  4. MSR “Unexpected end of JSON input” after container update
5 Posts 2 Posters 1.3k Views 2 Watching
    sykong
    Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config
    NODE_PATH /opt/reactor:/opt/reactor/node_modules
    [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1
    [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined)
    [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage
    [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules
    [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172
    [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331
    [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300
    [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283
    [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353
    [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069
    [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293
    [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146
    [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211
    [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093
    [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283
    [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107
    [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324
    [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339
    [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058
    [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172
    [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351
    [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109
    [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344
    [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313
    [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331
    i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all.
    [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-]
        at JSON.parse (<anonymous>)
        at /opt/reactor/server/lib/Controller.js:464:51
        at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36)
        at new Controller (/opt/reactor/server/lib/Controller.js:45:42)
        at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9)
        at /opt/reactor/server/lib/Controller.js:101:37
    Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all.
        at _T (/opt/reactor/server/lib/i18n.js:468:37)
        at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25)
        at /opt/reactor/app.js:381:140
    [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-]
        at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54)
        at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50)
        at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67)
        at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179)
        at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100)
        at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47)
        at new Rule (/opt/reactor/server/lib/Rule.js:378:47)
        at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36)
        at /opt/reactor/server/lib/Engine.js:263:53
    i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available.
    Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available.
        at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36)
        at /opt/reactor/server/lib/HassController.js:1117:370
    I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
    Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config
    [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0
    [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined)
    [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage
    [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules
    [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172
    [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331
    [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300
    [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283
    [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353
    [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069
    [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293
    [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146
    [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211
    [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093
    [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283
    [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057
    [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324
    [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023
    [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057
    [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057
    [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351
    [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050
    [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048
    [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313
    [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331
    [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-]
        at new Controller (/opt/reactor/server/lib/Controller.js:45:43)
        at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9)
    [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-]
        at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45)
        at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49)
        at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65)
        at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179)
        at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101)
        at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47)
        at new Rule (/opt/reactor/server/lib/Rule.js:371:47)
        at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36)
        at /opt/reactor/server/lib/Engine.js:828:53
        at _T (/opt/reactor/server/lib/i18n.js:614:37)
        at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25)
        at /opt/reactor/server/lib/HassController.js:1133:374
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    How do I fix this?
      This can happen if the container has a disorderly shutdown, or when you get a disk full condition. It looks like you have at least one broken entity metadata file, and possibly a broken rule.
      To fix the state file, stop the Reactor container and remove the entire storage/entities/reactor_system subdirectory. This data will simply be rebuilt, and it's harmless.
      The rule is another matter. Go into storage/rules and look for zero-length files. If you find any, delete them.
      Then restart Reactor. That should get you up and running again, but, you'll need to restore the damaged (now deleted) rules from a backup.
      Edit: also, the messages are not entirely the expected rhythm, and I'm thinking you've redacted some messages. Please don't do that. For any and every error, I see to several lines (a dozen or more is good) in front of the error, without redaction. It seems a few messages that should accompany the error are missing, and these should have vital details that would make this process easier to interpret and let me give you much more concise instructions.
      S 1 Reply Last reply
        sykong
        Thank you for the quick reply. I didn’t intentionally remove any logs. I copied whatever was showing as the container logs in portainer (100 lines?) without realising that there is a reactor log file. I’ve now included the logs from the log file for the latest restart below.
        [latest-24057]2024-02-28T23:56:27.199Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0
        [latest-24057]2024-02-28T23:56:27.200Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined)
        [latest-24057]2024-02-28T23:56:27.201Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage
        [latest-24057]2024-02-28T23:56:27.201Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules
        [latest-24057]2024-02-28T23:56:27.204Z <app:INFO> Configured locale (undefined); selected locale(s) en-US.UTF-8
        [latest-24057]2024-02-28T23:56:27.265Z <app:INFO> Loaded locale en-US for en-US
        [latest-24057]2024-02-28T23:56:27.269Z <Structure:null> Module Structure v23172
        [latest-24057]2024-02-28T23:56:27.271Z <Capabilities:null> Module Capabilities v23331
        [latest-24057]2024-02-28T23:56:27.301Z <Capabilities:NOTICE> System capabilities loaded from core distribution, data version 24004 revision 1
        [latest-24057]2024-02-28T23:56:27.337Z <Plugin:null> Module Plugin v22300
        [latest-24057]2024-02-28T23:56:27.344Z <TimerBroker:null> Module TimerBroker v22283
        [latest-24057]2024-02-28T23:56:27.347Z <Entity:null> Module Entity v22353
        [latest-24057]2024-02-28T23:56:27.351Z <Controller:null> Module Controller v23069
        [latest-24057]2024-02-28T23:56:27.368Z <default:null> Module Ruleset v22293
        [latest-24057]2024-02-28T23:56:27.368Z <default:null> Module Rulesets v22146
        [latest-24057]2024-02-28T23:56:27.376Z <GlobalExpression:null> Module GlobalExpression v23211
        [latest-24057]2024-02-28T23:56:27.392Z <Predicate:null> Module Predicate v23093
        [latest-24057]2024-02-28T23:56:27.396Z <AlertManager:null> Module AlertManager v22283
        [latest-24057]2024-02-28T23:56:27.399Z <Rule:null> Module Rule v24057
        [latest-24057]2024-02-28T23:56:27.402Z <GlobalReaction:null> Module GlobalReaction v22324
        [latest-24057]2024-02-28T23:56:27.405Z <Engine:null> Module Engine v24023
        [latest-24057]2024-02-28T23:56:27.422Z <httpapi:null> Module httpapi v24057
        [latest-24057]2024-02-28T23:56:27.439Z <wsapi:null> Module wsapi v24057
        [latest-24057]2024-02-28T23:56:27.440Z <app:NOTICE> Starting Structure...
