  4. Need Testers
Need Testers
78 Posts 8 Posters 47.2k Views 8 Watching
    @gwp1 said in Need Testers:
    I have noticed that the TOOLS>Restart Reactor button does not work
    Make sure you've done a hard refresh on the browser to ensure that it has loaded all the latest files for the UI.
    Failing that, hit F12 (usually) in your browser to open a Developer window, and then hit the Restart button and see if anything gets logged on the browser side.
    @toggledbits Completely slipped my mind to approach it from the browers. Derp.
    Yep.
    Logged in as the default admin with updated pwd.
    *Hubitat C-7 2.5.2.135
    Core 2026.10.1
    MSR: latest-26287-0a7107d5
    • T tamorgen
      @toggledbits,
      Thanks for the updated version. I'll test it this evening after work.
      I was only able to provide limited diagnostic information this morning before I headed to work. Reverting to 24115 latest version fixed the immediate issue of reactions not functioning, so everything would function normally while I was gone for the day.
      If the reactions continue to hang with the revised version, I'll provide more detailed information and logs this evening.
      @toggledbits said in Need Testers:
      @tamorgen said in Need Testers:
      I'm not seeing the login.html in the reactorui directory
      Oy. OK. Fresh build is now up.
      those reactions are hanging.
      I'm running this in my house, not seeing any issues. The engine is the same for 24115 and userauth; they are completely in sync except for the required elements to support user authentication, which has nothing to do with reaction. Still, anything is possible, but I wouldn't be able to discern much without the usual rules still applying: when things aren't going as expected, look at the logs... follow the posting guidelines...
      Slow day at work. I was able to remote into my home server and installed the updated release. The login functions properly, and I'm not seeing the hanging reactions as I was this morning.
      This is really great. Now I can securely access my reactor UI remotely if I have the need. The only thing that would make it better is 2FA, but this is a fantastic update.
        Yep.
        When you reload the page, do you get any similar errors, specifically for /api/v1/systime? Is the time display in the page header correct (showing both host and browser times)?
          @toggledbits no errors for /api/v1/systime and the browser time and system time are identical, perhaps a split second apart as they tick by.
          Core 2026.10.1
            @therealdb the fixed build I just put up (to include the missing HTML file) also includes a potential fix for VirtualEntityController to preserve attributes across upgrades. Let's see how it works out.
            @toggledbits yep, it's working beautifully 🎉 time to delete some junky code I wrote for the occasion 🙂
            I'll play with AuthN&AuthZ on May 1st, since it's a public holiday here in Italy and rain is forecast.
              @therealdb said in Need Testers:
              Outstanding. I can apply the same type of fix to MQTTController, so I'll do that.
                @toggledbits I have not done that yet. One step at a time 🙂 The Not found issue has been resolved with your latest build and Access Control is WAE. The Reactions issue I noted has also not reappeared.
                I have noticed that the TOOLS>Restart Reactor button does not work and I see nothing in the logs whatsoever even after "elevator button-ing" it (press press press press press press press).
                @toggledbits I have finally finished up the SSL and am getting this from my local browser:
                Going to spin this off into it's own thread.
                Core 2026.10.1
                  Build 24120
                  • Mostly code cleanup and tightening around application restriction.
                  • Should fix Tools > Restart Reactor issue
                    Not hearing a lot of grumbling, which is a Good Thing so far. Any and all feedback welcome. Please comment on the docs, too, if you have anything. On my end, I'm out of things to do on this feature, nothing to add, so I'm just waiting for fixing/tweaking.
                      @toggledbits thanks for this feature! I sort of had to volunteer as a tester as I originally did a feature request for authentication support...
                      Anyway, seems to work nicely, although only about an hour of testing behind. Will keep you posted if anything unexpected comes up. You could update docs though:
                      "1. Copy the template users.yaml-dist from the dist-config distribution directory to your config directory."
                      --> "1. Copy the template users.yaml-dist from the /opt/reactor/dist-config distribution directory to your config directory. Rename it as users.yaml file."
                      (at least for me as a Docker user it wasn't immediately clear where to find this template)
                      PablaP 1 Reply Last reply
                        @tunnus Yes this would be a good improvement to the docs.. you weren't the only one who made this mistake lol!
