  3. Vera
  4. Vera PushOver notification with image
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
2 Posts 2 Posters 1.4k Views 2 Watching
  • D Offline
    D Offline
    destination
    • D destination
      The code in your link was messed up when they updated that forum some years ago. I've rehashed it to give it a chance of working but I suspect you may still have trouble getting it to work. Running it in the Lua test window would be your starting point after reading the
      push over api doco.
      Another alternative is to use Telegram with the Telegram plugin.
      -- Refer to pushover documentation:
      --   https://pushover.net/api
      local pushToken    = "YourPushOverTokenHere"
      local pushUser     = "YourPushOverUserCodeHere"
      local pushTitle    = "MessageTitle"
      local pushMessage  = "MessageContent"
      local snapshotFile = "/tmp/camera_snapshot.jpg"
      local pushPriority = "1"
      -- Sound could be: pushover bike bugle, cash register, classical, cosmic, falling,
      -- gamelan, intermission, magic, mechanical, pianobar, siren, spacealarm, tugboat,
      -- alien, climb, persistent, echo, updown, none
      local pushSound = "gamelan"
      -- Link to the BlueIris videostream of that camera
      local pushUrl = "http://xxx.xxx.xxx.xxx/mjpg/ShortCamName&user=XXX&pw=XXX"
      local pushUrlTitle = "Camera Name"
      -- This points to one of my BlueIris managed cameras
      local camera = "http://xxx.xxx.xxx.xxx/image/ShortCamName?q=50&s=80&user=XXX&pw=XXX"
      -- Get the snapshot from the camera
      local out = assert(io.open(snapshotFile, "wb"))
      local _,data = luup.inet.wget(camera)
      out:write(data)
      assert(out:close())
      --Send PushOver request
      local curlCommandTab = {}
      table.insert (curlCommandTab, 'curl -s')
      table.insert (curlCommandTab, '-F "token='      ..pushToken    ..'"')
      table.insert (curlCommandTab, '-F "user='       ..pushUser     ..'"')
      table.insert (curlCommandTab, '-F "title='      ..pushTitle    ..'"')
      table.insert (curlCommandTab, '-F "message='    ..pushMessage  ..'"')
      table.insert (curlCommandTab, '-F attachment=@' ..snapshotFile ..'"')
      table.insert (curlCommandTab, '-F "sound='      ..pushSound    ..'"')
      table.insert (curlCommandTab, '-F "priority='   ..pushPriority ..'"')
      table.insert (curlCommandTab, '-F "url='        ..pushUrl      ..'"')
      table.insert (curlCommandTab, '-F "url_title='  ..pushUrlTitle ..'"')
      -- The .json suffix requests that the response be in JSON format
      table.insert (curlCommandTab, 'https://api.pushover.net/1/messages.json')
      local curlCommand = table.concat (curlCommandTab, ' ')
      print(curlCommand)
      local handle = io.popen(curlCommand)
      local result = handle:read("*a")
      handle:close()
      print (result)
      -- Delete temporary snapshot
      os.remove (snapshotFile)
        1.1k
        158.1k