        [latest-24057]2024-02-28T23:56:27.445Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
        [latest-24057]2024-02-28T23:56:27.447Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
        [latest-24057]2024-02-28T23:56:27.494Z <TaskQueue:null> Module TaskQueue 21351
        [latest-24057]2024-02-28T23:56:27.495Z <VeraController:null> Module VeraController v24050
        [latest-24057]2024-02-28T23:56:27.545Z <Structure:INFO> Structure#1 loading controller interface hass (HassController)
        [latest-24057]2024-02-28T23:56:27.558Z <HassController:null> Module HassController v24048
        [latest-24057]2024-02-28T23:56:27.799Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
        [latest-24057]2024-02-28T23:56:27.804Z <DynamicGroupController:null> Module DynamicGroupController v22313
        [latest-24057]2024-02-28T23:56:27.808Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
        [latest-24057]2024-02-28T23:56:27.815Z <SystemController:null> Module SystemController v23331
        [latest-24057]2024-02-28T23:56:28.493Z <SystemController:NOTICE> SystemController#reactor_system resetting (reactor_system capability updated)
        [latest-24057]2024-02-28T23:56:28.497Z <Structure:INFO> Starting controller VeraController#vera
        [latest-24057]2024-02-28T23:56:28.497Z <VeraController:NOTICE> VeraController#vera starting...
        [latest-24057]2024-02-28T23:56:28.506Z <Controller:INFO> VeraController#vera loaded vera capabilities ver 22253 rev 1 format 1
        [latest-24057]2024-02-28T23:56:28.532Z <Controller:INFO> VeraController#vera loaded implementation data ver 23109 rev 1 format 1
        [latest-24057]2024-02-28T23:56:28.532Z <Structure:INFO> Starting controller HassController#hass
        [latest-24057]2024-02-28T23:56:28.532Z <HassController:NOTICE> HassController#hass starting...
        [latest-24057]2024-02-28T23:56:28.535Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23289 rev 1 format 1
        [latest-24057]2024-02-28T23:56:28.555Z <Controller:INFO> HassController#hass loaded implementation data ver 24004 rev 3 format 1
        [latest-24057]2024-02-28T23:56:28.555Z <Structure:INFO> Starting controller DynamicGroupController#groups
        [latest-24057]2024-02-28T23:56:28.564Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
        [latest-24057]2024-02-28T23:56:28.565Z <Structure:INFO> Starting controller SystemController#reactor_system
        [latest-24057]2024-02-28T23:56:28.569Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
        [latest-24057]2024-02-28T23:56:28.698Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
        [latest-24057]2024-02-28T23:56:28.698Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
        [latest-24057]2024-02-28T23:56:28.700Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
        [latest-24057]2024-02-28T23:56:28.700Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state
        [latest-24057]2024-02-28T23:56:28.701Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values
        [latest-24057]2024-02-28T23:56:28.707Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.20.230:8123/api/websocket
        [latest-24057]2024-02-28T23:56:28.711Z <app:NOTICE> Starting HTTP server and API...
        [latest-24057]2024-02-28T23:56:28.714Z <httpapi:NOTICE> httpapi: starting HTTP service on port "8111"
        [latest-24057]2024-02-28T23:56:28.717Z <app:NOTICE> Starting Reaction Engine...
        [latest-24057]2024-02-28T23:56:28.717Z <Engine:INFO> Reaction Engine starting
        [latest-24057]2024-02-28T23:56:28.718Z <Engine:INFO> Checking rule sets...
        [latest-24057]2024-02-28T23:56:28.721Z <Engine:INFO> Checking rules...