                          #32
                          well, I actually knew to rename this file, but it took a while to find that template (as I've used MSR container for years now and did not remember the location of dist-config)
                          • N Offline
                            N Offline
                            Hi, I used Portainer to change the image from latest to userauth and it was easy and thanks for this update!
                            current configuration:
                            Synology NAS/Docker/Reactor (Multi-hub) userauth-24120-7745fb8d
                            unexpected:
                            when I try to log in on http://10.0.0.1:8111/dashboard/ as admin:admin, I'm redirect to reactor http://10.0.0.1:8111/reactor/en-US/ and not to dashboard
                            This happens on Chrome and Edge
                            Features/suggestion that I image:
                            Guest user has access to:
                            all dashboard set to public (homescreen - all public group tile - all public single tile)
                            where group tile are rooms/hubs/virtual/weather on homescreen dashboard
                            and single tile are all the entities: devices/virtual devices/etc
                            Admin can use option on tile VISIBLE/HIDDEN icon by clicking on it.
                            If a tile is set to HIDDEN, all entities associated with it will also be hidden. Setting VISIBLE on specific entities will not be respected. Setting hidden on specific entities it will be not visible to guests.
                            So Public means VISIBLE.
                            imaging it:
                            -Docker on Synology NAS
                            -HASS Docker 2026.8.1
                            -ZWaveJS-UI 11.22.3
                            -Update 16/08/2026
                              #34
                              Not sure if others are experiencing the same, but with this build (userauth-24120-7745fb8d) if I go to Manual (i.e. http://reactor-ip:8111/docs/), it takes a very long time before search can be used as it stays in "initializing search" state. At least I haven't noticed the same with earlier releases. Browser is Chrome.
                                @toggledbits another thing noticed with this build is that deleting global reactions does not work.
                                How to reproduce:
                                1. create reaction
                                2. delete it
                                3. refresh browser
                                4. reaction is back...
                                  How to reproduce:
                                  1. create reaction
                                  2. delete it
                                  3. refresh browser
                                  #36
                                  @tunnus said in Need Testers:
                                  I see it. It's also happening to latest-24115. I've got it fixed on my end and will roll a build on Sunday.
                                  @noelab said in Need Testers:
                                  I think I've got that nailed down as well. Look for Sunday's build.
                                  @Pabla said in Need Testers:
                                  I think better still, have Reactor docker containers copy dist-config to your data directory (as dist-config, not overwriting any existing real config), so no special steps are needed to find those files, they are just there. Sunday's build.
                                    #37
                                    Anyone else noticed this? @noelab, @Pabla? Other thing I found out today was that there's some kind of a log problem going on, Docker logs claim that reactor.log file cannot be found:
                                    2024/05/11 21:48:36	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                    2024/05/11 21:48:32	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                                    2024/05/11 21:48:32	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                    2024/05/11 21:48:32	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                                    2024/05/11 21:48:32	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                    2024/05/11 21:48:09	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                    2024/05/11 21:48:08	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                                    2024/05/11 21:48:08	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                    2024/05/11 21:48:08	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                                    2024/05/11 21:48:08	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                    2024/05/11 21:46:50	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                    2024/05/11 21:46:45	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                                    2024/05/11 21:46:45	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                    2024/05/11 21:46:45	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                                    But reactor.log file seems to in place when checked via terminal:
                                    N PablaP 2 Replies Last reply
                                      N Offline
                                      N Offline
                                      @tunnus yes, some problem here too from the reactor log in container manager. Hope this may help too:
                                      2024/05/08 21:20:46	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                      2024/05/08 21:20:46	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                                      2024/05/08 21:20:46	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                                      2024/05/08 21:20:46	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                      2024/05/08 21:20:46	stdout	[userauth-24120]2024-05-08T19:20:46.401Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 7ms (from 1715196046401<5/8/2024, 9:20:46 PM> to 1715196046408<5/8/2024, 9:20:46 PM>)
                                      2024/05/08 21:20:45	stdout	[userauth-24120]2024-05-08T19:20:45.347Z <Timer:null> Timer#rule-lq1iq5i3 just a note: I'm setting a delay of only 8ms (from 1715196045347<5/8/2024, 9:20:45 PM> to 1715196045355<5/8/2024, 9:20:45 PM>)
                                      2024/05/08 21:20:42	stdout	[userauth-24120]2024-05-08T19:20:42.093Z <Timer:null> Timer#rule-lq5ri09p just a note: I'm setting a delay of only 8ms (from 1715196042093<5/8/2024, 9:20:42 PM> to 1715196042101<5/8/2024, 9:20:42 PM>)
                                      2024/05/08 21:19:04	stdout	[userauth-24120]2024-05-08T19:19:04.547Z <Timer:null> Timer#rule-lq5rgx5t just a note: I'm setting a delay of only 8ms (from 1715195944547<5/8/2024, 9:19:04 PM> to 1715195944555<5/8/2024, 9:19:04 PM>)
                                      2024/05/08 21:19:02	stdout	[userauth-24120]2024-05-08T19:19:02.765Z <Timer:null> Timer#rule-lq5rhvua just a note: I'm setting a delay of only 8ms (from 1715195942765<5/8/2024, 9:19:02 PM> to 1715195942773<5/8/2024, 9:19:02 PM>)
                                      2024/05/08 21:19:02	stdout	[userauth-24120]2024-05-08T19:19:02.153Z <EzloController:null> remapped item action to [Object]{ "item": "switch", "value": true, "method": "hub.item.value.set", "parameters": { "value": { "value": true } } }
                                      2024/05/08 21:19:01	stdout	[userauth-24120]2024-05-08T19:19:01.110Z <Timer:null> Timer#rule-lq5qgdau just a note: I'm setting a delay of only 8ms (from 1715195941110<5/8/2024, 9:19:01 PM> to 1715195941118<5/8/2024, 9:19:01 PM>)
                                      2024/05/08 21:18:59	stdout	[userauth-24120]2024-05-08T19:18:59.226Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715195939226<5/8/2024, 9:18:59 PM> to 1715195939234<5/8/2024, 9:18:59 PM>)
                                      2024/05/08 21:17:10	stdout	[userauth-24120]2024-05-08T19:17:10.678Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715195830678<5/8/2024, 9:17:10 PM> to 1715195830686<5/8/2024, 9:17:10 PM>)
                                      2024/05/08 21:14:44	stdout	[userauth-24120]2024-05-08T19:14:44.540Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715195684540<5/8/2024, 9:14:44 PM> to 1715195684548<5/8/2024, 9:14:44 PM>)
                                      2024/05/08 21:09:18	stdout	[userauth-24120]2024-05-08T19:09:18.150Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715195358150<5/8/2024, 9:09:18 PM> to 1715195358158<5/8/2024, 9:09:18 PM>)
                                      2024/05/08 21:05:44	stdout	[userauth-24120]2024-05-08T19:05:44.738Z <Timer:null> Timer#rule-ks56ms0b just a note: I'm setting a delay of only 8ms (from 1715195144738<5/8/2024, 9:05:44 PM> to 1715195144746<5/8/2024, 9:05:44 PM>)
                                      2024/05/08 21:05:44	stdout	[userauth-24120]2024-05-08T19:05:44.719Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715195144719<5/8/2024, 9:05:44 PM> to 1715195144727<5/8/2024, 9:05:44 PM>)
                                      2024/05/08 21:00:16	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                      2024/05/08 21:00:14	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                                      2024/05/08 21:00:12	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                                      2024/05/08 21:00:12	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                                      2024/05/08 21:00:12	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                      2024/05/08 20:59:52	stdout	[userauth-24120]2024-05-08T18:59:52.886Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715194792886<5/8/2024, 8:59:52 PM> to 1715194792894<5/8/2024, 8:59:52 PM>)
