  3. Vera
  4. Nuke Vera Script
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
Nuke Vera Script
20 Posts 5 Posters 8.1k Views 6 Watching
    GitHub - rafale77/Nuke-Vera: Script to neuter the vera and broadcast its zwave and zigbee serial ports
    Script to neuter the vera and broadcast its zwave and zigbee serial ports - rafale77/Nuke-Vera
      Is this just as good as buying a zigbee stick ?
      I was thinking of using the zigbee through vera, but mabye this is better in terms of device compatibility?
      • parkercP Offline
        parkercP Offline
        parkerc
        Looking at the code and depending on the version of Ser2net that’s installed, adding e.g. max-connections=3 to the end of the Ser2net command would allow multiple connections ?
          So... I have been using this for 10 months now and yeah it is better than a zigbee stick because you bypass the usb interface. It is a direct serial uart so I got to fool around with the firmware without ever bricking it due incorrect bootloader etc which usb requires.
          You know there are only a handful of zigbee chipsets so... this is the silabs one and is the most generically compatible. The conbee would be the only zigbee stick I would consider with the TI one being last though it is cheap.
          @parkerc... yup I am using it with two connections. I have a uzb plugged into my vera at the center of my house sending both the zigbee and the uzb serial ports down to my z-way/openluup/homeassistant VMs in my server down in my garage. You can practically make it send any number of serial port you want.
          • parkercP Offline
            parkercP Offline
            parkerc
            Hey @rafale77
            I’m going to have a play with this later, as a comprehensive usb/serial server (https://smarthome.community/topic/209/home-automation-serial-server-raspberry-pi ) is something I’ve been tinkering with for years ! (https://community.getvera.com/t/building-a-ser2net-serial-to-ip-server/173673) - wow has it really been that long .. 2012 !!!
            Once announced and eventually added to Vera, Zigbee has been a capability that I’ve been keen to explore, but due to it’s lack of consistency (compared to z-wave) I’ve not invested much time.
            Although; it is on my HA to-do list, - out of my league, but by opening up the zigbee on Vera, is there the potential to extend its usage with (https://github.com/koenkk/zigbee-herdsman ) and (https://github.com/koenkk/zigbee2mqtt) ?
            • parkercP parkerc
              Hey @rafale77
              @parkerc
              Have not looked at these project in quite some time but if my memory serves me well, they support only the TI chipset stacks so no they are not compatible with the chip on the vera. The stack on the vera works with the bellows-zigpy project: https://github.com/zigpy/bellows, EZSP stack, which was the base of the initial Home assistant zigbee support.
                tallyho
                @rafale77. I want to neuter my Vera Plus and socat the zwave, but keep the client wifi connectivity so I can place the Vera more centrally. I modified the nuke vera script to not do "wifi down". This seemed to work for a while, my ra0 interface had an IP, and I was able to reboot the Vera and it still worked. After a couple days the Vera dropped off the wifi, even the wired interface wouldn't link up. I did a factory reset and that got the wired interface working again.
                I'm not sure how to configure the wireless interface. Using iwconfig to try and configure ra0 w/ the wifi ssid gave me "SET failed on device ra0 ; Operation not supported." Any ideas on what I might need to do to get the client wifi working?
                  Interesting. Not sure why none of the interface would work after a few days. You may want to look for system logs. This should not happen unless something on your network kicked the vera out. I am thinking of a DHCP lease renewal failing for example.
                  I would suggest to set everything with a static IP for a start if you have not done so. Note also that if you are using 2.4GHz wifi and don't have the channels setup right you may have your wifi interfere with zigbee.
                    So, I nuked my Vera.. 😲 (Just the bakup vera though)
                    Can you extrapolate your guide to the point where i see them in z-way?
                      Hmm it won't work on z-way... this is more for other platforms for example homeseer or home assistant. z-way unfortunately requires a key which requires the hardware to be specific (uzb or razberry).
                      The compatibility is only one way. You can use any usb zwave stick, including the uzb on homeseer, domotcz, homeassistant, vera etc... because they all use the same zwave serial API but z-way only works with their hardware.
                      With this nuking process, you basically turned the vera into a usb zwave and zigbee stick over IP.
                        Aha, OK.
                        Anyway, i found the way to install socat at least (for anyone wondering about this later):
                        Oct 25, 2017
                        Using a Vera Edge as a network-attached zwave device (skipping the vera software)
                        I have a few Vera’s lying around and I wanted to migrate one to home assistant, and instead of going the tedious way of adding again all my zwave devices to a zwave stick, I decided to try and make a zwave-to-tcp device out of the controller, and connect home assistant to it. Data path: zwave...
                        So, this is not a way to get zigbee to Openluup instead of the vera bridge?
                          wrote on last edited by PerH
                          Throwing out a thought; could it be possible to reinstall a VeraPlus with HASSio?
                          I'm really sick of the zigbee handling of the vera, so if HA can use the zigbee chip in the vera, that could be even more elegant than HASS on the main unit and Socat..
                          Found this thread: https://community.home-assistant.io/t/ha-on-openwrt/118125/16
                          It may be possible to do that on a nuked vera?
                            ..which links to this: https://community.home-assistant.io/t/how-to-install-ha-on-your-router/126937
                            I may have a go at this.. 🙂
                              I've been looking a bit more at this, taking in zigbee and rfxtrx from a vera to HASS.
                              Zigbee is in, and runs well, but the second connection is rough, wether its z-wave or RFXTRX (I added a line for it in ser2net.conf).
                              I noticed that the Vera seems to have a timeout on the connections, is there a way to disable this or to change it?
                                I have never observed this, Are you sure it isn't a network problem (switch maybe?)
                                  Can't see that my router does anything here, but I do see that the RFXTRX integration in HASS has some issues, so it may just be that implementation. Zigbee to ZHA in hass is completely stable..
                                  I just noticed that my SSH connection dropped out if i wasn't active on it, so I thought that this may be the case for the RFX connection as well..
                                    I've gotten all the connections up (problem was on the other side), but one issue is still here: Rotate_Logs.sh is still called every 20 minutes, and it causes a reboot. Can I just delete the script?
                                      I did a test of just modifying a line from the nukevera script, and now the vera is stable. 🙂 No idea if it's correct (or will survive a reboot), but it works..
                                      sed -i '2 a exit 0' /usr/bin/Rotate_Logs.sh
                                        madmax
                                        wrote on last edited by madmax
                                        Hello, I would like to use Home Assistant (HA) instead of the Vera Lite or Edge, which are becoming obsolete. The only thing is that Alexa works quite well with the Vera, but I believe that sooner or later, Ezlo will remove that functionality. There haven’t been any firmware updates for a while, so I’m wondering if it’s still possible to use a Vera with HA, as discussed in a previous post. Is it easily reversible in case it doesn’t work for me and I need to go back to the Vera? I’m thinking of using the “rafale77 nukevera.sh” script, but I suspect that despite a reboot, it may still leave some traces. So, to return to the original state, can we still access the interface to create a backup of the Vera? Thank you for the information. Also, for HA, how can I use socat because things might have changed over time?
                                          I havent needed Socat, just using Z2MQTT in a docker, and it connects to the vera just fine over network.. I ended up retiring the vera in the end in favour of UZB and Z-Stick, as some functions and security didn't work, but basic z-wave works well.
                                            157.7k
