  3. Vera
  4. Help with Luup Reloads
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
33 Posts 6 Posters 15.1k Views 6 Watching
    wrote on last edited by Pabla
    Recently I have been getting constant reloads on my Vera Plus running the latest 7.32 beta build. It usually starts after a 3-4 day Luup uptime and the reloads start at around 5am local time and keep going every 30 mins until I physically restart my Vera Plus (unplugging and plugging it back in). Right before a reload I see on the status bar above the modes on the homepage "cannot write user data" then after a few minutes a reload occurs. Looking into the logs I have seen mention of 03 06/21/21 8:53:18.102 JobHandler_LuaUPnP::Reload: low memory Critical 1 m_bCriticalOnly 0 dirty data 1 running 1 <0x76aa7520> almost every single time a reload happens. I have attached logs from 2 instances this morning where a reload happened. I have noticed that the OpenSprinkler plugin has been very chatty even though I have set debugging to 0, is that what is filling up temp log system?
    01	06/21/21 8:45:58.123	IOPort::Connect connect -1 192.168.8.43:23 <0x6a148520>
    02	06/21/21 8:45:59.031	UserData::CommitToDatabase data size 1244271 1244271 <0x7662b520>
    01	06/21/21 8:45:59.333	UserData::WriteUserData saved--before move File Size: 234865 save size 234865 <0x7662b520>
    02	06/21/21 8:45:59.333	UserData::TempLogFileSystemFailure start 0 <0x7662b520>
    02	06/21/21 8:45:59.334	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x7662b520>
    02	06/21/21 8:45:59.334	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x7662b520>
    01	06/21/21 8:45:59.341	UserData::WriteUserData failed File Size: 234865 save size 234902 <0x7662b520>
    02	06/21/21 8:45:59.342	UserData::TempLogFileSystemFailure start 1 <0x7662b520>
    02	06/21/21 8:45:59.344	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x7662b520>
    01	06/21/21 8:45:59.632	UserData::WriteUserData failed result:1 size2:234865 vs 234865 <0x7662b520>
    02	06/21/21 8:45:59.632	UserData::TempLogFileSystemFailure start 1 <0x7662b520>
    02	06/21/21 8:45:59.634	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x7662b520>
    02	06/21/21 8:45:59.635	UserData::TempLogFileSystemFailure start 0 <0x7662b520>
    02	06/21/21 8:45:59.635	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x7662b520>
    02	06/21/21 8:45:59.636	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x7662b520>
    06	06/21/21 8:45:59.636	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 skip: 0 v:0x1099d38/NONE duplicate:0 <0x7662b520>
    06	06/21/21 8:45:59.637	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 skip: 0 v:0x1a02d48/NONE duplicate:0 <0x7662b520>
    06	06/21/21 8:45:59.637	Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusID was: 0 now: 3 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x7662b520>
    06	06/21/21 8:45:59.638	Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusText was: OK now: GET_LANG(resetting_zigbee_network,Resetting Zigbee Network) #hooks: 0 upnp: 0 skip: 0 v:0x12b9e60/NONE duplicate:0 <0x7662b520>
    01	06/21/21 8:45:59.648	RAServerSync::SendAlert notification lost quit 1 device 50002761 servers:vera-us-oem-event12.mios.com/vera-us-oem-event11.mios.com for time 23822220 type 7 code user_data <0x7642b520>
    02	06/21/21 8:46:01.381	UserData::CommitToDatabase data size 1244349 1244349 <0x770dc320>
    01	06/21/21 8:46:01.675	UserData::WriteUserData saved--before move File Size: 234875 save size 234875 <0x770dc320>
    02	06/21/21 8:46:01.675	UserData::TempLogFileSystemFailure start 0 <0x770dc320>
    02	06/21/21 8:46:01.676	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x770dc320>
    02	06/21/21 8:46:01.676	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x770dc320>