                                      2024/05/08 20:58:22	stdout	[userauth-24120]2024-05-08T18:58:22.585Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715194702585<5/8/2024, 8:58:22 PM> to 1715194702593<5/8/2024, 8:58:22 PM>)
                                      2024/05/08 20:56:26	stdout	[userauth-24120]2024-05-08T18:56:26.917Z <Timer:null> Timer#rule-lq5rh1ns just a note: I'm setting a delay of only 8ms (from 1715194586917<5/8/2024, 8:56:26 PM> to 1715194586925<5/8/2024, 8:56:26 PM>)
                                      2024/05/08 20:56:06	stdout	[userauth-24120]2024-05-08T18:56:06.581Z <Timer:null> Timer#rule-lq1iq5i3 just a note: I'm setting a delay of only 8ms (from 1715194566581<5/8/2024, 8:56:06 PM> to 1715194566589<5/8/2024, 8:56:06 PM>)
                                      2024/05/08 20:54:49	stdout	[userauth-24120]2024-05-08T18:54:49.514Z <Timer:null> Timer#rule-lq5rgx5t just a note: I'm setting a delay of only 8ms (from 1715194489514<5/8/2024, 8:54:49 PM> to 1715194489522<5/8/2024, 8:54:49 PM>)
                                      2024/05/08 20:54:49	stdout	[userauth-24120]2024-05-08T18:54:49.058Z <Timer:null> Timer#rule-lq5qgdau just a note: I'm setting a delay of only 8ms (from 1715194489058<5/8/2024, 8:54:49 PM> to 1715194489066<5/8/2024, 8:54:49 PM>)
                                      2024/05/08 20:54:43	stdout	[userauth-24120]2024-05-08T18:54:43.027Z <Timer:null> Timer#rule-lq5qgdau just a note: I'm setting a delay of only 8ms (from 1715194483027<5/8/2024, 8:54:43 PM> to 1715194483035<5/8/2024, 8:54:43 PM>)
                                      2024/05/08 20:50:44	stdout	[userauth-24120]2024-05-08T18:50:44.225Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715194244225<5/8/2024, 8:50:44 PM> to 1715194244233<5/8/2024, 8:50:44 PM>)
                                      2024/05/08 20:50:43	stdout	[userauth-24120]2024-05-08T18:50:43.256Z <EzloController:null> remapped item action to [Object]{ "item": "dimmer", "value_expr": "min(100,max(0,floor(parameters.level*100+0.5)))", "method": "hub.item.value.set", "parameters": { "value": { "value_expr": "min(100,max(0,floor(parameters.level*100+0.5)))" } } }
                                      2024/05/08 20:47:23	stdout	[userauth-24120]2024-05-08T18:47:23.713Z <Timer:null> Timer#rule-ks56ms0b just a note: I'm setting a delay of only 8ms (from 1715194043713<5/8/2024, 8:47:23 PM> to 1715194043721<5/8/2024, 8:47:23 PM>)
                                      2024/05/08 20:47:23	stdout	[userauth-24120]2024-05-08T18:47:23.693Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715194043693<5/8/2024, 8:47:23 PM> to 1715194043701<5/8/2024, 8:47:23 PM>)
                                      2024/05/08 20:47:22	stdout	[userauth-24120]2024-05-08T18:47:22.392Z <EzloController:null> remapped item action to [Object]{ "item": "switch", "value": false, "method": "hub.item.value.set", "parameters": { "value": { "value": false } } }
                                      2024/05/08 20:46:10	stdout	[userauth-24120]2024-05-08T18:46:09.716Z <default:null> Module NotifyAlert v21092
                                      2024/05/08 20:46:10	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                      2024/05/08 20:46:10	stdout	[userauth-24120]2024-05-08T18:46:09.704Z <default:null> Module NotifyPushover v21195
                                      2024/05/08 20:46:10	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                                      2024/05/08 20:46:10	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                                      2024/05/08 20:46:10	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                      2024/05/08 20:46:09	stdout	[userauth-24120]2024-05-08T18:46:09.014Z <Notifier:null> Module Notifier v22283
                                      2024/05/08 20:46:06	stdout	    at /opt/reactor/server/lib/VirtualEntityController.js:357:319
                                      2024/05/08 20:46:06	stdout	    at VirtualEntityController._load_devices (/opt/reactor/server/lib/VirtualEntityController.js:644:114)
                                      2024/05/08 20:46:06	stdout	    at Entity.setPrimaryAttribute (/opt/reactor/server/lib/Entity.js:563:19)
                                      2024/05/08 20:46:06	stdout	Error: Invalid primary attribute assignment; capability not assigned (state_sensor.value)
                                      2024/05/08 20:46:06	stdout	[userauth-24120]2024-05-08T18:46:06.542Z <VirtualEntityController:CRIT> Error: Invalid primary attribute assignment; capability not assigned (state_sensor.value) [-]