        [latest-24057]2024-02-28T23:56:28.806Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/var/reactor/storage/states] failed to read cs-rule-ll4rewlj in /var/reactor/storage/states/cs-rule-ll4rewlj.json: [SyntaxError] Unexpected end of JSON input [-]
        [latest-24057]2024-02-28T23:56:28.806Z <app:ERR> Failed to start engine: [SyntaxError] Unexpected end of JSON input [-]
        [latest-24057]2024-02-28T23:56:28.806Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-]
        [latest-24057]2024-02-28T23:56:28.813Z <httpapi:NOTICE> httpapi: listening
        [latest-24057]2024-02-28T23:56:28.824Z <app:NOTICE> Starting WSAPI...
        [latest-24057]2024-02-28T23:56:28.824Z <wsapi:NOTICE> wsapi: starting version 24057
        [latest-24057]2024-02-28T23:56:28.946Z <HassController:NOTICE> HassController#hass connected, starting protocol
        [latest-24057]2024-02-28T23:56:28.950Z <HassController:INFO> HassController#hass successful authentication with ws://192.168.20.230:8123; fetching initial data...
        [latest-24057]2024-02-28T23:56:28.955Z <HassController:INFO> HassController#hass Hass reports version "2024.2.5" location Home timezone Asia/Singapore state RUNNING safe_mode false
        [latest-24057]2024-02-28T23:56:28.960Z <HassController:ERR> HassController#hass reported Hass version "2024.2.5" is not supported!
        [latest-24057]2024-02-28T23:56:29.000Z <HassController:NOTICE> HassController#hass no signature match for sun.sun
        [latest-24057]2024-02-28T23:56:29.065Z <HassController:NOTICE> HassController#hass no signature match for fan.living_rm_fan
        [latest-24057]2024-02-28T23:56:29.066Z <HassController:NOTICE> HassController#hass no signature match for fan.dining_rm_fan
        [latest-24057]2024-02-28T23:56:29.066Z <HassController:NOTICE> HassController#hass no signature match for fan.mbr_fan
        [latest-24057]2024-02-28T23:56:29.066Z <HassController:NOTICE> HassController#hass no signature match for fan.br2_fan
        [latest-24057]2024-02-28T23:56:29.067Z <HassController:NOTICE> HassController#hass no signature match for fan.br3_fan
        [latest-24057]2024-02-28T23:56:29.076Z <HassController:NOTICE> HassController#hass no signature match for remote.rm_mini3_d5
        [latest-24057]2024-02-28T23:56:29.077Z <HassController:NOTICE> HassController#hass no signature match for remote.rm_pro_f5
        [latest-24057]2024-02-28T23:56:29.077Z <HassController:NOTICE> HassController#hass no signature match for remote.rm_mini3_b3
        [latest-24057]2024-02-28T23:56:29.077Z <HassController:NOTICE> HassController#hass no signature match for remote.rm_pro_15
        [latest-24057]2024-02-28T23:56:29.142Z <HassController:NOTICE> HassController#hass no signature match for update.us_8_60w
        [latest-24057]2024-02-28T23:56:29.143Z <HassController:NOTICE> HassController#hass no signature match for update.uap_nanohd
        [latest-24057]2024-02-28T23:56:29.156Z <HassController:NOTICE> HassController#hass no signature match for update.uap_ac_lite
        [latest-24057]2024-02-28T23:56:29.179Z <HassController:NOTICE> HassController#hass no signature match for fan.smartmi_2s_fan
        [latest-24057]2024-02-28T23:56:29.200Z <HassController:NOTICE> HassController#hass no signature match for update.eap615_wall_firmware_update
        [latest-24057]2024-02-28T23:56:29.207Z <HassController:NOTICE> HassController#hass no signature match for update.eap615_mbr_firmware_update
        [latest-24057]2024-02-28T23:56:29.213Z <Controller:INFO> HassController#hass 0 dead entities older than 86400000s purged
        [latest-24057]2024-02-28T23:56:29.220Z <Controller:NOTICE> Controller HassController#hass is now online.
        [latest-24057]2024-02-28T23:56:29.298Z <Controller:INFO> VeraController#vera 0 dead entities older than 86400000s purged
        [latest-24057]2024-02-28T23:56:29.301Z <Controller:NOTICE> Controller VeraController#vera is now online.