    01	06/21/21 8:46:01.680	UserData::WriteUserData failed File Size: 234875 save size 234865 <0x770dc320>
    02	06/21/21 8:46:01.680	UserData::TempLogFileSystemFailure start 1 <0x770dc320>
    02	06/21/21 8:46:01.682	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x770dc320>
    01	06/21/21 8:46:01.940	UserData::WriteUserData failed result:1 size2:234875 vs 234875 <0x770dc320>
    02	06/21/21 8:46:01.941	UserData::TempLogFileSystemFailure start 1 <0x770dc320>
    02	06/21/21 8:46:01.943	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x770dc320>
    02	06/21/21 8:46:01.944	UserData::TempLogFileSystemFailure start 0 <0x770dc320>
    02	06/21/21 8:46:01.945	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x770dc320>
    02	06/21/21 8:46:01.945	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x770dc320>
    50	06/21/21 8:46:03.102	luup_log:1304: VeraOpenSprinkler[1.50]: [updateFromController] error: false - nil - nil <0x72581520>
    01	06/21/21 8:46:05.210	Main WatchDogRoutine: blocked - terminating 1 <0x695de520>
    02	06/21/21 8:46:05.211	Dumping 40 locks <0x695de520>
    02	06/21/21 8:46:05.211	finished check for exceptions <0x695de520>
    02	06/21/21 8:46:05.212	finished check for exceptions <0x695de520>
    02	06/21/21 8:46:05.213	finished check for exceptions <0x695de520>
    02	06/21/21 8:46:05.214	finished check for exceptions <0x695de520>
    02	06/21/21 8:46:05.215	finished check for exceptions <0x695de520>
    02	06/21/21 8:46:05.216	finished check for exceptions <0x695de520>
    02	06/21/21 8:46:05.217	finished check for exceptions <0x695de520>
    02	06/21/21 8:46:05.217	OL: (0xbbc560) (>100746) Variable JobHandler_LuaUPnP.cpp l:9817 time: 4:00:00p (1624290365 s) thread: 0x6f948520 Rel: Y Got: Y <0x695de520>
    02	06/21/21 8:46:05.218	OL: (0xbbc560) (>100751) Variable JobHandler_LuaUPnP.cpp l:9817 time: 4:00:00p (1624290365 s) thread: 0x6d948520 Rel: Y Got: Y <0x695de520>
    2021-06-21 08:46:05 - LuaUPnP Terminated with Exit Code: 137
    01	06/21/21 8:53:18.103	luup_log:901: Tesla Car_error: Monitor awake state, failed #400 HTTP/1.1 400 BAD REQUEST !! <0x72ffd520>
    02	06/21/21 8:53:18.482	UserData::CommitToDatabase data size 1244185 1244185 <0x76aa7520>
    01	06/21/21 8:53:18.781	UserData::WriteUserData saved--before move File Size: 234865 save size 234865 <0x76aa7520>
    02	06/21/21 8:53:18.781	UserData::TempLogFileSystemFailure start 0 <0x76aa7520>
    02	06/21/21 8:53:18.781	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x76aa7520>
    02	06/21/21 8:53:18.782	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x76aa7520>
    01	06/21/21 8:53:18.787	UserData::WriteUserData failed File Size: 234865 save size 234875 <0x76aa7520>
    02	06/21/21 8:53:18.787	UserData::TempLogFileSystemFailure start 1 <0x76aa7520>
    02	06/21/21 8:53:18.789	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x76aa7520>
    01	06/21/21 8:53:18.813	IOPort::Connect connect -1 192.168.8.43:23 <0x6a7c4520>
    01	06/21/21 8:53:19.020	UserData::WriteUserData failed result:1 size2:234865 vs 234865 <0x76aa7520>
    02	06/21/21 8:53:19.020	UserData::TempLogFileSystemFailure start 1 <0x76aa7520>
    02	06/21/21 8:53:19.023	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x76aa7520>
    02	06/21/21 8:53:19.027	UserData::TempLogFileSystemFailure start 0 <0x76aa7520>
    02	06/21/21 8:53:19.028	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x76aa7520>
    02	06/21/21 8:53:19.028	UserData::TempLogFileSystemFailure 0 res:0
    (null) <0x76aa7520>
    06	06/21/21 8:53:19.029	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 skip: 0 v:0x14bad80/NONE duplicate:0 <0x76aa7520>
    06	06/21/21 8:53:19.029	Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 skip: 0 v:0x1e23b10/NONE duplicate:0 <0x76aa7520>