                                      2024/05/08 20:46:06	stdout	Error: Invalid primary attribute assignment; capability not assigned (string_sensor.value)
                                      2024/05/08 20:46:06	stdout	[userauth-24120]2024-05-08T18:46:06.541Z <VirtualEntityController:CRIT> Error: Invalid primary attribute assignment; capability not assigned (string_sensor.value) [-]
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.410Z <VirtualEntityController:null> Module VirtualEntityController v24117
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.391Z <SystemController:null> Module SystemController v24076
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.382Z <OWMWeatherController:null> Module OWMWeatherController v22294
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.161Z <EzloController:null> Module EzloController v23345
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.090Z <VeraController:null> Module VeraController v24050
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.089Z <TaskQueue:null> Module TaskQueue 24113
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.993Z <HassController:null> Module HassController v24115
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.726Z <InfluxFeed:null> Module InfluxFeed v23341
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.682Z <wsapi:null> Module wsapi v24115
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.439Z <httpapi:null> Module httpapi v24119
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.231Z <Engine:null> Module Engine v24113
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.229Z <GlobalReaction:null> Module GlobalReaction v24099
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.197Z <Rule:null> Module Rule v24115
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.176Z <AlertManager:null> Module AlertManager v24099
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.107Z <Predicate:null> Module Predicate v23093
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.045Z <GlobalExpression:null> Module GlobalExpression v24099
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.023Z <default:null> Module Rulesets v24099
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.022Z <default:null> Module Ruleset v24099
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.952Z <Controller:null> Module Controller v24099
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.929Z <Entity:null> Module Entity v24108
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.925Z <TimerBroker:null> Module TimerBroker v22283
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.460Z <Plugin:null> Module Plugin v22300
                                      2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.311Z <Capabilities:null> Module Capabilities v23331
                                      2024/05/08 20:46:03	stdout	[userauth-24120]2024-05-08T18:46:03.269Z <Structure:null> Module Structure v24110
                                      2024/05/08 20:46:03	stdout	[userauth-24120]2024-05-08T18:46:03.059Z <app:null> Local date/time using configured timezone and locale formatting is "5/8/2024, 8:46:03 PM"
                                      2024/05/08 20:46:03	stdout	[userauth-24120]2024-05-08T18:46:03.058Z <app:null> Loaded locale en-US for en-US
                                      2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.890Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8
                                      2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.750Z <app:null> Resolved timezone=Europe/Rome, environment TZ=Europe/Rome; offset minutes from UTC=120
                                      2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.656Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules
                                      2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.656Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage
                                      2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.656Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined)
                                      2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.584Z <app:null> Reactor build userauth-24120-7745fb8d starting on v20.10.0 /usr/local/bin/node
                                      2024/05/08 20:46:02	stdout	NODE_PATH /opt/reactor:/opt/reactor/node_modules
                                      2024/05/08 20:46:02	stdout	Reactor userauth-24120-7745fb8d app 24120 configuration from /var/reactor/config
                                      -ZWaveJS-UI 11.22.3
                                      -Update 16/08/2026
                                        It looks like you may have a misconfiguration in your VirtualEntityController config. Can you post the config section for that?
