup=1699563172708
    zwave_device.manufacturer_info=[330,4,3]
    zwave_device.node_id=24
    zwave_device.specific_class="Notification Sensor"
    zwave_device.status=1
    zwave_device.status_text="asleep"
    zwave_device.version_info=[null,"10.1"]
    zwave_device.wakeup_interval=14400
    SnowmanS 1 Reply Last reply
      Try downloading the latest zwavejs_data.zip from the download server, and place the ZIP file in your config directory and restart Reactor.
      • SnowmanS Offline
        SnowmanS Offline
        Snowman
        Working now. I no longer see binary_sensor.state for the tilt sensor which was erratic at times showing the garage door was open while it was actually closed. I can now use the tilt_sensor.state (primary) = true/false
        Thanks again. Much appreciated.
        • SnowmanS Offline
          SnowmanS Offline
          Snowman
          @toggledbits I just noticed that the tilt_sensor.state = false now and no longer can be used in my rule. I have to use door_sensor.state instead.
          I cannot tell when the issue started and not sure if this is related to Reactor/ZwaveJSController implementation or the actual Z-Wave JS UI docker version. I have copied, below, the attributes of the tilt sensor in hopes it can help.
          Thanks in advance.
          Reactor version 24190
          ZWaveJSController version 23326
          Z-Wave JS UI version 9.14.5
          zwave-js version 12.12.3
          battery_maintenance.charging=null
          battery_maintenance.rechargeable=false
          battery_maintenance.replace=false
          battery_maintenance.state=null
          battery_power.level=1
          battery_power.since=1720636775292
          door_sensor.state=true
          power_source.source=null
          tamper.state=true
          tilt_sensor.state=false
          x_debug.dt={"entity_class":"Binary Sensor","match":"deviceClass.generic.key=7","description":"Z-Wave Plus Tilt Sensor","default_name":"Tilt Sensor","model":"TILTZWAVE2.5-ECO","capabilities":["tilt_sensor"],"primary_attribute":"tilt_sensor.state","values":[{"valueId":"32:currentValue:","capabilities":{"tilt_sensor":{"attributes":{"state":{}}}}},{"match":{"endpoint":0,"commandClass":48,"metadata.ccSpecific.sensorType":255},"capabilities":{"tilt_sensor":{"attributes":{"state":{}}}}}],"manufacturerId":330,"productType":4,"productId":3}
          x_zwave_values.Battery_level=100
          x_zwave_values.Binary_Sensor_Door_Window=true
          x_zwave_values.Notification_Access_Control_Door_state=22
          x_zwave_values.Notification_Access_Control_Door_state_simple=22
          zwave_device.impl_sig="23326:1:23318:2"
          zwave_device.last_wakeup=1720636775220
            Looks like this is the result of a change introduced in ZWaveJS version 12.12.0 (see change #6958 linked there).
            Let's see if we can deal with this the easy way first. I've updated the device definition data. You can download it (ZIP archive zwavejs_data.zip) from the Reactor download server and put the ZIP archive into your config directory (do not unzip it); restart Reactor. Let's see if that brings tilt_sensor back.
              SnowmanS Offline
              SnowmanS Offline
              Snowman
              @toggledbits That fixed it. Thank you sir.
              battery_maintenance.state="normal"
              battery_power.since=1720778246637
              tamper.state=true
              tilt_sensor.state=true
              • SnowmanS Snowman
                tamper.state=true
                SnowmanS Offline
                SnowmanS Offline
                Snowman
                @toggledbits I appears the tilt_sensor.state = false is back again after I upgraded both Reactor and ZWaveJSController to version 24257. It was working fine with ZWaveJSController version 24242.
                I can certainly stop using this entity and use the door_sensor.state instead.
                I did check the latest changes for zwave-js 13.2.0 and did not see any thing that may have been introduced causing this.
                Thanks in advance.
                Reactor version 24257
                ZWaveJSController version 24257
                Z-Wave JS UI version 9.18.1
                zwave-js version 13.2.0
                battery_maintenance.charging=0
                battery_maintenance.rechargeable=0
                battery_power.since=null
                tamper.state=true
                x_debug.dt={"entity_class":"Binary Sensor","match":"deviceClass.generic.key=7","description":"Z-Wave Plus Tilt Sensor","default_name":"Tilt Sensor","model":"TILTZWAVE2.5-ECO","capabilities":["tilt_sensor"],"primary_attribute":"tilt_sensor.state","values":[{"valueId":"32:currentValue:","capabilities":{"tilt_sensor":{"attributes":{"state":{}}}}},{"match":{"endpoint":0,"commandClass":48,"metadata.ccSpecific.sensorType":255},"capabilities":{"tilt_sensor":{"attributes":{"state":{}}}}},{"match":{"endpoint":0,"commandClass":113,"metadata.ccSpecific.notificationType":6},"capabilities":{"tilt_sensor":{"attributes":{"state":{"expr":"value === 22"}}}}}],"manufacturerId":330,"productType":4,"productId":3}
                zwave_device.impl_sig="24256:1:24192:1"
                zwave_device.is_beaming=true
                zwave_device.last_wakeup=1726513928400
                zwave_device.max_data_rate=100000
                zwave_device.version_info=[4,"10.1"]
                  Have you opened and closed the door since updating? Because it's a notification sensor, Reactor won't have the right values until it gets notifications from the device.
                  • SnowmanS Snowman
                    Thanks in advance.
                    tamper.state=true
                    SnowmanS Offline
                    SnowmanS Offline
                    Snowman
                    I did open and close the garage door after updating Reactor. More than once. I even removed the battery to see if it would make a difference.
                    I am looking at the Notification values under ZWaveJS UI ans can see that the Window/door state do toggle between TRUE/FALSE when the door opens and closes. Nothing unusual here.
                    Looking at Binary Sensor values, I am seing this though. Makes sense?
                    When the garage door Opens
                    When the garage door Closes
                      The Z-Wave JS UI doesn't show notifications here, only states. All of those are states. Notifications are class number 113.
                      At this point, I'll need to see logs for what happens when you open and close this thing. Here's what you need to do:
                      1. In your ZWaveJSController config in reactor.yaml, add the following line:
                             config:  # don't add this line, included for indenting reference only
                               monitor_nodes: [24]  # add this line
                      2. Restart Reactor.
                      3. Open and close the door two or three times.
                      4. Remove or comment out the line you added in step 1 and restart Reactor again.
                      5. Post the logs/zwavejs_24_monitor.json file to the URL I am going to DM to you in chat.
                        2. Restart Reactor.
                        SnowmanS Offline
                        SnowmanS Offline
                        Snowman
                        @toggledbits I now have the requested log file.
                          OK. Pull the zwavejs_data.zip update file from the server and put it into your config directory. The stop Reactor (not restart), clear out storage/entities/zwavejs, and start Reactor again.
                            SnowmanS Offline
                            SnowmanS Offline
                            Snowman
                            @toggledbits The ZIP file fixed the issue. The tilt_sensor.state working as expected. Thanks
                            tamper.state=true
                              Perfect. Thanks for sending the log. Don't forget to remove or comment out the monitor_nodes line if you haven't already... it will consume disk space to exhaustion if you don't disable it.
                              Edit: the issue, by the way, was the new device data had handling dependent on which version of Z-Wave JS was running, because the device is reported differently on earlier versions (as you pointed out earlier), but the test in the new data file was broken. Easy fix.
                                1.1k
                                158.5k