    06	06/21/21 8:53:19.033	Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusID was: 0 now: 3 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x76aa7520>
    01	06/21/21 8:53:19.040	RAServerSync::SendAlert notification lost quit 1 device 50002761 servers:vera-us-oem-event12.mios.com/vera-us-oem-event11.mios.com for time 20546340 type 7 code user_data <0x76ca7520>
    06	06/21/21 8:53:19.044	Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusText was: OK now: GET_LANG(resetting_zigbee_network,Resetting Zigbee Network) #hooks: 0 upnp: 0 skip: 0 v:0x16dadc0/NONE duplicate:0 <0x76aa7520>
    02	06/21/21 8:53:20.807	UserData::CommitToDatabase data size 1244263 1244263 <0x77759320>
    01	06/21/21 8:53:21.081	UserData::WriteUserData saved--before move File Size: 234875 save size 234875 <0x77759320>
    02	06/21/21 8:53:21.081	UserData::TempLogFileSystemFailure start 0 <0x77759320>
    02	06/21/21 8:53:21.116	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x77759320>
    02	06/21/21 8:53:21.117	UserData::TempLogFileSystemFailure 699 res:1
    -rw-r--r--    1 root     root           504 Jun 26  2017 /etc/cmh/user_data.json.luup.lzo
    -rw-r--r--    1 root     root        234865 Jun 21 08:53 /etc/cmh/user_data.json.lzo
    -rw-r--r--    1 root     root        234996 Jun 21 08:11 /etc/cmh/user_data.json.lzo.1
    -rw-r--r--    1 root     root        234930 Jun 21 08:02 /etc/cmh/user_data.json.lzo.2
    -rw-r--r--    1 root     root        234968 Jun 21 07:47 /etc/cmh/user_data.json.lzo.3
    -rw-r--r--    1 root     root        234658 Jun 21 07:11 /etc/cmh/user_data.json.lzo.4
    -rw-r--r--    1 root     root        234909 Jun 21 06:50 /etc/cmh/user_data.json.lzo.5
    -rw-r--r--    1 root     root        234875 Jun 21 08:53 /etc/cmh/user_data.json.lzo.new
     <0x77759320>
    02	06/21/21 8:53:21.228	UserData::TempLogFileSystemFailure start 0 <0x77759320>
    02	06/21/21 8:53:21.259	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x77759320>
    02	06/21/21 8:53:21.259	UserData::TempLogFileSystemFailure 610 res:1
    -rw-r--r--    1 root     root        234865 Jun 21 08:53 /etc/cmh/user_data.json.lzo.1
    -rw-r--r--    1 root     root        234996 Jun 21 08:11 /etc/cmh/user_data.json.lzo.2
    -rw-r--r--    1 root     root        234930 Jun 21 08:02 /etc/cmh/user_data.json.lzo.3
    -rw-r--r--    1 root     root        234968 Jun 21 07:47 /etc/cmh/user_data.json.lzo.4
    -rw-r--r--    1 root     root        234658 Jun 21 07:11 /etc/cmh/user_data.json.lzo.5
     <0x77759320>
    06	06/21/21 8:53:21.465	Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeDevice1 variable: PendingRemoveDevices was: 0024460000144655-01d8,0024460000146120-a155,00244600001467ad-a538 now: 0024460000144655-01d8,0024460000146120-a155,00244600001467ad-a538 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77759320>
    06	06/21/21 8:53:21.469	Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:ZigbeeDevice1 variable: UnknownDevices was:  now:  #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77759320>
    03	06/21/21 8:53:22.100	LuaUPNP: ending <0x77759320>
    2021-06-21 08:53:22 - LuaUPnP Terminated with Exit Code: 0```
      (null) <0x7662b520>
      (null) <0x7662b520>
      (null) <0x7662b520>
      (null) <0x7662b520>
      (null) <0x770dc320>
      (null) <0x770dc320>
      (null) <0x770dc320>
      (null) <0x770dc320>
      (null) <0x76aa7520>
      (null) <0x76aa7520>
      (null) <0x76aa7520>
      (null) <0x76aa7520>
       <0x77759320>
       <0x77759320>
      @pabla I could definitely remove some logs and move them to debug only.
      All that said, these crashes are normal and all related to memory leaks. I have similar ones and I’ve just set a memory watch to automatically reload it under these circumstances.