                                        N 1 Reply Last reply
                                          N Offline
                                          N Offline
                                          some devices are created for test purpose so maybe there are errors
                                          code_text
                                          • id: virtual
                                            implementation: VirtualEntityController
                                            enabled: true
                                            config:
                                            entities:
                                            HomeMode
                                               template: Binary Sensor
                                               name: v00 Automation Mode
                                            Indici Temperatura Umidità
                                               name: v00 Temp Inside HOT
                                               template: Value Sensor
                                               name: v00 Temp Outside HOT
                                               name: v00 Temp Outside>Inside
                                               name: v00 Umidita Assoluta Interna
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xWeather_Umidita_Assoluta_Interna
                                               primary_attribute: value_sensor.value
                                               type: ValueSensor
                                               name: v00 Umidita Assoluta Esterna
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xWeather_Umidita_Assoluta_Esterna
                                               type: ValueSensor
                                            IndiceThom
                                               name: vB1 IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xB1_IndiceThom_ID
                                               type: ValueSensor
                                               name: vB2 IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xB2_IndiceThom_ID
                                               type: ValueSensor
                                               name: vCS IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xCS_IndiceThom_ID
                                               type: ValueSensor
                                               name: vH IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xH_IndiceThom_ID
                                               type: ValueSensor
                                               name: vK IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xK_IndiceThom_ID
                                               type: ValueSensor
                                               name: vL IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xL_IndiceThom_ID
                                               type: ValueSensor
                                               name: vR1 IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR1_IndiceThom_ID
                                               type: ValueSensor
                                               name: vR2 IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR2_IndiceThom_ID
                                               type: ValueSensor
                                               name: vR3 IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR3_IndiceThom_ID
                                               type: ValueSensor
                                               name: vR4 IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR4_IndiceThom_ID
                                               type: ValueSensor
                                               name: vT IndiceThom
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xT_IndiceThom_ID
                                               type: ValueSensor
                                            LUX Funzionale
                                               name: vB1 LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xB1_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vB2 LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xB2_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vCS LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xCS_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vH LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xH_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vK LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xK_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vL LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xL_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vR1 LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR1_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vR2 LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR2_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vR3 LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR3_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vR4 LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR4_Lux_Funzionale_ID
                                               type: ValueSensor
                                               name: vT LuxFunzionale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xT_Lux_Funzionale_ID
                                               type: ValueSensor
                                            LUX AMBIENTALE
                                               name: vB1 LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xB1_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vB2 LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xB2_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vCS LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xCS_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vH LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xH_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vK LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xK_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vL LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xL_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vR1 LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR1_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vR2 LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR2_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vR3 LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR3_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vR4 LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xR4_Lux_Ambientale_ID
                                               type: ValueSensor
                                               name: vT LuxAmbientale
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xT_Lux_Ambientale_ID
                                               type: ValueSensor
                                            State
                                            EnergyMode10
                                               name: v00 EnergyMode Biorario
                                               name: v00 EnergyMode Sovraccarico Locale
                                               name: v00 EnergyMode Lavatrice State
                                               template: String Sensor
                                               capabilities:
                                                 string_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xB1_Lavatrice_State
                                               name: v00 EnergyMode Oven State
                                               capabilities:
                                                 string_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xK_Oven_State
                                               name: v00 EnergyMode Fridge State
                                               capabilities:
                                                 string_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xK_Fridge_State
                                               name: v00 EnergyMode Dishwasher State
                                               capabilities:
                                                 string_sensor:
                                                   attributes:
                                                     value:
                                                       expr: xK_Dishwasher_State
                                            HVACMode20
                                            TEST100
                                               template: Binary Switch
                                               name: TestF ValueSensor
                                               name: TestG ValueSensor
                                               name: TestH StringSensor
                                               name: TestI StringSensor
                                               name: TestJ StringSensor
                                               name: Test Virtual Heating Thermostat
                                               capabilities:
                                                 - hvac_control
                                                 - hvac_heating_unit
                                                 - temperature_sensor
                                               primary_attribute: hvac_control.state
                                               template: Dimmer
                                               name: Test Virtual Color DimmerA
                                               capabilities:
                                                 - color_temperature
                                               template: Dimmer
                                               name: Test Virtual Color DimmerB
                                               name: Test ModeHouse StringSensor
                                               capabilities:
                                                 string_sensor:
                                                   attributes:
                                                     value:
                                                       expr: x00_HouseMode_StartState
                                               name: TestA Dynamic Vec Binary
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                               primary_attribute: string_sensor.value
                                               type: StringSensor
                                               name: TestB Dynamic Vec Binary
                                               capabilities:
                                                 binary_sensor:
                                                   attributes:
                                                     state:
                                                       expr:
                                               primary_attribute: state_sensor.value
                                               type: BinarySensor
                                               name: TestC Dynamic Vec Binary
                                               capabilities:
                                                 value_sensor:
                                                   attributes:
                                                     value:
                                                       if_expr: test
                                               name: TEST D Dynamic VEC
                                               capabilities:
                                                 binary_sensor:
                                                   attributes:
                                                     state:
                                                       expr:
                                            END VIRTUAL DEVICE
                                          -ZWaveJS-UI 11.22.3
                                          -Update 16/08/2026
                                            149.4k
                                            1.3k