        [latest-24057]2024-02-28T23:56:29.302Z <DynamicGroupController:INFO> All controllers ready, setting up dynamic groups
        [latest-24057]2024-02-29T00:01:25.492Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:05:32.389Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/lang
        [latest-24057]2024-02-29T00:05:32.590Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:05:34.507Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:06:10.134Z <wsapi:INFO> client "192.168.20.220#1" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:06:20.158Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:06:26.166Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:07:34.988Z <wsapi:INFO> client "192.168.20.220#2" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:07:46.603Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:08:18.063Z <wsapi:INFO> client "192.168.20.220#3" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:09:14.411Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:10:35.124Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:11:16.348Z <wsapi:INFO> client "192.168.20.220#4" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:11:26.971Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:16:27.973Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:21:03.150Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:21:03.318Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:21:26.486Z <wsapi:INFO> client "192.168.20.220#5" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:21:29.616Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:24:53.554Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:25:03.217Z <wsapi:INFO> client "192.168.20.220#6" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:25:58.102Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:26:03.789Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:26:03.902Z <wsapi:INFO> client "192.168.20.220#7" closed, code=1001, reason=
        [latest-24057]2024-02-29T00:26:04.461Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/lang
        [latest-24057]2024-02-29T00:26:04.669Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:26:07.368Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:26:32.453Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:28:13.706Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:28:13.953Z <wsapi:INFO> client "192.168.20.220#8" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:28:34.125Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:28:39.981Z <wsapi:INFO> client "192.168.20.220#9" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:28:47.556Z <wsapi:INFO> client "192.168.20.220#10" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:28:52.218Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:29:23.273Z <Notifier:null> Module Notifier v22283
        [latest-24057]2024-02-29T00:29:23.314Z <default:null> Module NotifyAlert v21092
        [latest-24057]2024-02-29T00:29:23.384Z <default:null> Module NotifySMTP v21083
        [latest-24057]2024-02-29T00:29:23.393Z <default:null> Module NotifyProwl v21195
        [latest-24057]2024-02-29T00:29:23.397Z <default:null> Module NotifyPushover v21195
        [latest-24057]2024-02-29T00:29:23.402Z <default:null> Module NotifySyslog v21083
        [latest-24057]2024-02-29T00:29:23.407Z <default:null> Module NotifyCallMeBot v21195
        [latest-24057]2024-02-29T00:29:23.412Z <default:null> Module NotifyTelegram v21221
        [latest-24057]2024-02-29T00:31:12.183Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:31:32.546Z <wsapi:WARN> wsapi: timed out waiting for ping reply (pong) from client "192.168.20.220#11"
        [latest-24057]2024-02-29T00:31:32.547Z <wsapi:INFO> client "192.168.20.220#11" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:31:33.457Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:31:39.848Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:32:31.496Z <wsapi:INFO> client "192.168.20.220#12" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:33:34.831Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:36:13.198Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:36:34.075Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:38:26.909Z <wsapi:INFO> client "192.168.20.220#13" closed, code=1001, reason=
        [latest-24057]2024-02-29T00:38:27.833Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/lang
        [latest-24057]2024-02-29T00:38:28.403Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:38:31.988Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:41:35.501Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:42:57.382Z <wsapi:INFO> client "192.168.20.220#14" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:43:13.705Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:43:32.393Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:44:00.527Z <wsapi:INFO> client "192.168.20.220#15" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:44:35.635Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:45:46.136Z <wsapi:INFO> client "192.168.20.220#16" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:46:36.540Z <httpapi:INFO> httpapi: API request from ::ffff:127.0.0.1: GET /api/v1/alive
        [latest-24057]2024-02-29T00:47:18.038Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:47:33.185Z <wsapi:INFO> client "192.168.20.220#17" closed, code=1005, reason=
        [latest-24057]2024-02-29T00:48:00.759Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:48:33.177Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.20.220: GET /api/v1/systime
        [latest-24057]2024-02-29T00:49:01.074Z <wsapi:INFO> client "192.168.20.220#18" closed, code=1006, reason=
        [latest-24057]2024-02-29T00:49:33.746Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.20.220
        [latest-24057]2024-02-29T00:50:04.365Z <wsapi:INFO> client "192.168.20.220#19" closed, code=1006, reason=
        I deleted the “storage/entities/reactor_system” folder and restarted Reactor. The entity states are updated when viewing “entities”. But the states are not updated when viewing via the rules.
        There were no 0 kb sized file in the rules folder for me to delete. I did find a zero sized file in states “cs-rule-ll4rewlj.json” but that corresponding rule “rule-ll4rewlj.json” was last modified in 2023. Should I delete the entire rules folder?
        To restore the rules from a backup, do I just copy the files in?
          sykong
          I noticed the filename in the log. This file is indeed also 0kb. I deleted it and rector is now working fine.
          [latest-24057]2024-02-28T23:56:28.806Z IndividualFileStrategy:ERR [IndividualFileStrategy][IndividualFileStrategy#/var/reactor/storage/states] failed to read cs-rule-ll4rewlj in /var/reactor/storage/states/cs-rule-ll4rewlj.json: [SyntaxError] Unexpected end of JSON input [-]
            Thank you! That really helps. The zero-sized storage/states/cs-rule-ll4rewlj.json is the only file you need to remove. Just stop the container, remove the file, and restart. That should clear it. The data in that file will be rebuilt.
              161.4k
              1.3k