      PablaP 1 Reply Last reply
        @therealdb Do you think using a USB for logs would stop the memory leaks? The reloads continually happen until I manually do something about it
          @pabla I’m not confident it will. I have my logs on a network share… just use sysmon plugin to watch for memory and when below 90.000 do a luup.reload via a scene.
            @therealdb I just SSH into my unit and checked the /tmp folder and I found this, is this normal? I have tons of these files which I have never seen before
            Edit: I deleted all those files and more keep showing up by the minute lol! Something is definitely up
            therealdbT 2 Replies Last reply
              @pabla these files should be auto-deleted. But I’ll definitely take another look and release a fix today.
                @pabla version 1.51 is on github, addressing the temp files problem specifically. It will delete file older than 3 minutes. I've it running in my own test system with no problems.
                I still need to fix the duplication of programs in case of re-config, so just update the CurrentVersion variable on the master to 1.51 before updating the plug-in's files, so it will not configure it again.
                A fix for "ChildrenInSameRoom" is on its way in the next release. Try it and lemme know.
                  One thing to add here, a possibility: I notice that the plugin is using the 'ip' attribute to store the IP address of the controller. I have found that this causes a lot of instability. Luup has certain automatic things that it does in the background to try to open connections when the IP is stored on that attribute. It's all part of their built-in automatic I/O for serial and IP connections, which this plugin doesn't use. But Luup will try, try and retry forever to start and maintain a connection to that IP. I believe that this is at least one source of a memory leak -- I suspect their error handling on connection failure is not completely cleaning up after itself, so the system leaks memory, and/or possible even sockets. I discovered this some years ago and switched all of my plugins to just use state variables for the IP. My systems do not restart due to memory leaks, and memory usage is generally flat.
                  akbooerA therealdbT 3 Replies Last reply
                    @toggledbits said in Help with Luup Reloads:
                    Yes, this is, indeed, an issue, although NOT one, I would say, for openLuup. It may well explain why Vera behaves (sort of) when you remove some plugins.
                    For some time, now, I had a Vera Edge running without any plugins or Z-wave devices, and, I have to say, it just runs and runs!
                    toggledbitsT A 2 Replies Last reply
                      @toggledbits yep, I will change it in next build. I'm onto it as we speak. On my system I have few plug-ins, no one is using an IP and I'm still experiencing memory leaks. But I will probably just move everything to openLuup and use the Vera as a radio system.
                        @akbooer said in Help with Luup Reloads:
                        Sorry, did I miss that this was openLuup? Or are you just confirming that openLuup is better than real Luup (which everyone already knows)? 🙂
                          @therealdb said in Help with Luup Reloads:
                          One more thing... some versions of Luup have trouble returning the status from os.execute(). They said they have fixed it in the newer beta builds (5363/4/5), but it's concerning that it could be broken at all (should be straightforward, not unstable), and Edward's response to me when queried was a bit uncertain. So I've started moving away from using the return value under Luup and started doing error detection other ways (e.g. does the file I expect now exist?).
                            Oooh, hope not... NO, just checked...
                            @pabla said in Help with Luup Reloads:
                            Er, yes, just that, really. Let's say that this is one feature I chose not to emulate.
                              So I updated to 1.51 and dont see the files in the /tmp folder being deleted after 3 minsf53f49fd-ff36-4045-8011-702b8c6efd3f-image.png
                                @pabla I found a small problem, and I'll fix it in a moment. Please wait for a new release.
                                  @therealdb No rush, just reporting back 🙂
                                    @pabla 1.51-hotfix is on GitHub.
                                    • programs duplication is now fixed, so a reconfiguration is OK
                                    • IP is now a variable (and it's automatically migrated - don't worry)
                                    • temp files are correctly deleted
                                    • I've tracked the problem with infinite stations - and I'm working on a permanent fix. this seems to be related to reloads and I'll investigate this further in the next days.
                                    Give it a try!
                                      @toggledbits I found that AltHue by @amg0 is still using IP attr. I'll probably send him a pull request, since it's very popular.
                                        Give it a try!
                                        @therealdb So I updated to the latest hot fix, and the files still aren't getting deleted. I have a fill from 11:06am local time and its 11:27am. Do they auto delete after a longer time?
                                          @pabla nope, this should be performed at every http call. This is weird. I’ve just deleted mine with the plugin and it’s working. Try to delete them by hand for the last time and let’s see if it’s working from now on.
